    Remove fade from weather
    21 Posts 2 Posters 8.2k Views 2 Watching
      sdetweil @louise
      @louise are u doing forecast?
      for the timeFormat in clock, is it inside the
      config:{
      section?
      if a module doesn’t have one, u have to add it
      • L
        louise @sdetweil
        @sdetweil For time, it is in config.js.
        I did look at most of the .js but didn’t see where people were putting their fades in, thinking I could just clear it out.
        I was in the programming screen thinking I could find something but no.
        Well that is weird. Thinking I could start over with config.js for just the time part, copied and pasted the default, saved, restarted and now the time is right.
          sdetweil @louise
          @louise can u show the config block for clock and weather
          from
          module:
          to
          please use the code block
          paste text,
          select text
          push the button above
          • L
            louise @sdetweil
            @sdetweil don’t know if u saw the edited version of last post, but it is working with time format 12.
            So that is good, just need to figure out the fade on weather.
              sdetweil @louise
              @louise false with NO quotes, right?
              • L
                louise @sdetweil
                @sdetweil No quotes
                • L
                  louise @louise
                  @louise I rebooted, when it came up the time on top was military time, appointments regular time. Looked at the config.js and it showed 24. Changed it to 12 again, now time on top is military and the appointments are military.
                    sdetweil @louise
                    @louise show me the config.js…
                    mark out any personal info
                    with xxxxx don’t change any quotes or braces
                    • L
                      louise @sdetweil
                      /* Magic Mirror Config Sample
                       * By Michael Teeuw https://michaelteeuw.nl
                       * MIT Licensed.
                       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                       * and https://docs.magicmirror.builders/modules/configuration.html
                      let config = {
                      	address: "localhost", 	// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                      language: "en",
                      	locale: "en-US",
                      	timeFormat: 12,
                      	units: "imperial",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                      			header: "",
                      						symbol: "calendar-check",
                      						url: "https://calendar.google.com/calendar/ical/jxxxxxxxxxxxxpublic/basic.ics"
                      			module: "",
                      			position: ""
                      			module: "weather",
                      				type: "current",
                      				locationID: "5258393", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      				apiKey: "xxxxxxxxxx"
                      			module: "weather",
                      			header: "",
                      				type: "forecast",
                      				apiKey: "xxxxxxxxx"
                      			module: "",
                      			position: "",
                      				feeds: [
                      						title: "New York Times",
                      						url: ""
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                        sdetweil @louise
                        @louise no fade anywhere in there
                        in here you have module:“”
                        if u need to disable a module just add
                        disabled:true,
                        after the module: line
                        • L
                          louise @sdetweil
                          @sdetweil ok, wasn’t sure how to do that with the modules I didn’t want.
                            sdetweil @louise
                            @louise from the doc
                            if you used my MMM-Config module, all this would be in a form you fill out
                            https://github.com/sdetweil/MMM-Config
                            • L
                              louise @sdetweil
                              @sdetweil sure, now I understand what that says, the other day I was reading martian
                                sdetweil @louise
                                @louise said in Remove fade from weather:
                                yep
