    Error on update to MM 2.11.0
    32 Posts 2 Posters 11.3k Views 2 Watching
      sdetweil @killing joke
      @killing-joke do
      cd MagicMirror
      git remote -v
      grep version package.json
      • K Offline
        killing joke @sdetweil
        @sdetweil result as followed
        pi@raspberrypi:~/MagicMirror $ git remote -v
        origin	https://github.com/MichMich/MagicMirror.git (fetch)
        origin	https://github.com/MichMich/MagicMirror.git (push)
        pi@raspberrypi:~/MagicMirror $ grep version package.json
          "version": "2.11.0",
          @killing-joke said in Error on update to MM 2.11.0:
          “version”: “2.11.0”,
          definitely NOT the latest
          S K 2 Replies Last reply Reply Quote 0
            @sdetweil please run my script…
            • K Offline
              ok, i will do
                @killing-joke please run my script…
                https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
                • K Offline
                  pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  No LSB modules are available.
                  doing test run = false
                  Minimum Node version: v14.0.0
                  Installed Node version: v9.11.2
                  Node should be upgraded.
                  A Node process is currently running. Can't upgrade.
                  Please quit all Node processes and restart the installer.
                  pi 813 764 0 19:45 ? 00:00:00 sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js pi 817 813 0 19:45 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi 876 817 0 19:45 ? 00:00:05 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js pi 882 876 0 19:45 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 968 882 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 1133 876 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --field-trial-handle=16961185687081278422,14233476580341739937,131072 --disable-features=LayoutNG,SpareRendererForSitePerProcess --gpu-preferences=IAAAAAAAAAAgAAAgAAAAAAAAYAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --service-request-channel-token=5596814612634470352 pi 1946 1944 0 20:03 pts/0 00:00:00 grep node
                  how can I end a Node process to try again?
                    @killing-joke
                    pm2 stop all
                    then
                    ps -ef | grep node | grep -v color
                    it should return no output
                    • K Offline
                      pi@raspberrypi:~/MagicMirror $ pm2 stop all
                      [PM2] Applying action stopProcessId on app [all](ids: 0)
                      [PM2] [MagicMirror](0) ✓
                      │ App name    │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                      │ MagicMirror │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                       Use `pm2 show <id|name>` to get more details about an app
                      pi@raspberrypi:~/MagicMirror $ ps -ef | grep node | grep -v color
                        @killing-joke ok, now run my script again
                        • K Offline
                          I did.
                          afterwards “npm start” but with a black screen of my MM.
                          But I need to rest for today… tomorrow is another day to have fun with it!
                          Thanks for today
                          Installing Node.js ...
                          gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                          Paketlisten werden gelesen... Fertig
                          Abhängigkeitsbaum wird aufgebaut.
                          Statusinformationen werden eingelesen.... Fertig
                          Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                            realpath
                          Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                          Die folgenden Pakete werden aktualisiert (Upgrade):
                            nodejs
                          1 aktualisiert, 0 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
                          Es müssen 23,0 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 57,2 MB Plattenplatz zusätzlich benutzt.
                          Holen:1 https://deb.nodesource.com/node_14.x stretch/main armhf nodejs armhf 14.18.1-1nodesource1 [23,0 MB]
                          Es wurden 23,0 MB in 5 s geholt (4.587 kB/s).
                          apt-listchanges: Lese Changelogs...
                          (Lese Datenbank ... 123797 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../nodejs_14.18.1-1nodesource1_armhf.deb ...
                          Detected old npm client, removing...
                          Entpacken von nodejs (14.18.1-1nodesource1) über (9.11.2-1nodesource1) ...
                          nodejs (14.18.1-1nodesource1) wird eingerichtet ...
                          Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                          node version is
                          Node.js installation Done! version=v14.18.1
                          Minimum npm version: V6.0.0
                          Installed npm version: V6.14.15
                          No npm upgrade necessary.
