    Trying to update node.js fails
    26 Posts 3 Posters 12.2k Views 3 Watching
    • T Offline
      thad @sdetweil
      I don’t have nvm installed. The command ‘which nvm’ command returned nothing.
      If I clear the pm2 logs and immediately look at them, I’m seeing something odd. It appears I have 2 processed controlled by pm2. Here’s the output:
      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100
      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
      I think the MagicMirror references are to my initial installation from a year or two ago. The references to ‘mm’ are what I attempted to do this morning.
      • T Offline
        thad @bugsounet
        @bugsounet said in Trying to update node.js fails:
        sudo apt-get --allow-releaseinfo-change update
        That made a big difference! The script that updates node.js now runs properly! Thanks.
        I’ll keep playing and see if I can get this thing running again.
        • T Offline
          thad
          @bugsounet @bugsounet
          Thanks for your help. This has me running again. I need to work on the weather module some more. I have the current weather working, but the forecast is hung on ‘loading’. Thanks again for the super quick responses!
            sdetweil @bugsounet
            @bugsounet thx… added to upgrade, had for install
              sdetweil @thad
              @thad pm2 status shows the processes registered to manage
              pm2 info x (x is name or number) will show what it run
              pm2 delete x will remove an entry
              pm2 --help will show all the things u can do .
              • T Offline
                thad @sdetweil
                Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
                PM2 | pm2 has been killed by signal, dumping process list before exit…
                PM2 | Deleting process 0
                PM2 | Stopping app:MagicMirror id:0
                PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
                0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                PM2 | pid=1386 msg=process killed
                PM2 | Exited peacefully
                0|MagicM
                For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
                  sdetweil @thad
                  @thad is there a cron job running? maybe killing pm2
                  • T Offline
                    thad @sdetweil
                    I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
                      sdetweil @thad
                      @thad ok, lets see if we can start over on pm2
                      do
                      pm2 unstartup
                      it will give u a command to issue to remove the pm2 hooks
                      then do
                      sudo npm uninstall pm2
                      then run my fixuppm2.sh script again … it will redo all the setup
                      • T Offline
                        thad @sdetweil
                        Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
                        • T Offline
                          thad
                          That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
                          Here they are:
                          0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
                          0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
                          0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
                          0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
                          0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
                          0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
                          0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
                          0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
                          0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
                          0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                          0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                          PM2 | pid=1533 msg=process killed
                          0|MagicMirror | > magicmirror@2.18.0 start
                          0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                          0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
                          0|MagicMirror | Starting MagicMirror: v2.18.0
                            sdetweil @thad
                            @thad fun times
                            edit package.json and add
                            --disable-gpu
                            between the node_modules/electron and the js/electron.js
                            on the start statement
                            on my phone so hard to build good statement result… like this…
                            "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                            • T Offline
                              thad @sdetweil
                              Looking good. Right at an hour with no restarts.
                                sdetweil @thad
                                @thad what pi is this? and what os?
                                lsb_release -a
                                will show the os release info
                                • T Offline
                                  thad @sdetweil
                                  It’s a pi4 running Raspbian release 10.
                                    sdetweil @thad
                                    @thad release 10, is that buster or bullseye?
                                    pi4, 2,4,8 gig?
                                    • T Offline
                                      thad @sdetweil
                                      It’s buster and I believe the pi4 is a 2GB model.
                                      S T 2 Replies Last reply Reply Quote 0
                                        sdetweil @thad
                                        @thad do
                                        uname - a
                                        so I can see if legacy buster or real…
                                        free -m
                                        will tell u how much memory
                                        • T Offline
                                          thad @thad
                                          pi@raspberrypi:~/MagicMirror $ uname -a
                                          Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
                                          pi@raspberrypi:~/MagicMirror $ free -m
                                          total used free shared buff/cache available
                                          Mem: 1939 342 888 254 708 1261
                                            sdetweil @thad
                                            @thad thx… original buster (4.19.97), legacy is 5.??? something)
                                            and yes, 2gig memory
                                            did u do any display config settings info in the /boot/confg.txt
                                            i have gpu trouble on my jetson nano, but never on any pi so far…
