    Error in DNews (copy of PNews)
    5 Posts 3 Posters 902 Views 3 Watching
      Johans
      Re: MMM-Pnews
      Hi, long time ago you made this DNews module so I could see some local news. (it was copy from your PNews module.
      Now I re-installed the mirror after upgraded to an RPI4-4GB and this module gives me an error.
      Would you mind have a look at this.
      I would like to see this RSS feed on my mirror again :
      http://www.nieuwsblad.be/rss/section/c1e533dc-ff1c-40fc-b48c-77ee686d54d4?intro=1",
      I installed the PNews but unfortunately it works with an API key (which I have) but my news source isn’t available.
      I have the MMM-NewsFeed to display the regular new but this module can not have 2 instances. So I would like to continue using the DNews module next to it (as it was in the past)
      Hope you can help.
      this is the error:
      [04.12.2021 10:42.09.832] [ERROR] Whoops! There was an uncaught exception...
      [04.12.2021 10:42.09.837] [ERROR] Error: Cannot find module 'xml2js'
      Require stack:
      /home/pi/MagicMirror/modules/MMM-DNews/node_helper.js
      /home/pi/MagicMirror/js/app.js
      /home/pi/MagicMirror/js/electron.js
      /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
      at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      at Module._load (internal/modules/cjs/loader.js:732:27)
      at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
      at Module.require (internal/modules/cjs/loader.js:959:19)
      at require (internal/modules/cjs/helpers.js:88:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-DNews/node_helper.js:9:16)
      at Module._compile (internal/modules/cjs/loader.js:1078:30)
      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      at Module.load (internal/modules/cjs/loader.js:935:32)
      at Module._load (internal/modules/cjs/loader.js:776:14)
      at loadModule (/home/pi/MagicMirror/js/app.js:127:19)
      at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
      at /home/pi/MagicMirror/js/app.js:167:6
      at loadModule (/home/pi/MagicMirror/js/app.js:146:4)
      at loadModule (/home/pi/MagicMirror/js/app.js:146:4) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
      '/home/pi/MagicMirror/modules/MMM-DNews/node_helper.js',
      '/home/pi/MagicMirror/js/app.js',
      '/home/pi/MagicMirror/js/electron.js',
      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      undefined
      [04.12.2021 10:42.09.839] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      mumblebajM cowboysdudeC 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @Johans
        @johans Have a look at this thread.
        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/11
        Your error Error: Cannot find module 'xml2js'
          Johans @mumblebaj
          @mumblebaj said in Error in DNews (copy of PNews):
          Thank you - now it’s working again.
          • cowboysdudeC Offline
            cowboysdude Module Developer @Johans
            @johans yes… npm install…very important. I’ll have to look at the repository to make sure I put that in the instructions. If I didn’t I apologize :)
              Johans @cowboysdude
              @cowboysdude - thanks
