    MMM-CalendarExt2 CSS question. Is there anyway to get daily view to look like week view??
    Scheduled Pinned Locked Moved Solved Development
    5 Posts 3 Posters 3.6k Views 2 Watching
    • WolfieeewolfW
      Wolfieeewolf
      I’m guessing this is a CSS issue. I am trying to get my daily view to be horizontal instead of vertical. I like that the daily view rotates around to always have the current day first. Week view doesn’t do this or I can’t get it to do this.
      It’s more of a painful inconvenience than anything else. I like to see what is coming a few days in advance and the week view doesn’t roll over until the week is done. I know I could use the upcoming views but it again has the same issue. It only goes vertical, not horizontal.
      Any help would be great.
      WolfieeewolfW 1 Reply Last reply Reply Quote 0
      • WolfieeewolfW
        Wolfieeewolf @Wolfieeewolf
        worked it out
        for anyone that wants to do the same. open the CalendarExt2.js and scroll down until you see this
        views: {
          daily: {
            slotSubTitleFormat: "MMMM Do",
            slotTitleFormat: {
              sameDay: '[Today]',
              nextDay: '[Tomorrow]',
              nextWeek: 'dddd',
              lastDay: '[Yesterday]',
              lastWeek: '[Last] ddd',
              sameElse: 'ddd, M/D'
             type: "column",
        change type: “column”, to type: “row”, and problem solved. Might need to do a little bit of css editing to get things to fit but it works for now.
          sdetweil @Wolfieeewolf
          @wolfieeewolf you should be able to set the type in the view object u create in config.js. without changing any code
          • M
            MMRIZE @Wolfieeewolf
            @wolfieeewolf
            Use this code in your module config, not modifying the source.
            • WolfieeewolfW
              Wolfieeewolf @sdetweil
              @sdetweil thanks for that. I didn’t even think of adding it to config.js. I was so busy trying to change it in the custom.css file that I total forgot you can do it in there as well.
              I changed everything back and it works great. It’s a little squashed up so I’m now trying to make it into 2 rows. Not sure how to tackle that one yet.
