    Trying to update node.js fails
    26 Posts 3 Posters 12.6k Views 3 Watching
      sdetweil @thad
      @thad as for pm2, then show the pm2 logs
      pm2 logs --lines=100
      (ctrl-c to end)
      maybe need to clear them first to get shorter version
      pm2 flush
      then pm2 start
      them pm2 logs --lines=100 as above
      bugsounetB T 2 Replies Last reply
      • bugsounetB
        bugsounet Banned @sdetweil
        @thad said in Trying to update node.js fails:
        E: Repository ‘http://archive.raspberrypi.org/debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
        E: Repository ‘http://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
        @sdetweil : to correct this:
        sudo apt-get --allow-releaseinfo-change update
        (I’m really so kind, this cannot last !!! :dizzy_face: )
        T S 2 Replies Last reply
        • T
          thad @sdetweil
          I don’t have nvm installed. The command ‘which nvm’ command returned nothing.
          If I clear the pm2 logs and immediately look at them, I’m seeing something odd. It appears I have 2 processed controlled by pm2. Here’s the output:
          pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100
          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
          I think the MagicMirror references are to my initial installation from a year or two ago. The references to ‘mm’ are what I attempted to do this morning.
          • T
            thad @bugsounet
            @bugsounet said in Trying to update node.js fails:
            That made a big difference! The script that updates node.js now runs properly! Thanks.
            I’ll keep playing and see if I can get this thing running again.
            • T
              thad
              @bugsounet @bugsounet
              Thanks for your help. This has me running again. I need to work on the weather module some more. I have the current weather working, but the forecast is hung on ‘loading’. Thanks again for the super quick responses!
                sdetweil @bugsounet
                @bugsounet thx… added to upgrade, had for install
                  sdetweil @thad
                  @thad pm2 status shows the processes registered to manage
                  pm2 info x (x is name or number) will show what it run
                  pm2 delete x will remove an entry
                  pm2 --help will show all the things u can do .
                  T 1 Reply Last reply
                  • T
                    thad @sdetweil
                    Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
                    PM2 | pm2 has been killed by signal, dumping process list before exit…
                    PM2 | Deleting process 0
                    PM2 | Stopping app:MagicMirror id:0
                    PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
                    0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                    PM2 | pid=1386 msg=process killed
                    PM2 | Exited peacefully
                    0|MagicM
                    For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
                      sdetweil @thad
                      @thad is there a cron job running? maybe killing pm2
                      • T
                        thad @sdetweil
                        I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
                          sdetweil @thad
                          @thad ok, lets see if we can start over on pm2
                          do
                          pm2 unstartup
                          it will give u a command to issue to remove the pm2 hooks
                          then do
                          sudo npm uninstall pm2
                          then run my fixuppm2.sh script again … it will redo all the setup
                          • T
                            thad @sdetweil
                            Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
                            • T
                              thad
                              That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
                              Here they are:
                              0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
                              0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
                              0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
                              0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
                              0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
                              0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
                              0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
                              0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
                              0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
                              0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                              0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                              PM2 | pid=1533 msg=process killed
                              0|MagicMirror | > magicmirror@2.18.0 start
                              0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                              0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
                              0|MagicMirror | Starting MagicMirror: v2.18.0
                                sdetweil @thad
                                @thad fun times
                                edit package.json and add
                                --disable-gpu
                                between the node_modules/electron and the js/electron.js
                                on the start statement
                                on my phone so hard to build good statement result… like this…
                                "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                                • T
                                  thad @sdetweil
                                  Looking good. Right at an hour with no restarts.
                                    sdetweil @thad
                                    @thad what pi is this? and what os?
                                    lsb_release -a
                                    will show the os release info
                                    • T
                                      thad @sdetweil
                                      It’s a pi4 running Raspbian release 10.
                                        sdetweil @thad
                                        @thad release 10, is that buster or bullseye?
                                        pi4, 2,4,8 gig?
                                        • T
                                          thad @sdetweil
                                          It’s buster and I believe the pi4 is a 2GB model.
                                          S T 2 Replies Last reply
                                            sdetweil @thad
                                            @thad do
                                            uname - a
                                            so I can see if legacy buster or real…
                                            free -m
                                            will tell u how much memory
