    Trying to update node.js fails
    26 Posts 3 Posters 12.4k Views 3 Watching
    • T
      thad @sdetweil
      Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
      • T
        thad
        That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
        Here they are:
        0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
        0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
        0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
        PM2 | pm2 has been killed by signal, dumping process list before exit…
        PM2 | Deleting process 0
        PM2 | Stopping app:MagicMirror id:0
        PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
        0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
        0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
        0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
        0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
        0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
        0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
        0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
        0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
        PM2 | pid=1533 msg=process killed
        PM2 | Exited peacefully
        0|MagicMirror | > magicmirror@2.18.0 start
        0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
        0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
        0|MagicMirror | Starting MagicMirror: v2.18.0
          sdetweil @thad
          @thad fun times
          edit package.json and add
          --disable-gpu
          between the node_modules/electron and the js/electron.js
          on the start statement
          on my phone so hard to build good statement result… like this…
          "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
          • T
            thad @sdetweil
            Looking good. Right at an hour with no restarts.
              sdetweil @thad
              @thad what pi is this? and what os?
              lsb_release -a
              will show the os release info
              • T
                thad @sdetweil
                It’s a pi4 running Raspbian release 10.
                  sdetweil @thad
                  @thad release 10, is that buster or bullseye?
                  pi4, 2,4,8 gig?
                  • T
                    thad @sdetweil
                    It’s buster and I believe the pi4 is a 2GB model.
                    S T 2 Replies Last reply Reply Quote 0
                      sdetweil @thad
                      @thad do
                      uname - a
                      so I can see if legacy buster or real…
                      free -m
                      will tell u how much memory
                      • T
                        thad @thad
                        pi@raspberrypi:~/MagicMirror $ uname -a
                        Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
                        pi@raspberrypi:~/MagicMirror $ free -m
                        total used free shared buff/cache available
                        Mem: 1939 342 888 254 708 1261
                          sdetweil @thad
                          @thad thx… original buster (4.19.97), legacy is 5.??? something)
                          and yes, 2gig memory
                          did u do any display config settings info in the /boot/confg.txt
                          i have gpu trouble on my jetson nano, but never on any pi so far…
                          • T
                            thad @sdetweil
                            I don’t recall making any edits to that file. Most items in that file are commented out. Here’s a list of what’s not commented out:
                            hdmi_force_hotplug=1
                            hdmi_group=1
                            hdmi_mode=97
                            dtparam=audio=on
                            [pi4]
                            dtoverlay=vc4-fkms-v3d
                            max_framebuffers=2
                            [all]
                              sdetweil @thad
                              @thad said in Trying to update node.js fails:
                              max_framebuffers=2
                              same for my pi4 (4 gig)
