    Starting from an existing module?
    6 Posts 2 Posters 1.5k Views 2 Watching
    • sifuhallS Offline
      sifuhall
      I saw in this post a couple of people recommend starting with an existing module when attempting to create your own module.
      I have a JSON command that returns information I was to display on my Magic Mirror.
      The only two variables I want to specify in the config are the device IDs to pass to the JSON command and the amount of time (in minutes?) I would like to refresh this data.
      What would be a good module to start with for these requirements?
        sdetweil @sifuhall
        @sifuhall what is the ‘json command’ written in? python?
        see my PythonPrint module
        https://github.com/sdetweil/MMM-PythonPrint
        which launches a python script, captures it’s print/stdout content, and sends it to the front end to process
        it can launch python scripts that output repeatedly over time, or it can launch a one time script on some timed cycle
        sifuhallS 1 Reply Last reply Reply Quote 0
        • sifuhallS Offline
          sifuhall @sdetweil
          Thanks for the reply.
          The JSON command works from a browser.
          This is the command
          http://192.168.1.9/JSON?request=getstatus&ref=260,175,233
          260,175,233 would be the IDs I would like to pass
            sdetweil @sifuhall
            @sifuhall you should be able to do that right in the browser side with built in fetch()
            • sifuhallS Offline
              sifuhall @sdetweil
              @sdetweil Thank you
                sdetweil @sifuhall
                @sifuhall my SampleModule has all the parts. u won’t need the helper if fetch works
