    Character set for news fed text '
    12 Posts 4 Posters 3.5k Views 4 Watching
    • H Offline
      huskernut0878
      Searched for this but I’m too new to know if I found anything. My news feed from fox news will not display an apostrophe character. If the word was Bob’s it shows Bob's. I have no special configuration going to show you. How do I fix this?
      H J 2 Replies Last reply Reply Quote 0
      • H Offline
        huskernut0878 @huskernut0878
        @huskernut0878 well that didn’t work. It displays Bob ( the code for an apostrophe ) s
          sdetweil @huskernut0878
          @huskernut0878 you could try to change the character encoding
          see
          https://docs.magicmirror.builders/modules/newsfeed.html#configuration-options
          • H Offline
            huskernut0878 @sdetweil
            @sdetweil thank you, that did not make a difference.
              @huskernut0878 there is a similar issue open
              https://github.com/MichMich/MagicMirror/issues/2712
              the possible fix seems to open a big security exposure
                J_Joe @huskernut0878
                @huskernut0878
                I had the same frustrating issue - here’s my solution -
                I actually made a fix for this that works fine for me - Not sure how to present it - but in the newsfeed.js make the following changes
                1. At the end of the defaults of the newsfeed.js add the line replaceMe: [] as shown below -
                  logFeedWarnings: false,
                  replaceMe: []
                2. In the getTemplateData: function () { add the following before the return { loaded: true,
                  basically everything in the jep section all between the //*******
                  return item;
                   //jep  to fix title for various translations such as
                   // a simple ' instead of showing '
                   // also replace things like Seattle with Seattle, WA
                   var tempTitle = item.title;
                   for(let i = 0; i <  this.config.replaceMe.length; i+= 2)
                       tempTitle = tempTitle.toString().replaceAll(this.config.replaceMe[i], this.config.replaceMe[i+1]);
                   return {
                       loaded: true,
                2A. In the return section -add the jep line as shown below
                publishDate: moment(new Date(item.pubdate)).fromNow(),
                title: tempTitle, //jep see above
                description: item.description,
                1. Finally - in your config.js - the area for the newsfeed - at the end add this and edit it for the items you want changed…
                replaceMe: [ "&apos;", "'", "Seattle", "Seattle, WA", "Biden", "(Pres) Biden",  "Zuckerberg", "Zuckerberg [DATA]"]
                (sam, edited to add code block, which preserves the style of the quotes, else u get word processing style, which breaks config.js))
                This will replace the 1st item with the 2nd item, etc… Add whatever translations you want (: I’ve had some fun with the replacements…
                S B H 3 Replies Last reply Reply Quote 0
                  sdetweil @J_Joe
                  @j_joe u should propose that as a fix for the above listed issue…
                  moves control to the user, and eliminates a possible hack exposure
                    J_Joe @sdetweil
                    Not sure how to do that (:
                      sdetweil @J_Joe
                      @j_joe go to the link, and add a comment to the existing issue on how you solved this…
                      copy your info here, there in the comment
                        J_Joe @sdetweil
                        Got it - thank you. Done.
                        I hope my solution works for people. It’s been great for me and my needs! And it’s simple. How ever many items are in the array - it will look for them and replace them as dictated by the array…
                          bma_diy @J_Joe
                          @j_joe thank you, this worked for me. but i did have some trouble. only way i coudl get it to work for some reason was to place the character replacement array in the default section of newsfeed.js instead of in config.js
                          • H Offline
                            huskernut0878 @J_Joe
                            @j_joe Thank you. I am very new to this and dont know what some of the things you are saying even are such as "In the getTemplateData: function () " and “in the return section” but that gives me some things to figure out. The best way to understand is to figure things out. Thanks again.
