    order of bottom bar
    3 Posts 2 Posters 651 Views 2 Watching
    • W Offline
      wdave40
      I had my stock ticker on the very bottom “bottom_left” and the news feed just above it “bottom_bar”.
      I’d lost the news feed some how so had to re-add it to config and now the news feed is on the very bottom and the stock ticker is just above it.
      I would rather have the stock ticker on the very bottom.
      Does anyone know how to do that?
      Thanks!
        sdetweil @wdave40
        @wdave40 looking in the developers window (ctrl-shift-i) elements tabs
        I see this for calendar in bottom left, and newsfeed in bottom bar
        bottom left
        bottom bar
        so, it looks like bottom bar is ALWAYS below bottom-left/center/right
        I reversed the module definition order and got the same results.
        do you know if you had any custom.css entries relative to these areas?
        • W Offline
          wdave40 @sdetweil
          Hey Sam!
          I made the ticker bottom bar and the news feed bottom center and it worked!
          Simple fix but I was trying to make it the way it was originally rather than thinking outside the box.
          Thank you!
          Now onto trying to get my GCP tokens to work.
