    Questions about update
    19 Posts 5 Posters 8.0k Views 6 Watching
      selyjohns
      Hello,
      Is it possible to know when the next update (from develop branch) will be merged on the master branch ?
      When I use the git status command, here’s the result
      pi@MagicMirror:~/MagicMirror $ git status
      Sur la branche master
      Votre branche est à jour avec 'origin/master'.
      Fichiers non suivis:
        (utilisez "git add <fichier>..." pour inclure dans ce qui sera validé)
              css/custom.css_backup
              modules/default/compliments/compliments.js_backup
              modules/default/compliments/compliments.json
              modules/default/compliments/compliments.json_backup
      aucune modification ajoutée à la validation mais des fichiers non suivis sont présents (utilisez "git add" pour les suivre)
      Of course, I want to keep my backup files. Does I need to use git add to preserve my file ?
      Thank you.
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @selyjohns
        @selyjohns a new mm release is done every calendar quarter ( every 3 months).(Jan, Apr, July, Oct)
        the next is Jan 1
        no you do not need to use git to save your files. just copy them someplace outside the mm folder as a backup
        the ones list are in the untracted section, meaning git sees them but is not managing them
        for update, you can use my update script
        see
        • BKeyportB Offline
          BKeyport Module Developer @selyjohns
          I have a couple of tricks I use to preserve my modifications, even across a total system rebuild.
          1. config.js & custom.css is symlinked to my backup directory.
          2. my config.js is commented on where I can get my modules, and any forum posts which apply to help get them running (like how to add back required node.js modules that aren’t in MagicMirror core anymore)
          3. any and all non-core modules that have changes that would be overwritten by an update by the author are forked to my own github. if I update a core module, I would symlink the modified file to my backup directory.
          4. I left myself instructions in the backup directory on how to reset things I can’t/shouldn’t backup as of present (crontab, samba, config.txt, how to set up fresh SD card, hostname, etc) (config.txt you’ll see in the backup, but you shouldn’t just copy that back as new installs may be different in that file, use it to compare and add your changes)
          5. My backup directory is thrown to github in a private repository nightly using this (censored) script.
          #!/bin/bash
          d=$(date +%Y-%m-%d)
          cd ~/<directory>
          cp /boot/config.txt config.txt.backup
          cp /etc/samba/smb.conf smb.conf.backup
          rm core
          git add *
          git commit -m "Nightly Backup"+$d --all
          git push https://BKeyport:<token>@github.com/BKeyport/<directory>.git
          In my crontab -e:
            0 0 * * * /home/pi/<directory>/backup.sh
           30 * * * * pm2 restart omx
          (Run the backup script at midnight, and restart my camera cutout at 30 minutes past the hour respectively - OMX is a bit of a pain, working on better)
          I would love to see user modules be in their own directory so I could just wholesale symlink that directory to my backup system, but, eh…
          howtos :
          github (cheat sheet: https://education.github.com/git-cheat-sheet-education.pdf)
          symlinks: (https://www.freecodecamp.org/news/symlink-tutorial-in-linux-how-to-create-and-remove-a-symbolic-link/)
          cron: https://ostechnix.com/a-beginners-guide-to-cron-jobs/
          bugsounetB S 2 Replies Last reply Reply Quote 2
          • bugsounetB Offline
            bugsounet Banned @BKeyport
            What a lot of effort… Do you do the same with your personal computer?
            Wow… :'(
            • BKeyportB Offline
              BKeyport Module Developer @bugsounet
              @bugsounet No effort at all, once it’s set up. 😃
              Takes the typical reload time of 5 hours down to an hour, including burning a new SD. About 10 minutes of setup to restart a messed up mirror.
              bugsounetB 1 Reply Last reply Reply Quote 0
                😂 😂 MM update every 6 month… System update every month or less… Npm package update every month… Modules every month… Or not maintened… Yeah really I am 😂 😂 😂
                So I think you use very old system… And you are a module developer! 😂 😂
                Its very poor to read this from a developer
                Sorry., it’s not like this that you will learn beginer
                Sample with your Old save… Just try to laun an update… It will take a lot of time! 😂 (apt-get update & & apt-get upgrade)
                You will says… Yes but it’s not necessary… So don’t do any update on your computer too!
