    MMM log files. Where are they hiding?
    4 Posts 2 Posters 2.2k Views 2 Watching
    • G Offline
      GregoryWest
      I am working on making modules work for me. I get error messages usually saying “See log file for details” try as I might I have not been able to find the logfile. Can someone point me in the right direction?
      Greg
        sdetweil @GregoryWest
        @gregorywest if you use pm2, then the pm2 logs command will show the output
        they are stored in the ~/.pm2 folder
        by convention on linux, files/folders that start with . are hidden from normal file listing
        • G Offline
          GregoryWest @sdetweil
          @sdetweil Not using pm2. Should I be using it? What is it?
            @gregorywest pm2 = node process manager (version 2)
            it is used to start processes on boot, and also keep them running, if they fail
            my install script prompts if u want to use it… and I also provide a separate script to enable it if u change your mind.
            I don’t know how to edit the system files for services on all the platforms I use or come in contact with (and don’t WANT to know)
            pm2 is the same on every platform . (including windows)
            the good news is it captures the content from the thing it started
            and lets u examine it live… (and saves it for after the fact)
