    Character set for news fed text '
    12 Posts 4 Posters 3.6k Views 4 Watching
    • H
      huskernut0878 @huskernut0878
      @huskernut0878 well that didn’t work. It displays Bob ( the code for an apostrophe ) s
        sdetweil @huskernut0878
        @huskernut0878 you could try to change the character encoding
        see
        https://docs.magicmirror.builders/modules/newsfeed.html#configuration-options
        H 1 Reply Last reply
        • H
          huskernut0878 @sdetweil
          @sdetweil thank you, that did not make a difference.
            @huskernut0878 there is a similar issue open
            https://github.com/MichMich/MagicMirror/issues/2712
            the possible fix seems to open a big security exposure
              J_Joe @huskernut0878
              @huskernut0878
              I had the same frustrating issue - here’s my solution -
              I actually made a fix for this that works fine for me - Not sure how to present it - but in the newsfeed.js make the following changes
              1. At the end of the defaults of the newsfeed.js add the line replaceMe: [] as shown below -
                logFeedWarnings: false,
                replaceMe: []
              2. In the getTemplateData: function () { add the following before the return { loaded: true,
                basically everything in the jep section all between the //*******
                return item;
                 //jep  to fix title for various translations such as
                 // a simple ' instead of showing '
                 // also replace things like Seattle with Seattle, WA
                 var tempTitle = item.title;
                 for(let i = 0; i <  this.config.replaceMe.length; i+= 2)
                     tempTitle = tempTitle.toString().replaceAll(this.config.replaceMe[i], this.config.replaceMe[i+1]);
                 return {
                     loaded: true,
              2A. In the return section -add the jep line as shown below
              publishDate: moment(new Date(item.pubdate)).fromNow(),
              title: tempTitle, //jep see above
              description: item.description,
              1. Finally - in your config.js - the area for the newsfeed - at the end add this and edit it for the items you want changed…
              replaceMe: [ "&apos;", "'", "Seattle", "Seattle, WA", "Biden", "(Pres) Biden",  "Zuckerberg", "Zuckerberg [DATA]"]
              (sam, edited to add code block, which preserves the style of the quotes, else u get word processing style, which breaks config.js))
              This will replace the 1st item with the 2nd item, etc… Add whatever translations you want (: I’ve had some fun with the replacements…
              S B H 3 Replies Last reply
                sdetweil @J_Joe
                @j_joe u should propose that as a fix for the above listed issue…
                moves control to the user, and eliminates a possible hack exposure
                J 1 Reply Last reply
                  J_Joe @sdetweil
                  Not sure how to do that (:
                    sdetweil @J_Joe
                    @j_joe go to the link, and add a comment to the existing issue on how you solved this…
                    copy your info here, there in the comment
                      J_Joe @sdetweil
                      Got it - thank you. Done.
                      I hope my solution works for people. It’s been great for me and my needs! And it’s simple. How ever many items are in the array - it will look for them and replace them as dictated by the array…
                        bma_diy @J_Joe
                        @j_joe thank you, this worked for me. but i did have some trouble. only way i coudl get it to work for some reason was to place the character replacement array in the default section of newsfeed.js instead of in config.js
                        • H
                          huskernut0878 @J_Joe
                          @j_joe Thank you. I am very new to this and dont know what some of the things you are saying even are such as "In the getTemplateData: function () " and “in the return section” but that gives me some things to figure out. The best way to understand is to figure things out. Thanks again.
