    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 60.6k Views 4 Watching
      sdetweil @pastormingle
      @pastormingle yes and then start MagicMirror
      if u still get a black screen the check again…
      • P Offline
        pastormingle @pastormingle
        @pastormingle ```
        pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ pm2 logs --lines=50 MagicMirror
        [TAILING] Tailing last 50 lines for [MagicMirror] process (change the value with --lines option)
        /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
        0|MagicMir | -
        0|MagicMir | [14.12.2021 16:02.14.185] [ERROR] App threw an error during load
        0|MagicMir | [14.12.2021 16:02.14.187] [ERROR] Error: Cannot find module ‘valid-url’
        0|MagicMir | Require stack:
        0|MagicMir | - /home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js
        0|MagicMir | - /home/pi/MagicMirror/js/app.js
        0|MagicMir | - /home/pi/MagicMirror/js/electron.js
        0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        0|MagicMir | -
        0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
        0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
        0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        0|MagicMir | at Module._load (internal/modules/cjs/loader.js:848:27)
        0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
        0|MagicMir | at Module.require (internal/modules/cjs/loader.js:1032:19)
        0|MagicMir | at require (internal/modules/cjs/helpers.js:72:18)
        0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
        0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1152:30)
        0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
        0|MagicMir | [14.12.2021 16:02.14.197] [ERROR] Whoops! There was an uncaught exception…
        0|MagicMir | [14.12.2021 16:02.14.203] [ERROR] Error: Cannot find module ‘valid-url’
        0|MagicMir | -
        0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10) {
        0|MagicMir | code: ‘MODULE_NOT_FOUND’,
        0|MagicMir | requireStack: [
        0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js’,
        0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
        0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
        0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        0|MagicMir | undefined
          @pastormingle that message is from
          16:02.14.187
          so not recently
          pm2 stop all
          pm2 flush
          pm2 start 0
          wait
          pm2 stop all
          pm2 logs…
          • P Offline
            pastormingle @sdetweil
            @sdetweil ```
            0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
            0|MagicMir | > magicmirror@2.16.0 start /home/pi/MagicMirror
            0|MagicMir | > ./run-start.sh $1
            0|MagicMir |
            0|MagicMir | [14.12.2021 16:56.24.531] [LOG] Starting MagicMirror: v2.16.0
            0|MagicMir | [14.12.2021 16:56.24.538] [LOG] Loading config …
            0|MagicMir | [14.12.2021 16:56.24.545] [LOG] Loading module helpers …
            0|MagicMir | [14.12.2021 16:56.24.547] [LOG] No helper found for module: alert.
            0|MagicMir | [14.12.2021 16:56.25.838] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.25.840] [LOG] Module helper loaded: MMM-GoogleTasks
            0|MagicMir | [14.12.2021 16:56.25.978] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.25.978] [LOG] Module helper loaded: updatenotification
            0|MagicMir | [14.12.2021 16:56.25.980] [LOG] No helper found for module: weather.
            0|MagicMir | [14.12.2021 16:56.25.981] [LOG] No helper found for module: clock.
            0|MagicMir | [14.12.2021 16:56.25.982] [LOG] No helper found for module: MMM-Carousel.
            0|MagicMir | [14.12.2021 16:56.25.983] [LOG] No helper found for module: MMM-RAIN-MAP.
            0|MagicMir | [14.12.2021 16:56.26.361] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.26.362] [LOG] Module helper loaded: MMM-PaprikaMenu
            0|MagicMir | [14.12.2021 16:56.26.462] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.26.463] [LOG] Module helper loaded: calendar
            0|MagicMir | [14.12.2021 16:56.26.464] [LOG] No helper found for module: calendar_monthly.
            0|MagicMir | [14.12.2021 16:56.26.465] [LOG] No helper found for module: helloworld.
            0|MagicMir | [14.12.2021 16:56.26.804] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.26.805] [LOG] Module helper loaded: MMM-CalendarExt
            0|MagicMir | [14.12.2021 16:56.26.808] [LOG] Initializing new module helper …
            0|MagicMir | [14.12.2021 16:56.26.809] [LOG] Module helper loaded: MMM-ip
            0|MagicMir | [14.12.2021 16:56.26.809] [LOG] All module helpers loaded.
