    Remove fade from weather
    21 Posts 2 Posters 8.0k Views 2 Watching
    • L Offline
      louise
      Everything I’ve seen is people wanting to put fade in, I want to take it out of the weather. Went to every file and can’t find the place to change it. I was able to do the calendar one but not the weather.
      Also, all of a sudden my clock changed to 24 hr clock. Config.is shows 12 and imperial. Here else would this have shown up I might I have changed accidentally?
        sdetweil @louise
        @louise what is the hour setting up top in config.js
        L S 2 Replies Last reply Reply Quote 0
        • L Offline
          louise @sdetweil
          @sdetweil you mean the time format? I have it at 12
            @sdetweil there is the fade option on the doc for forecast
            • L Offline
              louise @sdetweil
              @sdetweil I did see that but when I told it false it didn’t go away
                sdetweil @louise
                @louise this is the default
                	timeFormat: 24,
                	units: "metric
                so
                	timeFormat: 12,
                • L Offline
                  louise @sdetweil
                  @sdetweil yes that is what I have
                    sdetweil @louise
                    @louise are u doing forecast?
                    for the timeFormat in clock, is it inside the
                    config:{
                    section?
                    if a module doesn’t have one, u have to add it
                    • L Offline
                      louise @sdetweil
                      @sdetweil For time, it is in config.js.
                      I did look at most of the .js but didn’t see where people were putting their fades in, thinking I could just clear it out.
                      I was in the programming screen thinking I could find something but no.
                      Well that is weird. Thinking I could start over with config.js for just the time part, copied and pasted the default, saved, restarted and now the time is right.
                        sdetweil @louise
                        @louise can u show the config block for clock and weather
                        from
                        module:
                        to
                        please use the code block
                        paste text,
                        select text
                        push the button above
                        • L Offline
                          louise @sdetweil
                          @sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
                          So that is good, just need to figure out the fade on weather.
                            sdetweil @louise
                            @louise false with NO quotes, right?
                            • L Offline
                              louise @sdetweil
                              @sdetweil No quotes
                              • L Offline
                                louise @louise
                                @louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
                                  sdetweil @louise
                                  @louise show me the config.js…
                                  mark out any personal info
                                  with xxxxx don’t change any quotes or braces
                                  • L Offline
                                    louise @sdetweil
                                    /* Magic Mirror Config Sample
                                     * By Michael Teeuw https://michaelteeuw.nl
                                     * MIT Licensed.
                                     * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                                     * and https://docs.magicmirror.builders/modules/configuration.html
                                    let config = {
                                    	address: "localhost", 	// Address to listen on, can be:
                                    	port: 8080,
                                    	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                    language: "en",
                                    	locale: "en-US",
                                    	timeFormat: 12,
                                    	units: "imperial",
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                    			header: "",
                                    						symbol: "calendar-check",
                                    						url: "https://calendar.google.com/calendar/ical/jxxxxxxxxxxxxpublic/basic.ics"
                                    			module: "",
                                    			position: ""
                                    			module: "weather",
                                    				type: "current",
                                    				locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    				apiKey: "xxxxxxxxxx"
                                    			module: "weather",
                                    			header: "",
                                    				type: "forecast",
                                    				apiKey: "xxxxxxxxx"
                                    			module: "",
                                    			position: "",
                                    				feeds: [
                                    						title: "New York Times",
                                    						url: ""
                                    				showSourceTitle: true,
                                    				showPublishDate: true,
                                    				broadcastNewsFeeds: true,
                                    				broadcastNewsUpdates: true
                                      sdetweil @louise
                                      @louise no fade anywhere in there
                                      in here you have module:“”
                                      if u need to disable a module just add
                                      disabled:true,
                                      after the module: line
                                      • L Offline
                                        louise @sdetweil
                                        @sdetweil ok, wasn’t sure how to do that with the modules I didn’t want.
                                          sdetweil @louise
                                          @louise from the doc
                                          if you used my MMM-Config module, all this would be in a form you fill out
                                          https://github.com/sdetweil/MMM-Config
                                          • L Offline
                                            louise @sdetweil
                                            @sdetweil sure, now I understand what that says, the other day I was reading martian
