    Character set for news fed text '
    12 Posts 4 Posters 2.7k Views 4 Watching
    • H Offline
      huskernut0878 @sdetweil
      @sdetweil thank you, that did not make a difference.
        sdetweil @huskernut0878
        @huskernut0878 there is a similar issue open
        https://github.com/MichMich/MagicMirror/issues/2712
        the possible fix seems to open a big security exposure
          J_Joe @huskernut0878
          @huskernut0878
          I had the same frustrating issue - here’s my solution -
          I actually made a fix for this that works fine for me - Not sure how to present it - but in the newsfeed.js make the following changes
          1. At the end of the defaults of the newsfeed.js add the line replaceMe: [] as shown below -
            logFeedWarnings: false,
            replaceMe: []
          2. In the getTemplateData: function () { add the following before the return { loaded: true,
            basically everything in the jep section all between the //*******
            return item;
             //jep  to fix title for various translations such as
             // a simple ' instead of showing '
             // also replace things like Seattle with Seattle, WA
             var tempTitle = item.title;
             for(let i = 0; i <  this.config.replaceMe.length; i+= 2)
                 tempTitle = tempTitle.toString().replaceAll(this.config.replaceMe[i], this.config.replaceMe[i+1]);
             return {
                 loaded: true,
          2A. In the return section -add the jep line as shown below
          publishDate: moment(new Date(item.pubdate)).fromNow(),
          title: tempTitle, //jep see above
          description: item.description,
          1. Finally - in your config.js - the area for the newsfeed - at the end add this and edit it for the items you want changed…
          replaceMe: [ "&apos;", "'", "Seattle", "Seattle, WA", "Biden", "(Pres) Biden",  "Zuckerberg", "Zuckerberg [DATA]"]
          (sam, edited to add code block, which preserves the style of the quotes, else u get word processing style, which breaks config.js))
          This will replace the 1st item with the 2nd item, etc… Add whatever translations you want (: I’ve had some fun with the replacements…
          S B H 3 Replies Last reply Reply Quote 0
            sdetweil @J_Joe
            @j_joe u should propose that as a fix for the above listed issue…
            moves control to the user, and eliminates a possible hack exposure
              J_Joe @sdetweil
              Not sure how to do that (:
                sdetweil @J_Joe
                @j_joe go to the link, and add a comment to the existing issue on how you solved this…
                copy your info here, there in the comment
                  J_Joe @sdetweil
                  Got it - thank you. Done.
                  I hope my solution works for people. It’s been great for me and my needs! And it’s simple. How ever many items are in the array - it will look for them and replace them as dictated by the array…
                    bma_diy @J_Joe
                    @j_joe thank you, this worked for me. but i did have some trouble. only way i coudl get it to work for some reason was to place the character replacement array in the default section of newsfeed.js instead of in config.js
                    • H Offline
                      huskernut0878 @J_Joe
                      @j_joe Thank you. I am very new to this and dont know what some of the things you are saying even are such as "In the getTemplateData: function () " and “in the return section” but that gives me some things to figure out. The best way to understand is to figure things out. Thanks again.
