    Remove fade from weather
    21 Posts 2 Posters 8.0k Views 2 Watching
    • L Offline
      louise @sdetweil
      @sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
      So that is good, just need to figure out the fade on weather.
        sdetweil @louise
        @louise false with NO quotes, right?
        • L Offline
          louise @sdetweil
          @sdetweil No quotes
          • L Offline
            louise @louise
            @louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
              sdetweil @louise
              @louise show me the config.js…
              mark out any personal info
              with xxxxx don’t change any quotes or braces
              • L Offline
                louise @sdetweil
                /* Magic Mirror Config Sample
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                 * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                	address: "localhost", 	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                language: "en",
                	locale: "en-US",
                	timeFormat: 12,
                	units: "imperial",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "",
                						symbol: "calendar-check",
                						url: "https://calendar.google.com/calendar/ical/jxxxxxxxxxxxxpublic/basic.ics"
                			module: "",
                			position: ""
                			module: "weather",
                				type: "current",
                				locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: "xxxxxxxxxx"
                			module: "weather",
                			header: "",
                				type: "forecast",
                				apiKey: "xxxxxxxxx"
                			module: "",
                			position: "",
                				feeds: [
                						title: "New York Times",
                						url: ""
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                  sdetweil @louise
                  @louise no fade anywhere in there
                  in here you have module:“”
                  if u need to disable a module just add
                  disabled:true,
                  after the module: line
                  • L Offline
                    louise @sdetweil
                    @sdetweil ok, wasn’t sure how to do that with the modules I didn’t want.
                      sdetweil @louise
                      @louise from the doc
                      if you used my MMM-Config module, all this would be in a form you fill out
                      https://github.com/sdetweil/MMM-Config
                      • L Offline
                        louise @sdetweil
                        @sdetweil sure, now I understand what that says, the other day I was reading martian
                          sdetweil @louise
                          @louise said in Remove fade from weather:
                          yep
