    how to update my MM
    45 Posts 3 Posters 19.5k Views 3 Watching
      RIKKO14
      This post is deleted!
        sdetweil @RIKKO14
        @rikko14 no space between the parts
        cd ~/MagicMirror
        means change directory (cd)
        and the path to change to is /MagicMirror
        relative to the current users home folder
        if pi is the current user, the it’s home is /home/pi
        so the final path would be /home/pi/MagicMirror
        better to run my upgrade script
        see
          RIKKO14
          I do : bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          the message at the top of my screen has disappeared but I have this :
          pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          No LSB modules are available.
          doing test run = true, NO updates will be applied!
          update log will be in /home/pi/MagicMirror/installers/upgrade.log
          Check current Node installation ...
          Node currently installed. Checking version number.
          Minimum Node version: v16.9.1
          Installed Node version: v14.18.1
          Node should be upgraded.
          A Node process is currently running. Can't upgrade.
          Please quit all Node processes and restart the installer.
          pi 717 571 0 13:50 ? 00:00:00 sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js pi 718 717 0 13:50 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi 763 718 12 13:50 ? 00:04:43 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js pi 807 763 0 13:50 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox pi 808 763 0 13:50 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 810 808 0 13:50 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 1011 807 86 13:50 ? 00:31:18 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --field-trial-handle=10979945511507590494,14705312379772556960,131072 --disable-features=CookiesWithoutSameSiteMustBeSecure,SameSiteByDefaultCookies,SpareRendererForSitePerProcess --gpu-preferences=UAAAAAAAAAAgAAAQAAAAAAAAAAAAAAAAAABgAAAAAAAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAAAAAAAAAAAAIAAAAAAAAAAgAAAAAAAAACAAAAAAAAAA= --shared-files pi 1017 763 0 13:50 ? 00:00:10 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --field-trial-handle=10979945511507590494,14705312379772556960,131072 --disable-features=CookiesWithoutSameSiteMustBeSecure,SameSiteByDefaultCookies,SpareRendererForSitePerProcess --lang=fr --service-sandbox-type=none --shared-files=v8_context_snapshot_data:100 pi 1038 1011 0 13:50 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=broker pi 4075 4073 0 14:26 pts/0 00:00:00 grep node pi 27692 763 50 14:20 ? 00:03:06 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --autoplay-policy=no-user-gesture-required --field-trial-handle=10979945511507590494,14705312379772556960,131072 --disable-features=CookiesWithoutSameSiteMustBeSecure,SameSiteByDefaultCookies,SpareRendererForSitePerProcess --lang=fr --app-path=/home/pi/MagicMirror/js --no-sandbox --no-zygote --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100
          pi@raspberrypi:~ $
          Is it normal ?
            sdetweil @RIKKO14
            @rikko14 MagicMirror is running… u need to stop it first
              RIKKO14
              It works with PM2 automatic mode. How to block the pm2 mode while updating and then restart the pm2 mode?
                sdetweil @RIKKO14
                @rikko14 pm2 stop all
                upgrade
                pm2 status
                pm2 start ???
                where ???
                is the name or number of the app definition from status output
                  sdetweil @RIKKO14
                  @rikko14 note that my upgrade is a two step process
                  run the script with no parameters and it is test mode, no changes made. it will highlight if there are issues you need to resolve
                  then run again with ‘apply’ parameter (no quotes) to actually DO the upgrade.
                  wouldn’t you want to know if it was about to mess up your work?
                    RIKKO14
                    it stil running
                    is it normal ?
                      sdetweil @RIKKO14
                      @rikko14 yes it has to update the system to be able to upgrade mm.
                        RIKKO14
                        i have this now :
                        Installing helper tools ...
                        Updating packages ...
                        Installed Node version: v14.18.3
                        Installing Node.js ...
                        gpg: Attention : le propriétaire du répertoire personnel « /home/pi/.gnupg »
                                    n'est pas sûr
                        Lecture des listes de paquets... Fait
                        Construction de l'arbre des dépendances
                        Lecture des informations d'état... Fait
                        Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
                          python-colorzero
                        Veuillez utiliser « sudo apt autoremove » pour le supprimer.
