    (solved) MM 2.18 - skipping optional Dependencys
    6 Posts 2 Posters 2.2k Views 2 Watching
    • O
      OberfragGER
      after a regular Update MM2.17 -> 2.18 ich recieved the Warning:
      MagicMirror installation finished successfully!
      > magicmirror@2.18.0 prepare /home/pi/MagicMirror
      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      husky - Git hooks installed
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/jest-haste-map/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
      Somehow- what do i have to perform to install this dependency…?
      npm install typescript
      npm install tsutils
      Both have been sucessful.
      This is hindering me to update NPM to Version 8.x.
      pi@MagicMirror:~/MagicMirror $ npm install fsevents
      npm ERR! code EBADPLATFORM
      npm ERR! notsup Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! notsup Valid OS:    darwin
      npm ERR! notsup Valid Arch:  any
      npm ERR! notsup Actual OS:   linux
      npm ERR! notsup Actual Arch: arm
      npm ERR!     /home/pi/.npm/_logs/2022-01-13T11_54_19_577Z-debug.log
      • O
        OberfragGER @OberfragGER
        Ich have found the answer by meyself.
        npm install --no-optional
        npm install tsutils
          sdetweil @OberfragGER
          @oberfragger I don’t understand.
          these optional libs are platform dependent.
          as such the fsevents uses macos only functions and CANNOT run on Linux/pi…
          that is why they are OPTIONAL
          no error if not installed.
          • O
            OberfragGER @sdetweil
            @sdetweil Youre right,
            but my inner monk says… warnings are no good. Please fix it ;)
              @oberfragger we cannot fix it… not our code and no overide of messages is available
              same as Audit
              • O
                @sdetweil No. This fix it was not meant by you- it was for me… “but my inner monk says (to myself)… warnings are no good. Please fix it 😉”
