    Trying to update node.js fails
    26 Posts 3 Posters 9.9k Views 3 Watching
      sdetweil @thad
      @thad is there a cron job running? maybe killing pm2
      • T Offline
        thad @sdetweil
        I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
          sdetweil @thad
          @thad ok, lets see if we can start over on pm2
          do
          pm2 unstartup
          it will give u a command to issue to remove the pm2 hooks
          then do
          sudo npm uninstall pm2
          then run my fixuppm2.sh script again … it will redo all the setup
          • T Offline
            thad @sdetweil
            Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
            • T Offline
              thad
              That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
              Here they are:
              0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
              0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
              0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
              PM2 | pm2 has been killed by signal, dumping process list before exit…
              PM2 | Deleting process 0
              PM2 | Stopping app:MagicMirror id:0
              PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
              0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
              0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
              0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
              0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
              0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
              0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
              0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
              0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
              PM2 | pid=1533 msg=process killed
              PM2 | Exited peacefully
              0|MagicMirror | > magicmirror@2.18.0 start
              0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
              0|MagicMirror | Starting MagicMirror: v2.18.0
                sdetweil @thad
                @thad fun times
                edit package.json and add
                --disable-gpu
                between the node_modules/electron and the js/electron.js
                on the start statement
                on my phone so hard to build good statement result… like this…
                "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                • T Offline
                  thad @sdetweil
                  Looking good. Right at an hour with no restarts.
                    sdetweil @thad
                    @thad what pi is this? and what os?
                    lsb_release -a
                    will show the os release info
                    • T Offline
                      thad @sdetweil
                      It’s a pi4 running Raspbian release 10.
                        sdetweil @thad
                        @thad release 10, is that buster or bullseye?
                        pi4, 2,4,8 gig?
                        • 2 / 3
