Remove fade from weather
@sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
So that is good, just need to figure out the fade on weather. -
@louise false with NO quotes, right?
@sdetweil No quotes
@louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
@louise show me the config.js…
mark out any personal info
with xxxxx don’t change any quotes or braces
/* Magic Mirror Config Sample * * By Michael Teeuw https://michaelteeuw.nl * MIT Licensed. * * For more information on how you can configure this file * see https://docs.magicmirror.builders/getting-started/configuration.html#general * and https://docs.magicmirror.builders/modules/configuration.html */ let config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" port: 8080, basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", locale: "en-US", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 12, units: "imperial", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "https://calendar.google.com/calendar/ical/jxxxxxxxxxxxxpublic/basic.ics" } ] } }, { module: "", position: "" }, { module: "weather", position: "top_right", config: { weatherProvider: "openweathermap", type: "current", location: "Kenosha", locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city apiKey: "xxxxxxxxxx" } }, { module: "weather", position: "top_right", header: "", config: { weatherProvider: "openweathermap", type: "forecast", location: "Kenosha", locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city apiKey: "xxxxxxxxx" } }, { module: "", position: "", config: { feeds: [ { title: "New York Times", url: "" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@louise no fade anywhere in there
in here you have module:“”
if u need to disable a module just add
disabled:true,after the module: line
@sdetweil ok, wasn’t sure how to do that with the modules I didn’t want.
@louise from the doc
if you used my MMM-Config module, all this would be in a form you fill out
https://github.com/sdetweil/MMM-Config -
@sdetweil sure, now I understand what that says, the other day I was reading martian