                        Les paquets suivants seront mis à jour :
                          nodejs
                        1 mis à jour, 0 nouvellement installés, 0 à enlever et 2 non mis à jour.
                        Il est nécessaire de prendre 22,9 Mo dans les archives.
                        Après cette opération, 3 950 ko d'espace disque seront libérés.
                        Réception de :1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.13.2-deb-1nodesource1 [22,9 MB]
                        22,9 Mo réceptionnés en 3s (8 267 ko/s)
                        apt-listchanges : Lecture des fichiers de modifications (« changelog »)...
                        (Lecture de la base de données... 100649 fichiers et répertoires déjà installés.)
                        Préparation du dépaquetage de .../nodejs_16.13.2-deb-1nodesource1_armhf.deb ...
                        Dépaquetage de nodejs (16.13.2-deb-1nodesource1) sur (14.18.3-deb-1nodesource1) ...
                        Paramétrage de nodejs (16.13.2-deb-1nodesource1) ...
                        Traitement des actions différées (« triggers ») pour man-db (2.8.5-2) ...
                        nodejs est déjà la version la plus récente (16.13.2-deb-1nodesource1).
                          python-colorzero
                        0 mis à jour, 0 nouvellement installés, 0 à enlever et 2 non mis à jour.
                        Node.js installation Done! version=v16.13.2
                        Check current NPM installation ...
                        NPM currently installed. Checking version number.
                        Minimum npm version: V7.11.2
                        Installed npm version: V8.1.2
                        No npm upgrade necessary.
                        It seems like MagicMirror is already installed.
                        To prevent overwriting, the installer will be aborted.
                        Please rename the ~/MagicMirror folder and try again.
                        pi@raspberrypi:~ $ ^C
                        pi@raspberrypi:~ $ ```
                        do I have to do something?
                          sdetweil @RIKKO14
                          @rikko14 u ran install… not upgrade
                          what am I doing wrong that users have so much trouble deciding what to do? how can I fix it?
                            RIKKO14
                            it’s absolutely not your fault but mine and my fear of doing stupid things.
                            so i copied the command line: bash -c “$ (curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                            and i get this :
                            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                            doing test run = false
                            Installed Node version: v16.13.2
                            No Node.js upgrade necessary.
                            saving custom.css
                            upgrading from version 2.17.1 to 2.18.0
                            fetching latest revisions
                            there are 3 local files that are different than the master repo
                               fonts/package-lock.json
                               package-lock.json
                               vendor/package-lock.json
                            any *-lock.json files do not need to be saved
                            do you want to save these files for later   (Y/n)?y
                            updating MagicMirror runtime, please wait
                            npm WARN tar TAR_BAD_ARCHIVE: Unrecognized archive format
                            npm WARN tarball cached data for qs@https://registry.npmjs.org/qs/-/qs-6.9.6.tgz (sha512-TIRk4aqYLNoJUbd+g2lEdz5kLWIuTMRagAXxl78Q0RiVjAOugHmeKNGdd3cwo/ktpf9aL9epCfFqWDEKysUlLQ==) seems to be corrupted. Refreshing cache.
                            npm WARN tarball cached data for ms@https://registry.npmjs.org/ms/-/ms-2.1.3.tgz (sha512-6FlzubTLZG3J2a/NVCAleEhjzq5oxgHyaCU9yYXvcLsvoVaHJq/s5xXI6/XXP6tz7R9xAOtHnSO/tXtF3WRTlA==) seems to be corrupted. Refreshing cache.
                            > magicmirror@2.18.0 install
                            > echo "Installing vendor files ...
                            > " && cd vendor && npm install --loglevel=error
                            up to date, audited 10 packages in 7s
                            found 0 vulnerabilities
                            > magicmirror@2.18.0 postinstall
                            > npm run install-fonts && echo "MagicMirror installation finished successfully!
                            > magicmirror@2.18.0 install-fonts
                            > echo "Installing fonts ...
                            > " && cd fonts && npm install --loglevel=error
                            up to date, audited 2 packages in 1s
                            > magicmirror@2.18.0 prepare
                            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                            no husky installed.
