    Trying to update node.js fails
    26 Posts 3 Posters 12.6k Views 3 Watching
      sdetweil @thad
      @thad pm2 status shows the processes registered to manage
      pm2 info x (x is name or number) will show what it run
      pm2 delete x will remove an entry
      pm2 --help will show all the things u can do .
      T 1 Reply Last reply
      • T
        thad @sdetweil
        Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
        PM2 | pm2 has been killed by signal, dumping process list before exit…
        PM2 | Deleting process 0
        PM2 | Stopping app:MagicMirror id:0
        PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
        0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
        PM2 | pid=1386 msg=process killed
        PM2 | Exited peacefully
        0|MagicM
        For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
          sdetweil @thad
          @thad is there a cron job running? maybe killing pm2
          • T
            thad @sdetweil
            I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
              sdetweil @thad
              @thad ok, lets see if we can start over on pm2
              do
              pm2 unstartup
              it will give u a command to issue to remove the pm2 hooks
              then do
              sudo npm uninstall pm2
              then run my fixuppm2.sh script again … it will redo all the setup
              • T
                thad @sdetweil
                Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
                • T
                  thad
                  That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
                  Here they are:
                  0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
                  0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
                  0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
                  0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
                  0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
                  0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
                  0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
                  0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
                  0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
                  0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                  0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                  PM2 | pid=1533 msg=process killed
                  0|MagicMirror | > magicmirror@2.18.0 start
                  0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
                  0|MagicMirror | Starting MagicMirror: v2.18.0
                    sdetweil @thad
                    @thad fun times
                    edit package.json and add
                    --disable-gpu
                    between the node_modules/electron and the js/electron.js
                    on the start statement
                    on my phone so hard to build good statement result… like this…
                    "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                    • T
                      thad @sdetweil
                      Looking good. Right at an hour with no restarts.
                        sdetweil @thad
                        @thad what pi is this? and what os?
                        lsb_release -a
                        will show the os release info
                        • T
                          thad @sdetweil
                          It’s a pi4 running Raspbian release 10.
                            sdetweil @thad
                            @thad release 10, is that buster or bullseye?
                            pi4, 2,4,8 gig?
                            • T
                              thad @sdetweil
                              It’s buster and I believe the pi4 is a 2GB model.
                              S T 2 Replies Last reply
                                sdetweil @thad
                                @thad do
                                uname - a
                                so I can see if legacy buster or real…
                                free -m
                                will tell u how much memory
                                • T
                                  thad @thad
                                  pi@raspberrypi:~/MagicMirror $ uname -a
                                  Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
                                  pi@raspberrypi:~/MagicMirror $ free -m
                                  total used free shared buff/cache available
                                  Mem: 1939 342 888 254 708 1261
                                    sdetweil @thad
                                    @thad thx… original buster (4.19.97), legacy is 5.??? something)
                                    and yes, 2gig memory
                                    did u do any display config settings info in the /boot/confg.txt
                                    i have gpu trouble on my jetson nano, but never on any pi so far…
                                    • T
                                      thad @sdetweil
                                      I don’t recall making any edits to that file. Most items in that file are commented out. Here’s a list of what’s not commented out:
                                      hdmi_force_hotplug=1
                                      hdmi_group=1
                                      hdmi_mode=97
                                      dtparam=audio=on
                                      [pi4]
                                      dtoverlay=vc4-fkms-v3d
                                      max_framebuffers=2
                                      [all]
                                        sdetweil @thad
                                        @thad said in Trying to update node.js fails:
                                        max_framebuffers=2
                                        same for my pi4 (4 gig)
