    Error on update to MM 2.11.0
    32 Posts 2 Posters 8.6k Views 2 Watching
    • K Offline
      killing joke @sdetweil
      I could facepalm me so hard for my last post since I want to hurry up my own post.
      Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
      How can I check the status of my npm?
        sdetweil @killing joke
        @killing-joke
        npm -v
        node -v
        • K Offline
          npm version 6.14.5
          node version 9.11.2
            @killing-joke
            to update manually you did
            ~/MagicMirror
            git pull
            npm install
            right?
              @killing-joke no… that won’t do…
              best thing is to run my upgrade script
              see https://github.com/sdetweil/MagicMirror_scripts
              and use force, instead of apply (because u already have the mm code pulled down)
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              • K Offline
                I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                installed it again know but following occurs
                pi@raspberrypi:~/MagicMirror $ npm install
                > magicmirror@2.11.0 install /home/pi/MagicMirror
                > echo "Installing vendor files ...
                " && cd vendor && npm install --loglevel=error
                > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                > node attribution.js
                Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                found 0 vulnerabilities
                > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                > npm run install-fonts && echo "MagicMirror installation finished successfully!
                > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                > echo "Installing fonts ...
                " && cd fonts && npm install --loglevel=error
                updated 1 package and audited 1 package in 2.515s
                audited 1172 packages in 61.47s
                70 packages are looking for funding
                  run `npm fund` for details
                found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                  run `npm audit fix` to fix them, or `npm audit` for details
                afterwards the same error occurs as in the first post described.
                  @killing-joke said in Error on update to MM 2.11.0:
                  magicmirror@2.11.0
                  but u still have 2.11 installed
                  so the git pull failed
                  • K Offline
                    funny, but when i go into the MM folder and type “git pull” it says it´s the latest software… (in German)
                      @killing-joke do
                      cd MagicMirror
                      git remote -v
                      grep version package.json
                      • K Offline
                        @sdetweil result as followed
                        pi@raspberrypi:~/MagicMirror $ git remote -v
                        origin	https://github.com/MichMich/MagicMirror.git (fetch)
                        origin	https://github.com/MichMich/MagicMirror.git (push)
                        pi@raspberrypi:~/MagicMirror $ grep version package.json
                          "version": "2.11.0",
                        • 3 / 4
