    Trying to update node.js fails
    26 Posts 3 Posters 9.9k Views 3 Watching
    • bugsounetB Offline
      bugsounet Banned @sdetweil
      @thad said in Trying to update node.js fails:
      E: Repository ‘http://archive.raspberrypi.org/debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
      E: Repository ‘http://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
      @sdetweil : to correct this:
      sudo apt-get --allow-releaseinfo-change update
      (I’m really so kind, this cannot last !!! :dizzy_face: )
      T S 2 Replies Last reply Reply Quote 0
      • T Offline
        thad @sdetweil
        I don’t have nvm installed. The command ‘which nvm’ command returned nothing.
        If I clear the pm2 logs and immediately look at them, I’m seeing something odd. It appears I have 2 processed controlled by pm2. Here’s the output:
        pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        I think the MagicMirror references are to my initial installation from a year or two ago. The references to ‘mm’ are what I attempted to do this morning.
        • T Offline
          thad @bugsounet
          @bugsounet said in Trying to update node.js fails:
          That made a big difference! The script that updates node.js now runs properly! Thanks.
          I’ll keep playing and see if I can get this thing running again.
          • T Offline
            thad
            @bugsounet @bugsounet
            Thanks for your help. This has me running again. I need to work on the weather module some more. I have the current weather working, but the forecast is hung on ‘loading’. Thanks again for the super quick responses!
              sdetweil @bugsounet
              @bugsounet thx… added to upgrade, had for install
                sdetweil @thad
                @thad pm2 status shows the processes registered to manage
                pm2 info x (x is name or number) will show what it run
                pm2 delete x will remove an entry
                pm2 --help will show all the things u can do .
                • T Offline
                  thad @sdetweil
                  Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
                  PM2 | pm2 has been killed by signal, dumping process list before exit…
                  PM2 | Deleting process 0
                  PM2 | Stopping app:MagicMirror id:0
                  PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
                  0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                  PM2 | pid=1386 msg=process killed
                  PM2 | Exited peacefully
                  0|MagicM
                  For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
                    sdetweil @thad
                    @thad is there a cron job running? maybe killing pm2
                    • T Offline
                      thad @sdetweil
                      I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
                        sdetweil @thad
                        @thad ok, lets see if we can start over on pm2
                        do
                        pm2 unstartup
                        it will give u a command to issue to remove the pm2 hooks
                        then do
                        sudo npm uninstall pm2
                        then run my fixuppm2.sh script again … it will redo all the setup