                Impressive :)
                BKeyportB karsten13K 2 Replies Last reply Reply Quote -2
                • BKeyportB Offline
                  @bugsounet SD Card failed every month for a while. Got tired of having to rebuild from scratch and taking time to have to find how to do half the crap I do, because my memory is swiss cheese when it comes to CSS in particular. :)
                  Admittedly, my mirror is on a pi that does more than just the mirror, one of my files updates every couple of days. I do this to make it so I don’t have to think when I make major changes.
                  It’s a suggestion. Leave it at that, eh?
                  • karsten13K Offline
                    karsten13 @bugsounet
                    @bugsounet said in Questions about update:
                    is there a difference between running an old system and running a public forum without https?
                    bugsounetB 1 Reply Last reply Reply Quote 3
                      bugsounet Banned @karsten13
                      @karsten13 Make all things like me after you can talk ;)
                      1 Reply Last reply Reply Quote -2
                        selyjohns
                        Yes, it’s a good solution that works great once installed.
                        To build my MM, I have made some modifications on everywhere to obtain the result I want, and if i had to rebuild all it will take a lot of time because it’s impossible to remember everything (like modifications on boot.txt)
                        And I agree about SD Card. It’s a really difficult to preserve it. So the solution is to externalize backups.
                        I’ve a NAS server with NFS possibilities. I think I’ll build a script to save every night for example a backup of config.js, custom.css, compliments.js and boot.txt (to compare in case of rebuild).
                        But, i’m also agree is represent a lot of work for a system that not modify every day. A big backup on every major modification is sufficient.
                        Have a nice day.
                          sdetweil @BKeyport
                          @bkeyport thanks. my backup doesn’t copy custom.css… doah
                            selyjohns
                            Just scripted what I want. Not externalized for the moment. Just a simple copy of modules folder and personnalized files.
                            Sorry if it’s not perfect, but i’m not a developer :)
                            #!/bin/bash
                            #BACKUP FOLDER
                            mkdir -p /var/backups/MM
                            cd /var/backups/MM
                            #OLD BACKUPS PURGE
                            echo "--- PURGE TASK ---"
                            echo "Check for existing backups..."
                            nb_save=$(ls | wc -l)
                            if [ $nb_save -gt 4 ]
                            then
                                    oldest_folder=$(ls -lt | tail -1 | cut -d " " -f10)
                                    echo "Limit of 5 backups reach. Deleting of the oldest one : $oldest_folder"
                                    rm -rf "$oldest_folder"
                                    echo "DELETED."
                            else
                                    echo "Limit of 5 backups doesn't reach, skip to backup task."
                            fi
                            #BACKUP
                            echo "--- BACKUP TASK ---"
                            echo "Starting..."
                            d=$(date +%Y-%m-%d_%H:%M)
                            mkdir -p $d
                            cd $d
                            cp /home/pi/MagicMirror/config/config.js config.js
                            cp /home/pi/MagicMirror/css/custom.css custom.css
                            cp /home/pi/MagicMirror/modules/default/compliments/compliments.json compliments.json
                            mkdir -p modules
                            cp -R /home/pi/MagicMirror/modules/ .
                            echo "DONE. CURRENT LIST OF BACKUPS :"
                            cd ..
                            ls -A1
                              sdetweil @selyjohns
                              @selyjohns cool… mine saves the list of modules (git url) and config.js to a local git repo with a tag with the date
                              other files (compliments.json) … cool… (any reason u didn’t put those in config.js?, u have to restart to use an updated file too)
                                selyjohns
                                @sdetweil said in Questions about update:
                                Perfect :) Git seem to be a good solution. For next evolution haha
                                For the json, it’s because i’ve define a lot of compliments and it’s more clean on external json that in config.js
                                  sdetweil @selyjohns
                                  @selyjohns you can look at my backup script for creating the tag from the date/time
                                    selyjohns @sdetweil
                                    @sdetweil Perfect ! Thanks :)
                                    • BKeyportB Offline
                                      @sdetweil Whoops. that’s 90% of my mirror! Without CSS copied it becomes a big mess quick. Only modules I don’t have custom CSS for is MMM-Multimonth and MMM-Worldclock (Hmm, wonder why? 😀)
                                        sdetweil @BKeyport
                                        @bkeyport fixed
                                        • BKeyportB Offline
                                          @sdetweil Slick script by the way, I gotta steal a few things from it. :)