                            added 3 packages, removed 209 packages, changed 206 packages, and audited 267 packages in 2m
                            19 packages are looking for funding
                              run `npm fund` for details
                            npm notice
                            npm notice New minor version of npm available! 8.1.2 -> 8.3.0
                            npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.3.0>
                            npm notice Run `npm install -g npm@8.3.0` to update!
                            npm notice
                            Checking for modules with removed libraries
                            processing dependency changes for active modules with package.json files
                            processing for module MMM-DHT-Sensor please wait
                            npm ERR! code EINTEGRITY
                            npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/ea/0f/a546dc24ba5ea99e7354a0e3a388be05355ffab78719fa8adfb1bd3127339805bb10a95582e594138f46a9366a29666551053598df5d0c4106dc1f1958de
                            npm ERR! errno EINTEGRITY
                            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/jsonfile: Integrity verification failed for sha512-6g+lRtwkul6pnnNUoOOjiL4FNV/6t4cZ+orfsb0xJzOYBbsQqVWC5ZQTj0apNmopZmVRBTWY310MQQbcHxlY3g== (/home/pi/.npm/_cacache/content-v2/sha512/ea/0f/a546dc24ba5ea99e7354a0e3a388be05355ffab78719fa8adfb1bd3127339805bb10a95582e594138f46a9366a29666551053598df5d0c4106dc1f1958de)
                            npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_52_46_753Z-debug.log
                            processing complete for module MMM-DHT-Sensor
                            processing for module MMM-Weather please wait
                            > MMM-Weather@1.0.4 preinstall
                            > installer/preinstall.sh
                            Welcome to MMM-Weather
                            Installing all npm libraries...
                            added 1 package, and audited 2 packages in 2s
                            processing complete for module MMM-Weather
                            processing for module MMM-NowPlayingOnSpotify please wait
                            npm WARN tarball cached data for aws4@https://registry.npmjs.org/aws4/-/aws4-1.11.0.tgz (sha512-xh1Rl34h6Fi1DC2WWKfxUTVqRsNnr6LsKz2+hfwDxQJWmrx8+c7ylaqBMcHfl1U1r2dsifOvKX3LQuLNZ+XSvA==) seems to be corrupted. Refreshing cache.
                            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            added 111 packages, and audited 674 packages in 1m
                            2 packages are looking for funding
                            41 vulnerabilities (1 low, 18 moderate, 14 high, 8 critical)
                            To address issues that do not require attention, run:
                              npm audit fix
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                            processing complete for module MMM-NowPlayingOnSpotify
                            processing for module MMM-Jast please wait
                            added 261 packages, and audited 262 packages in 2m
                            31 packages are looking for funding
                            processing complete for module MMM-Jast
                            processing for module MMM-TomTomTraffic please wait
                            npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/14/8e/dcdade657854ccd5d610d29351bd6df101fb52d4d01a837451a7e30bb8d84671c63b2ea77d691763bd70d3f257138ec61bf857c7d487aae8205bca7b4f88
                            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/color-name: Integrity verification failed for sha512-FI7c2t5leFTM1dYQ0pNRvW3xAftS1NAag3RRp+MLuNhGccY7Lqd9aRdjvXDT8lcTjsYb+FfH1Ieq6CBbyntPiA== (/home/pi/.npm/_cacache/content-v2/sha512/14/8e/dcdade657854ccd5d610d29351bd6df101fb52d4d01a837451a7e30bb8d84671c63b2ea77d691763bd70d3f257138ec61bf857c7d487aae8205bca7b4f88)
                            npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_56_18_973Z-debug.log
                            processing complete for module MMM-TomTomTraffic
                            processing for module MMM-MovieListings please wait
                            added 47 packages, and audited 48 packages in 4s
                            processing complete for module MMM-MovieListings
                            processing for module MMM-soccer please wait
                            npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/55/9d/0880334436e4cd6964d4caa6757e94f0fa27e66806cd75eaf698cc10016b007bf4e8ccb075d7dbf981ed0e475d529bea6bc174d3f9270e7f80ea8a5007a4
                            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/call-bind: Integrity verification failed for sha512-VZ0IgDNENuTNaWTUyqZ1fpTw+ifmaAbNder2mMwQAWsAe/TozLB119v5ge0OR11Sm+prwXTT+ScOf4DqilAHpA== (/home/pi/.npm/_cacache/content-v2/sha512/55/9d/0880334436e4cd6964d4caa6757e94f0fa27e66806cd75eaf698cc10016b007bf4e8ccb075d7dbf981ed0e475d529bea6bc174d3f9270e7f80ea8a5007a4)
                            npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_57_21_878Z-debug.log
                            processing complete for module MMM-soccer
                            processing for module MMM-MarineWeather please wait