                          upgrading from version 2.11.0 to 2.17.1
                          fetching latest revisions
                          there are 5 local files that are different than the master repo
                             fonts/package-lock.json
                             modules/default/calendar/calendar.js
                             package-lock.json
                             package.json
                             vendor/package-lock.json
                          any *-lock.json files do not need to be saved
                          do you want to save these files for later   (Y/n)?y
                          npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aws4
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/bowser
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet-csp
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/minimist
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/mkdirp
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/p-limit
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/yargs-parser
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/moment
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/request/node_modules/tough-cookie
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimstart
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimleft
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimend
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimright
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/p-limit
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/yargs-parser
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/express-ipfilter
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/grunt-markdownlint
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract/node_modules
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet/node_modules
                          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git/node_modules
                          npm ERR! code EACCES
                          npm ERR! syscall access
                          npm ERR! path /home/pi/MagicMirror/node_modules/aws4
                          npm ERR! errno -13
                          npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'
                          npm ERR!  [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'] {
                          npm ERR!   errno: -13,
                          npm ERR!   code: 'EACCES',
                          npm ERR!   syscall: 'access',
                          npm ERR!   path: '/home/pi/MagicMirror/node_modules/aws4'
                          npm ERR! }
                          npm ERR!
                          npm ERR! The operation was rejected by your operating system.
                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                          npm ERR!
                          npm ERR! If you believe this might be a permissions issue, please double-check the
                          npm ERR! permissions of the file and its containing directories, or try running
                          npm ERR! the command again as root/Administrator.
                          npm ERR!     /home/pi/.npm/_logs/2021-11-14T19_31_28_554Z-debug.log
                          	  package.json not found for module MMM-SunRiseSet
                          adding package.json for module MMM-SunRiseSet
                          	 require for request in module MMM-SunRiseSet not found in package.json package.json for module MMM-SunRiseSet
                          installing request for module MMM-SunRiseSet
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          	 require for request in module MMM-AVStock not found in package.json package.json for module MMM-AVStock
                          installing request for module MMM-AVStock
                          processing for module MMM-Carousel please wait
                          up to date in 0.732s
                          found 0 vulnerabilities
                          processing complete for module MMM-Carousel
                          processing for module MMM-DWD-WarnWeather please wait
                          added 47 packages from 58 contributors and audited 47 packages in 6.397s
                          2 packages are looking for funding
                            run `npm fund` for details
                          processing complete for module MMM-DWD-WarnWeather
                          processing for module MMM-SunRiseSet please wait
                          added 47 packages from 58 contributors and audited 47 packages in 6.702s
                          processing complete for module MMM-SunRiseSet
                          processing for module MMM-AVStock please wait
                          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                          added 53 packages from 62 contributors and audited 54 packages in 11.297s
                          processing complete for module MMM-AVStock
                          processing for module MMM-Fuel please wait
                          npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                          npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                          added 464 packages from 298 contributors and audited 464 packages in 84.828s
                          101 packages are looking for funding
                          found 6 moderate severity vulnerabilities
                            run `npm audit fix` to fix them, or `npm audit` for details
                          processing complete for module MMM-Fuel
                          we stashed a set of files that appear changed from the latest repo versions. you should review them
                          see installers/stashed_files for the list
                          you can use git checkout stash@{0} -- filename to extract one file from the stash
                          or git stash pop to restore them all
                          WARNING..
                          WARNING.. either will overlay the file just installed by the update
                          WARNING..
                          > magicmirror@2.17.1 start /home/pi/MagicMirror
                          [2021-11-14 20:35:10.378] [LOG]    Starting MagicMirror: v2.17.1
                          [2021-11-14 20:35:10.425] [LOG]    Loading config ...
                          [2021-11-14 20:35:10.441] [LOG]    Loading module helpers ...
                          [2021-11-14 20:35:10.451] [LOG]    No helper found for module: MMM-Carousel.
