    Remove fade from weather
    21 Posts 2 Posters 6.8k Views 2 Watching
    • L Offline
      louise @sdetweil
      @sdetweil I did see that but when I told it false it didn’t go away
        sdetweil @louise
        @louise this is the default
        	timeFormat: 24,
        	units: "metric
        so
        	timeFormat: 12,
        • L Offline
          louise @sdetweil
          @sdetweil yes that is what I have
            sdetweil @louise
            @louise are u doing forecast?
            for the timeFormat in clock, is it inside the
            config:{
            section?
            if a module doesn’t have one, u have to add it
            • L Offline
              louise @sdetweil
              @sdetweil For time, it is in config.js.
              I did look at most of the .js but didn’t see where people were putting their fades in, thinking I could just clear it out.
              I was in the programming screen thinking I could find something but no.
              Well that is weird. Thinking I could start over with config.js for just the time part, copied and pasted the default, saved, restarted and now the time is right.
                sdetweil @louise
                @louise can u show the config block for clock and weather
                from
                module:
                to
                please use the code block
                paste text,
                select text
                push the button above
                • L Offline
                  louise @sdetweil
                  @sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
                  So that is good, just need to figure out the fade on weather.
                    sdetweil @louise
                    @louise false with NO quotes, right?
                    • L Offline
                      louise @sdetweil
                      @sdetweil No quotes
                      • L Offline
                        louise @louise
                        @louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