            0|MagicMir | [14.12.2021 16:56.26.921] [LOG] Starting server on port 8080 …
            0|MagicMir | [14.12.2021 16:56.26.936] [LOG] Server started …
            0|MagicMir | [14.12.2021 16:56.26.937] [LOG] Connecting socket for: MMM-GoogleTasks
            0|MagicMir | [14.12.2021 16:56.26.938] [LOG] Starting node helper for: MMM-GoogleTasks
            0|MagicMir | [14.12.2021 16:56.26.939] [LOG] Connecting socket for: updatenotification
            0|MagicMir | [14.12.2021 16:56.26.940] [LOG] Connecting socket for: MMM-PaprikaMenu
            0|MagicMir | [14.12.2021 16:56.26.940] [LOG] Starting node_helper for module [MMM-PaprikaMenu]
            0|MagicMir | [14.12.2021 16:56.26.941] [LOG] Connecting socket for: calendar
            0|MagicMir | [14.12.2021 16:56.26.942] [LOG] Starting node helper for: calendar
            0|MagicMir | [14.12.2021 16:56.26.943] [LOG] Connecting socket for: MMM-CalendarExt
            0|MagicMir | [14.12.2021 16:56.26.944] [LOG] Connecting socket for: MMM-ip
            0|MagicMir | [14.12.2021 16:56.26.945] [LOG] Starting module helper: MMM-ip
            0|MagicMir | [14.12.2021 16:56.26.945] [LOG] Available network interface types: lo, wlan0
            0|MagicMir | [14.12.2021 16:56.26.946] [LOG] Sockets connected & modules started …
            0|MagicMir | [14.12.2021 16:56.27.226] [LOG] Launching application.
            0|MagicMir | [14.12.2021 16:56.29.659] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-34995d14cf5e15efc8bd68f680c508e3/basic.ics - Interval: 50000
            0|MagicMir | [14.12.2021 16:56.29.715] [LOG] Create new calendarfetcher for url: http://outlook.office365.com/owa/calendar/f2033a09d6504d21833241fb44df8c3c@dxc.com/a53b201c85bf4825a9290ce3ec96a8b2457585490405428856/calendar.ics - Interval: 50000
            0|MagicMir | [14.12.2021 16:56.29.857] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastorcharlotte%40htni.org/private-448bd9e0646a570df025700cdd3f7155/basic.ics - Interval: 50000
            0|MagicMir | [14.12.2021 16:56.30.213] [INFO] Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [14.12.2021 16:56.30.556] [INFO] Calendar-Fetcher: Broadcasting 2 events.
            0|MagicMir | [14.12.2021 16:56.30.678] [LOG] MMM-PaprikaMenu: Week starts: 2021-12-13, next week starts: 2021-12-20
            0|MagicMir | [14.12.2021 16:56.30.699] [LOG] MMM-PaprikaMenu: Waiting on 0 Paprika recipe calls.
            0|MagicMir | [14.12.2021 16:56.30.700] [LOG] MMM-PaprikaMenu: All recipe queries returned.
            0|MagicMir | [14.12.2021 16:56.39.598] [INFO] Calendar-Fetcher: Broadcasting 10 events.
              @pastormingle see no errors there
              let’s stop using pm2 during debug
              pm2 stop all
              cd ~/MagicMirror
              npm start &>somefile.txt
              wait til black screen
              ctrl-q
              the examine the contents of somefile.txt
              • P Offline
                @sdetweil npm ERR! missing script: start
                npm ERR! /home/pi/.npm/_logs/2021-12-14T23_05_21_577Z-debug.log
                • P Offline
                  @pastormingle ```
                  ./run-start.sh $1
                  [14.12.2021 17:06.53.311] [LOG] Starting MagicMirror: v2.16.0
                  [14.12.2021 17:06.53.315] [LOG] Loading config …
                  [14.12.2021 17:06.53.322] [LOG] Loading module helpers …
                  [14.12.2021 17:06.53.324] [LOG] No helper found for module: alert.
                  [14.12.2021 17:06.54.616] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.54.618] [LOG] Module helper loaded: MMM-GoogleTasks
                  [14.12.2021 17:06.54.753] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.54.753] [LOG] Module helper loaded: updatenotification
                  [14.12.2021 17:06.54.754] [LOG] No helper found for module: weather.
                  [14.12.2021 17:06.54.755] [LOG] No helper found for module: clock.
                  [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-Carousel.
                  [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-RAIN-MAP.
                  [14.12.2021 17:06.55.135] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.55.136] [LOG] Module helper loaded: MMM-PaprikaMenu
                  [14.12.2021 17:06.55.236] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.55.237] [LOG] Module helper loaded: calendar
                  [14.12.2021 17:06.55.238] [LOG] No helper found for module: calendar_monthly.
                  [14.12.2021 17:06.55.238] [LOG] No helper found for module: helloworld.
                  [14.12.2021 17:06.55.577] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.55.577] [LOG] Module helper loaded: MMM-CalendarExt
                  [14.12.2021 17:06.55.580] [LOG] Initializing new module helper …
                  [14.12.2021 17:06.55.581] [LOG] Module helper loaded: MMM-ip
                  [14.12.2021 17:06.55.581] [LOG] All module helpers loaded.
