    error config;JS magic mirror, awesome Alexa install fails
    4 Posts 2 Posters 727 Views 2 Watching
    • H
      hamzalaq
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node-pre-gyp’ Require stack: - /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js - /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      S 2 Replies Last reply Reply Quote 1
        sdetweil @hamzalaq
        @hamzalaq yes, we discussed in GitHub issue.
        I will try to look at this later, but the author is not around anymore, so who knows…
          sdetweil @hamzalaq
          @hamzalaq i rechecked the script I made from the wiki instructions (with one addition they didn’t document) and it installs Awesome-Alexa so that it works. (on buster or bullseye)
          https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
            also note Amazon has tightened limits on what API can do
            see
            https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
            now unable to control devices
