    Trying to update node.js fails
    26 Posts 3 Posters 12.6k Views 3 Watching
      sdetweil @thad
      @thad do you have nvm installed
      do
      which nvm
      (if nvm is NOT installed u will get a blank response)
      nvm sets its own path which overrides the base path
        sdetweil @thad
        @thad as for pm2, then show the pm2 logs
        pm2 logs --lines=100
        (ctrl-c to end)
        maybe need to clear them first to get shorter version
        pm2 flush
        then pm2 start
        them pm2 logs --lines=100 as above
        bugsounetB T 2 Replies Last reply
        • bugsounetB
          bugsounet Banned @sdetweil
          @thad said in Trying to update node.js fails:
          E: Repository ‘http://archive.raspberrypi.org/debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
          E: Repository ‘http://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
          @sdetweil : to correct this:
          sudo apt-get --allow-releaseinfo-change update
          (I’m really so kind, this cannot last !!! :dizzy_face: )
          T S 2 Replies Last reply
          • T
            thad @sdetweil
            I don’t have nvm installed. The command ‘which nvm’ command returned nothing.
            If I clear the pm2 logs and immediately look at them, I’m seeing something odd. It appears I have 2 processed controlled by pm2. Here’s the output:
            pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100
            /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
            /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
            I think the MagicMirror references are to my initial installation from a year or two ago. The references to ‘mm’ are what I attempted to do this morning.
            • T
              thad @bugsounet
              @bugsounet said in Trying to update node.js fails:
              That made a big difference! The script that updates node.js now runs properly! Thanks.
              I’ll keep playing and see if I can get this thing running again.
              • T
                thad
                @bugsounet @bugsounet
                Thanks for your help. This has me running again. I need to work on the weather module some more. I have the current weather working, but the forecast is hung on ‘loading’. Thanks again for the super quick responses!
                  sdetweil @bugsounet
                  @bugsounet thx… added to upgrade, had for install
                    sdetweil @thad
                    @thad pm2 status shows the processes registered to manage
                    pm2 info x (x is name or number) will show what it run
                    pm2 delete x will remove an entry
                    pm2 --help will show all the things u can do .
                    T 1 Reply Last reply
                    • T
                      thad @sdetweil
                      Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
                      PM2 | pm2 has been killed by signal, dumping process list before exit…
                      PM2 | Deleting process 0
                      PM2 | Stopping app:MagicMirror id:0
                      PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
                      0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                      PM2 | pid=1386 msg=process killed
                      PM2 | Exited peacefully
                      0|MagicM
                      For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
                        sdetweil @thad
                        @thad is there a cron job running? maybe killing pm2
                        • T
                          thad @sdetweil
                          I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
                            sdetweil @thad
                            @thad ok, lets see if we can start over on pm2
                            do
                            pm2 unstartup
                            it will give u a command to issue to remove the pm2 hooks
                            then do
                            sudo npm uninstall pm2
                            then run my fixuppm2.sh script again … it will redo all the setup
                            • T
                              thad @sdetweil
                              Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
                              • T
                                thad
                                That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
                                Here they are:
                                0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
                                0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
                                0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
                                0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
                                0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
                                0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
                                0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
                                0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
                                0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
                                0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                                0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                                PM2 | pid=1533 msg=process killed
                                0|MagicMirror | > magicmirror@2.18.0 start
                                0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
                                0|MagicMirror | Starting MagicMirror: v2.18.0
                                  sdetweil @thad
                                  @thad fun times
                                  edit package.json and add
                                  --disable-gpu
                                  between the node_modules/electron and the js/electron.js
                                  on the start statement
                                  on my phone so hard to build good statement result… like this…
                                  "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                                  • T
                                    thad @sdetweil
                                    Looking good. Right at an hour with no restarts.
                                      sdetweil @thad
                                      @thad what pi is this? and what os?
                                      lsb_release -a
                                      will show the os release info
                                      • T
                                        thad @sdetweil
                                        It’s a pi4 running Raspbian release 10.
                                          sdetweil @thad
                                          @thad release 10, is that buster or bullseye?
                                          pi4, 2,4,8 gig?
                                          • T
                                            thad @sdetweil
                                            It’s buster and I believe the pi4 is a 2GB model.
                                            S T 2 Replies Last reply
