    Any Horoscope modules that work?
    8 Posts 2 Posters 2.2k Views 2 Watching
    • P Offline
      pingywon
      Both:
      https://github.com/cowboysdude/MMM-Astrology
      and
      https://github.com/morozgrafix/MMM-horoscope
      are very broken.
      Can anyone fix them or is there any other Astrology modules that actually do work?
      I had an old MM running for years with old software and the Astrology one worked. I wiped everything and updated to the latest and greatest and now neither one will work and im not sure why.
      HALP! :)
        sdetweil @pingywon
        @pingywon probably this
        • P Offline
          pingywon @sdetweil
          @sdetweil This helped a lot, I was still having some issues, but I was able to get MMM-Astrology working correctly.
          Thank you once again for the help.
          • P Offline
            pingywon @pingywon
            @sdetweil … I spoke too soon. I had MMM-Astrology working just fine and then started playing with a bunch of other stuff and now its broken…either I broke it or it just happen to break 4 days after I got it working. Can anyone help or confirm?
            Here is my config block for it. look ok?
                        module: 'MMM-Astrology',
                        disabled: false,
                        position: 'bottom_right',
                            starSigns: ["gemini"],
                            hScope: "daily",
                            tcolor: "white"
            Any help would be great…the Gemini in my house NEEDS her horiscope. :)
              sdetweil @pingywon
              @pingywon what does broken mean. a little more info please
              P 2 Replies Last reply Reply Quote 0
              • P Offline
                pingywon @sdetweil
                @sdetweil the module loads properly but the horoscope just shows
                instead of the text of the actual horoscope
                I removed the whole module and “re-cloned” it but its still just showing [] instead of text
                • P Offline
                  pingywon @sdetweil
                  @sdetweil said in Any Horoscope modules that work?:
                  @sdetweil Or anyone… can someone confirm the module is still working? or is it broken for everyone?
                    sdetweil @pingywon
                    @pingywon i got the URL and tested
                    “date”: “2021-12-22”,
                    “horoscope”: “[]”, // api returns empty list
                    “sunsign”: “cancer”
                    I opened and issue
                    https://github.com/cowboysdude/MMM-Astrology/issues/18
