    Analog Clock Module Midori Browser
    3 Posts 3 Posters 2.6k Views 4 Watching
      bmarofsky
      I have the Analog clock setup but it only works from my laptop browsers (firefox, IE). On the Pi zero (Jessie full) I am running either Midori or KWeb and the clock shows but is stuck at 9:00.
      If I switch it to Digital, it works and i see the correct time and the seconds updating. Any thoughts?
      EDIT: I tried scaling the clock from 600 to 100 and it started working. Scaled it up to 600, still worked. Rebooted and it stopped.
      • E Offline
        envedede
        Hello there, I am having the same issue, but I am running Pi Zero W with jessie lite. Did you manage to fix the issue by any chance?
        • G Offline
          geoffibs
          I’m having the same issue except no amount of scaling will move it from 9 O’clock. In case anyone if lookingat unread psots and fixed it, how did you do it? Thanks.