                          [2021-11-14 20:35:10.454] [LOG]    No helper found for module: alert.
                          [2021-11-14 20:35:10.494] [LOG]    Initializing new module helper ...
                          [2021-11-14 20:35:10.496] [LOG]    Module helper loaded: updatenotification
                          [2021-11-14 20:35:10.500] [LOG]    No helper found for module: clock.
                          [2021-11-14 20:35:10.628] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                          Require stack:
                          - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                          - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                          [2021-11-14 20:35:10.630] [LOG]    Loading module helpers ...
                          [2021-11-14 20:35:10.631] [LOG]    No helper found for module: MMM-Carousel.
                          [2021-11-14 20:35:10.632] [LOG]    No helper found for module: alert.
                          [2021-11-14 20:35:10.634] [LOG]    Initializing new module helper ...
                          [2021-11-14 20:35:10.634] [LOG]    Module helper loaded: updatenotification
                          [2021-11-14 20:35:10.635] [LOG]    No helper found for module: clock.
                          [2021-11-14 20:35:10.640] [ERROR]  App threw an error during load
                          [2021-11-14 20:35:10.642] [ERROR]  Error: Cannot find module 'node-ical'
                          Require stack:
                              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                              at Module.require (internal/modules/cjs/loader.js:685:19)
                              at require (internal/modules/cjs/helpers.js:16:16)
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:10:14)
                              at Module._compile (internal/modules/cjs/loader.js:786:30)
                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                              at Module.load (internal/modules/cjs/loader.js:645:32)
                          [2021-11-14 20:35:10.645] [ERROR]  Whoops! There was an uncaught exception...
                          [2021-11-14 20:35:10.646] [ERROR]  Error: Cannot find module 'node-ical'
                          Require stack:
                              at Module.load (internal/modules/cjs/loader.js:645:32) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                              '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                              '/home/pi/MagicMirror/js/app.js',
                              '/home/pi/MagicMirror/js/electron.js',
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              undefined
                          [2021-11-14 20:35:10.659] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2021-11-14 20:35:10.660] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                          [2021-11-14 20:35:11.331] [LOG]    Launching application.
                          [2021-11-14 20:37:36.856] [LOG]    Shutting down server...
                          [2021-11-14 20:37:36.862] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:36.864] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:36.865] [ERROR]  Whoops! There was an uncaught exception...
                          [2021-11-14 20:37:36.866] [ERROR]  TypeError: Cannot read property 'close' of undefined
                              at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
                              at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
                              at App.emit (events.js:200:13)
                              at Object.exports.execute (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item-roles.js:286:23)
                              at MenuItem.click (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item.js:46:20)
                              at Function.executeCommand (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:32:17)
                          [2021-11-14 20:37:36.870] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2021-11-14 20:37:36.871] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2021-11-14 20:37:38.262] [LOG]    Shutting down server...
                          [2021-11-14 20:37:38.265] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:38.266] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:38.268] [ERROR]  Whoops! There was an uncaught exception...
                          [2021-11-14 20:37:38.269] [ERROR]  TypeError: Cannot read property 'close' of undefined
                          [2021-11-14 20:37:38.271] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2021-11-14 20:37:38.272] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2021-11-14 20:37:39.822] [LOG]    Shutting down server...
                          [2021-11-14 20:37:39.823] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:39.824] [LOG]    Stopping module helper: updatenotification
                          [2021-11-14 20:37:39.826] [ERROR]  Whoops! There was an uncaught exception...
                          [2021-11-14 20:37:39.827] [ERROR]  TypeError: Cannot read property 'close' of undefined
                          [2021-11-14 20:37:39.829] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2021-11-14 20:37:39.830] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            @killing-joke crazy
                            sudo rm -rf node_modules
                            the update didn’t work (write access) almost like someone did sudo npm install at one time.
