    MMM-OpenWeatherForecast Language
    4 Posts 3 Posters 1.1k Views 3 Watching
      bjoern
      Hello,
      how can i change the language to german?
      module: "MMM-OpenWeatherForecast",
          //header: "Vorhersage",
             language: "de",
             extraCurrentConditions: false,
             showHourlyForecast: false,
             showDailyTableHeaderRow: false,
             showSummary: false,
             forecastHeaderText: "",
              colored: true,
      	showCurrentConditions: false,
      language: "de"
      doesn’t work !
        bjoern
        for the days i have found
        label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
        that’s enough!
        • H Offline
          HugoBc
          How you did it?
          I’m trying to put it in french but when i change to “Fr” it’s change nothing…
            sdetweil @bjoern
            @bjoern @HugoBc
            this module uses the base language config option
            (which is lower case)
            this language option is outside the modules list, up in the section with address:
            but, IF you want to change it for just this module,
            you would include
            language:“??”,
            in the modules config section
            module:
            position:
            config:{
                language:"??",
                ...   other config options