                            added 4 packages, and audited 5 packages in 2s
                            processing complete for module MMM-MarineWeather
                            processing for module MMM-Shom please wait
                            added 2 packages, and audited 3 packages in 3s
                            processing complete for module MMM-Shom
                            processing for module MMM-Tools please wait
                            added 3 packages, and audited 4 packages in 3s
                            1 package is looking for funding
                            processing complete for module MMM-Tools
                            restoring custom.css
                            we stashed a set of files that appear changed from the latest repo versions. you should review them
                            see installers/stashed_files for the list
                            you can use git checkout stash@{0} -- filename to extract one file from the stash
                            or git stash pop to restore them all
                            WARNING..
                            WARNING.. either will overlay the file just installed by the update
                            WARNING..
                            pi@raspberrypi:~ $
                            so everything is OK? Or do you have to do something more?
                            I just have to do pm2 start?
                              sdetweil @RIKKO14
                              @rikko14 yes, just pm2 start… i don’t know what is causing the
                              code EINTEGRITY
                              errors…
                              the more I look at it, the more it sounds like a networking problem
                              I checked each reported bad file and I get them clean…
                              on this
                                 package-lock.json
                              any *-lock.json files do not need to be saved     <-----------
                              do you want to save these files for later   (Y/n)?y  < --------- but you replied yes???
                                RIKKO14
                                it does not work …
                                pi @ raspberrypi: ~ $ pm2 start
                                [PM2] [ERROR] File ecosystem.config.js not found
                                  sdetweil @RIKKO14
                                  @rikko14 because of the changed node and npm version… do this
                                  pm2 update
                                    RIKKO14
                                    I do this :
                                    pi@raspberrypi:~ $ pm2 update
                                    Be sure to have the latest version by doing `npm install pm2@latest -g` before doing this procedure.
                                    [PM2] [v] Modules Stopped
                                    [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
                                    [PM2] [mm](0) ✓
                                    [PM2] [v] All Applications Stopped
                                    [PM2] [v] PM2 Daemon Stopped
                                    [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                    [PM2] Restoring processes located in /home/pi/.pm2/dump.pm2
                                    [PM2] Process /home/pi/mm.sh restored
                                    >>>>>>>>>> PM2 updated
                                    but nothing happens … the MM does not start
                                    same in the MM folder :
                                    pi@raspberrypi:~/MagicMirror $ pm2 update
                                    [PM2] PM2 Successfully daemonized
                                    [PM2][WARN] No process found
                                    >>>>>>>>>> PM2 updated
                                    │ id  │ name  │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                    │ 0   │ mm    │ default     │ N/A     │ fork    │ N/A      │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
                                      sdetweil @RIKKO14
                                      @rikko14 and then pm2 start
                                      pm2 update fixed the missing file
                                        RIKKO14
                                        same error :
                                        pi@raspberrypi:~/MagicMirror $ pm2 start
                                        [PM2][ERROR] File ecosystem.config.js not found
                                        and
                                        pi@raspberrypi:~ $ pm2 start
                                          sdetweil @RIKKO14
                                          @rikko14 ok, (when I said pm2 start, I assumed you would know to add the name or number , pm2 start 0)
                                          do
                                          pm2 save
                                          pm2 start 0
                                            RIKKO14
                                            it works but I found this Electron problem … with a black screen :
                                            see a the top right of my screen
                                            • 1 / 3
