    Remove fade from weather
    21 Posts 2 Posters 8.2k Views 2 Watching
    • L
      louise @sdetweil
      @sdetweil I did see that but when I told it false it didn’t go away
        sdetweil @louise
        @louise this is the default
        	timeFormat: 24,
        	units: "metric
        so
        	timeFormat: 12,
        • L
          louise @sdetweil
          @sdetweil yes that is what I have
            sdetweil @louise
            @louise are u doing forecast?
            for the timeFormat in clock, is it inside the
            config:{
            section?
            if a module doesn’t have one, u have to add it
            • L
              louise @sdetweil
              @sdetweil For time, it is in config.js.
              I did look at most of the .js but didn’t see where people were putting their fades in, thinking I could just clear it out.
              I was in the programming screen thinking I could find something but no.
              Well that is weird. Thinking I could start over with config.js for just the time part, copied and pasted the default, saved, restarted and now the time is right.
                sdetweil @louise
                @louise can u show the config block for clock and weather
                from
                module:
                to
                please use the code block
                paste text,
                select text
                push the button above
                • L
                  louise @sdetweil
                  @sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
                  So that is good, just need to figure out the fade on weather.
                    sdetweil @louise
                    @louise false with NO quotes, right?
                    • L
                      louise @sdetweil
                      @sdetweil No quotes
                      • L
                        louise @louise
                        @louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
                          sdetweil @louise
                          @louise show me the config.js…
                          mark out any personal info
                          with xxxxx don’t change any quotes or braces
                          • L
                            louise @sdetweil
                            /* Magic Mirror Config Sample
                             * By Michael Teeuw https://michaelteeuw.nl
                             * MIT Licensed.
                             * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                             * and https://docs.magicmirror.builders/modules/configuration.html
                            let config = {
                            	address: "localhost", 	// Address to listen on, can be:
                            	port: 8080,
                            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                            language: "en",
                            	locale: "en-US",
                            	timeFormat: 12,
                            	units: "imperial",
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_left"
                            			header: "",
                            						symbol: "calendar-check",
                            						url: "https://calendar.google.com/calendar/ical/jxxxxxxxxxxxxpublic/basic.ics"
                            			module: "",
                            			position: ""
                            			module: "weather",
                            				type: "current",
                            				locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            				apiKey: "xxxxxxxxxx"
                            			module: "weather",
                            			header: "",
                            				type: "forecast",
                            				apiKey: "xxxxxxxxx"
                            			module: "",
                            			position: "",
                            				feeds: [
                            						title: "New York Times",
                            						url: ""
                            				showSourceTitle: true,
                            				showPublishDate: true,
                            				broadcastNewsFeeds: true,
                            				broadcastNewsUpdates: true
                              sdetweil @louise
                              @louise no fade anywhere in there
                              in here you have module:“”
                              if u need to disable a module just add
                              disabled:true,
                              after the module: line
                              • L
                                louise @sdetweil
                                @sdetweil ok, wasn’t sure how to do that with the modules I didn’t want.
                                  sdetweil @louise
                                  @louise from the doc
                                  if you used my MMM-Config module, all this would be in a form you fill out
                                  https://github.com/sdetweil/MMM-Config
                                  • L
                                    louise @sdetweil
                                    @sdetweil sure, now I understand what that says, the other day I was reading martian
                                      sdetweil @louise
                                      @louise said in Remove fade from weather:
                                      yep
