    Error on update to MM 2.11.0
    32 Posts 2 Posters 10.1k Views 2 Watching
    • K Offline
      killing joke @sdetweil
      ok, i will do
        sdetweil @killing joke
        @killing-joke please run my script…
        https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
        • K Offline
          pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
          No LSB modules are available.
          doing test run = false
          Minimum Node version: v14.0.0
          Installed Node version: v9.11.2
          Node should be upgraded.
          A Node process is currently running. Can't upgrade.
          Please quit all Node processes and restart the installer.
          pi 813 764 0 19:45 ? 00:00:00 sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js pi 817 813 0 19:45 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi 876 817 0 19:45 ? 00:00:05 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js pi 882 876 0 19:45 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 968 882 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 1133 876 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --field-trial-handle=16961185687081278422,14233476580341739937,131072 --disable-features=LayoutNG,SpareRendererForSitePerProcess --gpu-preferences=IAAAAAAAAAAgAAAgAAAAAAAAYAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --service-request-channel-token=5596814612634470352 pi 1946 1944 0 20:03 pts/0 00:00:00 grep node
          how can I end a Node process to try again?
            @killing-joke
            pm2 stop all
            then
            ps -ef | grep node | grep -v color
            it should return no output
            • K Offline
              pi@raspberrypi:~/MagicMirror $ pm2 stop all
              [PM2] Applying action stopProcessId on app [all](ids: 0)
              [PM2] [MagicMirror](0) ✓
              │ App name    │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
              │ MagicMirror │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
               Use `pm2 show <id|name>` to get more details about an app
              pi@raspberrypi:~/MagicMirror $ ps -ef | grep node | grep -v color
                @killing-joke ok, now run my script again
                • K Offline
                  I did.
                  afterwards “npm start” but with a black screen of my MM.
                  But I need to rest for today… tomorrow is another day to have fun with it!
                  Thanks for today
                  Installing Node.js ...
                  gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                  Paketlisten werden gelesen... Fertig
                  Abhängigkeitsbaum wird aufgebaut.
                  Statusinformationen werden eingelesen.... Fertig
                  Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                    realpath
                  Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                  Die folgenden Pakete werden aktualisiert (Upgrade):
                    nodejs
                  1 aktualisiert, 0 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
                  Es müssen 23,0 MB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 57,2 MB Plattenplatz zusätzlich benutzt.
                  Holen:1 https://deb.nodesource.com/node_14.x stretch/main armhf nodejs armhf 14.18.1-1nodesource1 [23,0 MB]
                  Es wurden 23,0 MB in 5 s geholt (4.587 kB/s).
                  apt-listchanges: Lese Changelogs...
                  (Lese Datenbank ... 123797 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../nodejs_14.18.1-1nodesource1_armhf.deb ...
                  Detected old npm client, removing...
                  Entpacken von nodejs (14.18.1-1nodesource1) über (9.11.2-1nodesource1) ...
                  nodejs (14.18.1-1nodesource1) wird eingerichtet ...
                  Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                  node version is
                  Node.js installation Done! version=v14.18.1
                  Minimum npm version: V6.0.0
                  Installed npm version: V6.14.15
                  No npm upgrade necessary.
                  upgrading from version 2.11.0 to 2.17.1
                  fetching latest revisions
                  there are 5 local files that are different than the master repo
                     fonts/package-lock.json
                     modules/default/calendar/calendar.js
                     package-lock.json
                     package.json
                     vendor/package-lock.json
                  any *-lock.json files do not need to be saved
                  do you want to save these files for later   (Y/n)?y
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aws4
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/bowser
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet-csp
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/minimist
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/mkdirp
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/p-limit
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/yargs-parser
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/moment
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/request/node_modules/tough-cookie
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimstart
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimleft
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimend
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimright
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/p-limit
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/yargs-parser
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/express-ipfilter
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/grunt-markdownlint
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract/node_modules
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet/node_modules
                  npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git/node_modules
                  npm ERR! code EACCES
                  npm ERR! syscall access
                  npm ERR! path /home/pi/MagicMirror/node_modules/aws4
                  npm ERR! errno -13
                  npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'
                  npm ERR!  [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'] {
                  npm ERR!   errno: -13,
                  npm ERR!   code: 'EACCES',
                  npm ERR!   syscall: 'access',
                  npm ERR!   path: '/home/pi/MagicMirror/node_modules/aws4'
                  npm ERR! }
                  npm ERR!
                  npm ERR! The operation was rejected by your operating system.
                  npm ERR! It is likely you do not have the permissions to access this file as the current user
                  npm ERR!
                  npm ERR! If you believe this might be a permissions issue, please double-check the
                  npm ERR! permissions of the file and its containing directories, or try running
                  npm ERR! the command again as root/Administrator.
