    [MMM-Remote-Control] Can not access remote control module
    7 Posts 2 Posters 1.1k Views 2 Watching
      ruffneck2
      At first, I would like to thank again for developing this module MMM-Remote-Control.
      I’ve cloned it into my \MagicMirror\modules folder via manual command from Github and since this failed via automatic installer script as well:
      bash -c "$(curl -s https://raw.githubusercontent.com/Jopyth/MMM-Remote-Control/master/installer.sh)"
      Once I add the module to my config/config.js file with
      			module: "MMM-Remote-Control",
      			// uncomment the following line to show the URL of the remote control on the mirror
      			// position: 'bottom_left',
      			// you can hide this module afterwards from the remote control itself
      				apiKey: "my_ultra_secret_API_key"
      or the command given on Github page
          module: 'MMM-Remote-Control',
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              // apiKey: "", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
      the MagicMirror² does not start after performing pm2 restart mm.sh
      Once I uncomment the module in config.js it’s working fine again.
      Does anybody could provide a hint, so that I’d be able to shutdown the MagicMirror² remotely?
      I also get connection to the mirror from any device in my home network via http://ipaddressofpi:8080/ when uncommenting the module, adding this information in hope it would help to solve this issue.
        ruffneck2 @sdetweil
        I removed the MMM-Remote-Control folder with newest Release version and downloaded and installed an older Release version (1.1.5) and this one is working on my old mirror which is totally fine for me :)
        I’m happy now, so thank you for your efforts and support on this topic. :flexed_biceps_light_skin_tone:
          sdetweil @ruffneck2
          @ruffneck2 could you look at the messages recorded by pm2
          pm2 logs --lines=???
          ??? is a number, default 15, u may have to make that bigger, 100 maybe.
          or look at the log files in the ~/.pm2/logs folder
          note the dot in front of pm2, by convention, this is considered hidden from file lists, without additional parms
            ruffneck2 @sdetweil
            @sdetweil said in [MMM-Remote-Control] Can not access remote control module:
            pm2 logs --lines=
            Thanks for your reply.
            I’ve performed pm2 logs --lines=100
            Please find result below:
            /home/pi/.pm2/logs/mm-error.log last 100 lines:
            0|mm       |     at Module._compile (module.js:606:28)
            0|mm       |     at Object.Module._extensions..js (module.js:653:10)
            0|mm       |     at Module.load (module.js:561:32)
            0|mm       |     at tryModuleLoad (module.js:504:12)
            0|mm       |     at Function.Module._load (module.js:496:3)
            0|mm       |     at Module.require (module.js:586:17)
            0|mm       |     at require (internal/module.js:11:18)
            0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/lib/tasks/branch.js:6:24)
            0|mm       | /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/lib/parsers/parse-branch.js:10
            0|mm       |     new utils_1.LineParser(/^(\*\s)?(\S+)\s+([a-z0-9]+)\s(.*)$/s, (result, [current, name, commit, label]) => {
            0|mm       |                            ^
            0|mm       |
            0|mm       | SyntaxError: Invalid regular expression flags
            0|mm       |     at createScript (vm.js:80:10)
            0|mm       |     at Object.runInThisContext (vm.js:139:10)
            0|mm       | libGL error: MESA-LOADER: failed to retrieve device information
            0|mm       | MESA-LOADER: failed to retrieve device information
            0|mm       | [9288:0105/224644.968557:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
            0|mm       | npm ERR! code ELIFECYCLE
            0|mm       | npm ERR! errno 1
            0|mm       | npm ERR! magicmirror@2.5.0 start: `sh run-start.sh`
            0|mm       | npm ERR! Exit status 1
            0|mm       | npm ERR!
            0|mm       | npm ERR! Failed at the magicmirror@2.5.0 start script.
            0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|mm       |
            0|mm       | npm ERR! A complete log of this run can be found in:
            0|mm       | npm ERR!     /home/pi/.npm/_logs/2022-01-05T21_54_38_745Z-debug.log
            0|mm       | Failure: Error: connect ECONNREFUSED ::1:5005
            0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
            0|mm       | App threw an error during load
            0|mm       |                            ^
            0|mm       |
            0|mm       |                            ^
            0|mm       |
              sdetweil @ruffneck2
              @ruffneck2 you are running MagicMirror 2.5?
              current is 2.18, and released every 3 months, so 4 years old.
              what node/nom version are you using?
              do
              node -v
              npm -v
                ruffneck2 @sdetweil
                npm -v
                Node Version is v9.11.2
                NPM Version is 5.6.0
                Yes, unfortunately I’m using MagicMirror 2.5.0, because my mirror is already finished and mounted to the wall.
                In the past I had a lot of trouble after trying to update to a higher version. I had to disassemble the entire system, re-install it to get it working again. To avoid running into same issue once again, I decided to be fine with running system, but now I have found this helpful module and would like to use it to shutdown the system more securely.
                However, does it has to do with incompatible version of the module and old files of node and npm? Should I use an older version of the module instead?
                  sdetweil @ruffneck2
                  @ruffneck2 this is certainly because of the system level …
                  I do not know if you can make it work…
                  IF you decide to upgrade, make a backup of the MM folder
                  and try my upgrade script
                  see https://github.com/sdetweil/MagicMirror_scripts
                  its a 2 part process…
                  1 is test, identify any issues, make no changes
                  you fix any issue u want to fix
                  if you choose to upgrade then
                  2 rerun with ‘apply’ parameter to DO the upgrade (make changes)
                    ruffneck2 @sdetweil