                            run my script again
                            • K Offline
                              @sdetweil I did the described code
                              and run your script again. The result as followed…
                              pi@raspberrypi:~ $ sudo rm -rf node_modules
                              pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                              Installed Node version: v14.18.1
                              No Node.js upgrade necessary.
                              upgrading from version 2.17.1 to 2.17.1
                              npm ERR! errno -13
                              npm ERR! }
                              npm ERR!
                              npm ERR!
                              npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_23_10_794Z-debug.log
                              up to date in 1.262s
                              added 47 packages from 58 contributors and audited 47 packages in 7.638s
                              added 47 packages from 58 contributors and audited 47 packages in 6.311s
                              added 53 packages from 62 contributors and audited 54 packages in 9.551s
                              added 464 packages from 298 contributors and audited 464 packages in 67.606s
                              pi@raspberrypi:~ $
                              “npm start” gives me the following error code
                              pi@raspberrypi:~ $ npm start
                              npm ERR! code ENOENT
                              npm ERR! syscall open
                              npm ERR! errno -2
                              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm ERR! enoent This is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_27_04_499Z-debug.log
                              pi@raspberrypi:~ $
                              I don´t have a folder named “.npm” to show the logs. Is it a hidden folder?
                                @killing-joke you need to be IN the MagicMirror folder to do npm start
                                  @killing-joke but u missed a step right at the beginning
                                  so u didn’t erase the bad folder which is causing all the problems
                                  • K Offline
                                    @sdetweil said in Error on update to MM 2.11.0:
                                    Oh my gosh, same mistake twice a week? Shame on me!!!
                                    Did as described before (but IN the correct folder now) :beaming_face_with_smiling_eyes:
                                    pi@raspberrypi:~/MagicMirror $ sudo rm -rf node_modulespi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                    (23) Failed writing body
                                    > core-js@3.15.2 postinstall /home/pi/MagicMirror/node_modules/core-js
                                    > node -e "try{require('./postinstall')}catch(e){}"
                                    Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                                    The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                                    > https://opencollective.com/core-js
                                    > https://www.patreon.com/zloirock
                                    Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                                    > electron@13.5.1 postinstall /home/pi/MagicMirror/node_modules/electron
                                    > node install.js
                                    > magicmirror@2.17.1 install /home/pi/MagicMirror
                                    " && cd vendor && npm install --loglevel=error
                                    audited 9 packages in 1.163s
                                    > magicmirror@2.17.1 postinstall /home/pi/MagicMirror
                                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                    > magicmirror@2.17.1 install-fonts /home/pi/MagicMirror
                                    > echo "Installing fonts ...
                                    " && cd fonts && npm install --loglevel=error
                                    audited 1 package in 1.367s
                                    added 294 packages from 243 contributors and audited 918 packages in 94.737s
                                    20 packages are looking for funding
                                    up to date in 0.782s
                                    added 47 packages from 58 contributors and audited 47 packages in 9.188s
                                    added 47 packages from 58 contributors and audited 47 packages in 6.346s
                                    added 53 packages from 62 contributors and audited 54 packages in 9.937s
                                    added 464 packages from 298 contributors and audited 464 packages in 72.299s
                                    npm start works fine, but two more questions:
                                    • What should I do with the 6 moderate severity vulnerabilities? (last block of the code)
                                    • how should I update my MM or the modules in future?
                                    Thank you very much for your help / support!!!
                                      nothing you can do… not our code
                                      MM run my upgarde script
                                      modules, u have to go to each module folder that NEEDS update and do
                                      git pull
                                      IF the module has a package.json file then also do , IN the module folder,
                                      rm -rf node_modules
                                      npm install
                                        can u send the log file to me via email, same userid at gmail…
                                        I want to look at the one error reported
                                          @sdetweil thanks… the error reported was related to timing of part of the script… nothing damaged, and I never knew this error could occur… so fun times!!
                                          • K Offline
                                            @sdetweil glad to help ;-)