                  npm ERR!     /home/pi/.npm/_logs/2021-11-14T19_31_28_554Z-debug.log
                  	  package.json not found for module MMM-SunRiseSet
                  adding package.json for module MMM-SunRiseSet
                  	 require for request in module MMM-SunRiseSet not found in package.json package.json for module MMM-SunRiseSet
                  installing request for module MMM-SunRiseSet
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  	 require for request in module MMM-AVStock not found in package.json package.json for module MMM-AVStock
                  installing request for module MMM-AVStock
                  processing for module MMM-Carousel please wait
                  up to date in 0.732s
                  found 0 vulnerabilities
                  processing complete for module MMM-Carousel
                  processing for module MMM-DWD-WarnWeather please wait
                  added 47 packages from 58 contributors and audited 47 packages in 6.397s
                  2 packages are looking for funding
                    run `npm fund` for details
                  processing complete for module MMM-DWD-WarnWeather
                  processing for module MMM-SunRiseSet please wait
                  added 47 packages from 58 contributors and audited 47 packages in 6.702s
                  processing complete for module MMM-SunRiseSet
                  processing for module MMM-AVStock please wait
                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                  added 53 packages from 62 contributors and audited 54 packages in 11.297s
                  processing complete for module MMM-AVStock
                  processing for module MMM-Fuel please wait
                  npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                  npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                  added 464 packages from 298 contributors and audited 464 packages in 84.828s
                  101 packages are looking for funding
                  found 6 moderate severity vulnerabilities
                    run `npm audit fix` to fix them, or `npm audit` for details
                  processing complete for module MMM-Fuel
                  we stashed a set of files that appear changed from the latest repo versions. you should review them
                  see installers/stashed_files for the list
                  you can use git checkout stash@{0} -- filename to extract one file from the stash
                  or git stash pop to restore them all
                  WARNING..
                  WARNING.. either will overlay the file just installed by the update
                  WARNING..
                  > magicmirror@2.17.1 start /home/pi/MagicMirror
                  [2021-11-14 20:35:10.378] [LOG]    Starting MagicMirror: v2.17.1
                  [2021-11-14 20:35:10.425] [LOG]    Loading config ...
                  [2021-11-14 20:35:10.441] [LOG]    Loading module helpers ...
                  [2021-11-14 20:35:10.451] [LOG]    No helper found for module: MMM-Carousel.
                  [2021-11-14 20:35:10.454] [LOG]    No helper found for module: alert.
                  [2021-11-14 20:35:10.494] [LOG]    Initializing new module helper ...
                  [2021-11-14 20:35:10.496] [LOG]    Module helper loaded: updatenotification
                  [2021-11-14 20:35:10.500] [LOG]    No helper found for module: clock.
                  [2021-11-14 20:35:10.628] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                  Require stack:
                  - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                  - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                  [2021-11-14 20:35:10.630] [LOG]    Loading module helpers ...
                  [2021-11-14 20:35:10.631] [LOG]    No helper found for module: MMM-Carousel.
                  [2021-11-14 20:35:10.632] [LOG]    No helper found for module: alert.
                  [2021-11-14 20:35:10.634] [LOG]    Initializing new module helper ...
                  [2021-11-14 20:35:10.634] [LOG]    Module helper loaded: updatenotification
                  [2021-11-14 20:35:10.635] [LOG]    No helper found for module: clock.
                  [2021-11-14 20:35:10.640] [ERROR]  App threw an error during load
                  [2021-11-14 20:35:10.642] [ERROR]  Error: Cannot find module 'node-ical'
                  Require stack:
                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:10:14)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                  [2021-11-14 20:35:10.645] [ERROR]  Whoops! There was an uncaught exception...
                  [2021-11-14 20:35:10.646] [ERROR]  Error: Cannot find module 'node-ical'
                  Require stack:
                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                      '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [2021-11-14 20:35:10.659] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2021-11-14 20:35:10.660] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                  [2021-11-14 20:35:11.331] [LOG]    Launching application.
                  [2021-11-14 20:37:36.856] [LOG]    Shutting down server...
                  [2021-11-14 20:37:36.862] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:36.864] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:36.865] [ERROR]  Whoops! There was an uncaught exception...
                  [2021-11-14 20:37:36.866] [ERROR]  TypeError: Cannot read property 'close' of undefined
                      at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
                      at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
                      at App.emit (events.js:200:13)
                      at Object.exports.execute (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item-roles.js:286:23)
                      at MenuItem.click (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item.js:46:20)
                      at Function.executeCommand (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:32:17)
                  [2021-11-14 20:37:36.870] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2021-11-14 20:37:36.871] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2021-11-14 20:37:38.262] [LOG]    Shutting down server...
                  [2021-11-14 20:37:38.265] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:38.266] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:38.268] [ERROR]  Whoops! There was an uncaught exception...