                  [14.12.2021 17:06.55.694] [LOG] Starting server on port 8080 …
                  [14.12.2021 17:06.55.708] [LOG] Server started …
                  [14.12.2021 17:06.55.709] [LOG] Connecting socket for: MMM-GoogleTasks
                  [14.12.2021 17:06.55.710] [LOG] Starting node helper for: MMM-GoogleTasks
                  [14.12.2021 17:06.55.710] [LOG] Connecting socket for: updatenotification
                  [14.12.2021 17:06.55.711] [LOG] Connecting socket for: MMM-PaprikaMenu
                  [14.12.2021 17:06.55.712] [LOG] Starting node_helper for module [MMM-PaprikaMenu]
                  [14.12.2021 17:06.55.712] [LOG] Connecting socket for: calendar
                  [14.12.2021 17:06.55.713] [LOG] Starting node helper for: calendar
                  [14.12.2021 17:06.55.713] [LOG] Connecting socket for: MMM-CalendarExt
                  [14.12.2021 17:06.55.714] [LOG] Connecting socket for: MMM-ip
                  [14.12.2021 17:06.55.715] [LOG] Starting module helper: MMM-ip
                  [14.12.2021 17:06.55.715] [LOG] Available network interface types: lo, wlan0
                  [14.12.2021 17:06.55.716] [LOG] Sockets connected & modules started …
                  [14.12.2021 17:06.55.995] [LOG] Launching application.
                  [14.12.2021 17:06.58.663] [LOG] Create new calendarfetcher for url: http://outlook.office365.com/owa/calendar/f2033a09d654825a9290ce3ec9657585490405428856/calendar.ics - Interval: 50000
                  [14.12.2021 17:06.58.696] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-34995d14cf5e15efc8bd68f680c508e3/basic.ics - Interval: 50000
                  [14.12.2021 17:06.58.766] [LOG] TASKS SERVICE ALREADY RUNNING, DONT NEED TO AUTHENTICATE AGAIN
                  [14.12.2021 17:06.58.884] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastorcharlotte%40htni.org/private-448bd900cdd3f7155/basic.ics - Interval: 50000
                  [14.12.2021 17:06.59.198] [INFO] Calendar-Fetcher: Broadcasting 6 events.
                  [14.12.2021 17:06.59.540] [INFO] Calendar-Fetcher: Broadcasting 2 events.
                  [14.12.2021 17:06.59.674] [LOG] MMM-PaprikaMenu: Week starts: 2021-12-13, next week starts: 2021-12-20
                  [14.12.2021 17:06.59.696] [LOG] MMM-PaprikaMenu: Waiting on 0 Paprika recipe calls.
                  [14.12.2021 17:06.59.697] [LOG] MMM-PaprikaMenu: All recipe queries returned.
                  [14.12.2021 17:07.02.676] [LOG] Shutting down server…
                  [14.12.2021 17:07.02.678] [LOG] Stopping module helper: MMM-GoogleTasks
                  [14.12.2021 17:07.02.679] [LOG] Stopping module helper: updatenotification
                  [14.12.2021 17:07.02.680] [LOG] Stopping module helper: MMM-PaprikaMenu
                  [14.12.2021 17:07.02.682] [LOG] Stopping module helper: calendar
                  [14.12.2021 17:07.02.683] [LOG] Stopping module helper: MMM-CalendarExt
                  [14.12.2021 17:07.02.684] [LOG] Stopping module helper: MMM-ip
                  • P Offline
                    @pastormingle no errors but still not displaying the calendar…
                      @pastormingle is the screen black?
                      no. then the fix from before is ok.
                      I don’t know anything about that module itself
                      • P Offline
                        @sdetweil no it’s not blacked out it is displaying the other module like the clock but nothing on the calendar…
                          @pastormingle I would open another topic here on calendarext not showing as this topic says carousel
                          • P Offline
                            @sdetweil Thanks Sam… It seems to be an issue with mmm-google task and the order you call the calendarext from mmm-carousel. It needs to be first on the list if you are using a slide mode on the carousel… Not sure yet why the mmm-googletask is causing it to fail… Thanks for all the help Sam… I’m adding this just in case someone else comes along with the same issue…
                              @pastormingle just for clarity
                              "It needs to be first on the list "
                              which module needs to be 1st? (it)
                              • P Offline
                                @sdetweil the “MMM-CalendarExt” needs to be first…
                                • P Offline
                                  pastormingle
                                  I am still having issues with my weather app using it with carousel. When it rotates back to weather I only get a thumbnail of the radar… Do you know of any fix to that?
                                    @pastormingle what weather module?
                                    I do not know the answer. don’t use carousel
                                    • 5 / 5
