    moment js not found on windows
    3 Posts 2 Posters 561 Views 2 Watching
    • C Offline
      ChaosEncoded
      Wasn’t sure what to tag this as so will start with troubleshooting and adjust if necessary.
      I recently cloned the repo to my windows machine so I can use it as a base for when I’m debugging things like enhancing current modules I like or trying my hand at making my own; but I’m having an issue getting it to load.
      Every time I start the process and the electron app starts the screen is blank. when I open the console here I see that it can’t find the moment library in clock js.
      Going down that rabbit hole I commented out the module and restarted the app, only to find the same error for a different module. I continued doing this until I was left with only modules that didn’t use moment.
      I tried running npm i -g moment as well as installing moment in the magic mirror directory but this didn’t fix the issue.
      Has anyone else run into this? I couldn’t find anything on the repo or in this forum about it.
      Any help at all would be appreciated.
        sdetweil @ChaosEncoded
        @chaosencoded on windows u have extra steps
        npm install in the vendors folder
        and
        npm install in the fonts folder
        the stock install process doesn’t complete on windows
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          ChaosEncoded @sdetweil
          @sdetweil I can’t believe it was that easy. Thanks!