                  [2021-11-14 20:37:38.269] [ERROR]  TypeError: Cannot read property 'close' of undefined
                  [2021-11-14 20:37:38.271] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2021-11-14 20:37:38.272] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2021-11-14 20:37:39.822] [LOG]    Shutting down server...
                  [2021-11-14 20:37:39.823] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:39.824] [LOG]    Stopping module helper: updatenotification
                  [2021-11-14 20:37:39.826] [ERROR]  Whoops! There was an uncaught exception...
                  [2021-11-14 20:37:39.827] [ERROR]  TypeError: Cannot read property 'close' of undefined
                  [2021-11-14 20:37:39.829] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2021-11-14 20:37:39.830] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    @killing-joke crazy
                    sudo rm -rf node_modules
                    the update didn’t work (write access) almost like someone did sudo npm install at one time.
                    run my script again
                    • K Offline
                      @sdetweil I did the described code
                      and run your script again. The result as followed…
                      pi@raspberrypi:~ $ sudo rm -rf node_modules
                      pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                      Installed Node version: v14.18.1
                      No Node.js upgrade necessary.
                      upgrading from version 2.17.1 to 2.17.1
                      npm ERR! errno -13
                      npm ERR! }
                      npm ERR!
                      npm ERR!
                      npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_23_10_794Z-debug.log
                      up to date in 1.262s
                      added 47 packages from 58 contributors and audited 47 packages in 7.638s
                      added 47 packages from 58 contributors and audited 47 packages in 6.311s
                      added 53 packages from 62 contributors and audited 54 packages in 9.551s
                      added 464 packages from 298 contributors and audited 464 packages in 67.606s
                      pi@raspberrypi:~ $
                      “npm start” gives me the following error code
                      pi@raspberrypi:~ $ npm start
                      npm ERR! code ENOENT
                      npm ERR! syscall open
                      npm ERR! errno -2
                      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                      npm ERR! enoent This is related to npm not being able to find a file.
                      npm ERR! enoent
                      npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_27_04_499Z-debug.log
                      pi@raspberrypi:~ $
                      I don´t have a folder named “.npm” to show the logs. Is it a hidden folder?
                        @killing-joke you need to be IN the MagicMirror folder to do npm start
                          @killing-joke but u missed a step right at the beginning
                          so u didn’t erase the bad folder which is causing all the problems
                          • K Offline
                            @sdetweil said in Error on update to MM 2.11.0:
                            Oh my gosh, same mistake twice a week? Shame on me!!!
                            Did as described before (but IN the correct folder now) :beaming_face_with_smiling_eyes:
                            pi@raspberrypi:~/MagicMirror $ sudo rm -rf node_modulespi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            (23) Failed writing body
                            > core-js@3.15.2 postinstall /home/pi/MagicMirror/node_modules/core-js
                            > node -e "try{require('./postinstall')}catch(e){}"
                            Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                            The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                            > https://opencollective.com/core-js
                            > https://www.patreon.com/zloirock
                            Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                            > electron@13.5.1 postinstall /home/pi/MagicMirror/node_modules/electron
                            > node install.js
                            > magicmirror@2.17.1 install /home/pi/MagicMirror
                            " && cd vendor && npm install --loglevel=error
                            audited 9 packages in 1.163s
                            > magicmirror@2.17.1 postinstall /home/pi/MagicMirror
                            > npm run install-fonts && echo "MagicMirror installation finished successfully!
                            > magicmirror@2.17.1 install-fonts /home/pi/MagicMirror
                            > echo "Installing fonts ...
                            " && cd fonts && npm install --loglevel=error
                            audited 1 package in 1.367s
                            added 294 packages from 243 contributors and audited 918 packages in 94.737s
                            20 packages are looking for funding
                            up to date in 0.782s
                            added 47 packages from 58 contributors and audited 47 packages in 9.188s
                            added 47 packages from 58 contributors and audited 47 packages in 6.346s
                            added 53 packages from 62 contributors and audited 54 packages in 9.937s
                            added 464 packages from 298 contributors and audited 464 packages in 72.299s
                            npm start works fine, but two more questions:
                            • What should I do with the 6 moderate severity vulnerabilities? (last block of the code)
                            • how should I update my MM or the modules in future?
                            Thank you very much for your help / support!!!
                              @killing-joke said in Error on update to MM 2.11.0:
                              nothing you can do… not our code
                              MM run my upgarde script
                              modules, u have to go to each module folder that NEEDS update and do
                              git pull
                              IF the module has a package.json file then also do , IN the module folder,
                              rm -rf node_modules
                              npm install
                                can u send the log file to me via email, same userid at gmail…
                                I want to look at the one error reported
                                  @sdetweil thanks… the error reported was related to timing of part of the script… nothing damaged, and I never knew this error could occur… so fun times!!
                                  • K Offline
                                    @sdetweil glad to help ;-)
