    how to update my MM
    45 Posts 3 Posters 17.2k Views 3 Watching
      sdetweil @RIKKO14
      @rikko14 u ran install… not upgrade
      what am I doing wrong that users have so much trouble deciding what to do? how can I fix it?
        RIKKO14
        it’s absolutely not your fault but mine and my fear of doing stupid things.
        so i copied the command line: bash -c “$ (curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
        and i get this :
        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        No LSB modules are available.
        doing test run = false
        update log will be in /home/pi/MagicMirror/installers/upgrade.log
        Check current Node installation ...
        Node currently installed. Checking version number.
        Minimum Node version: v16.9.1
        Installed Node version: v16.13.2
        No Node.js upgrade necessary.
        Check current NPM installation ...
        NPM currently installed. Checking version number.
        Minimum npm version: V7.11.2
        Installed npm version: V8.1.2
        No npm upgrade necessary.
        saving custom.css
        upgrading from version 2.17.1 to 2.18.0
        fetching latest revisions
        there are 3 local files that are different than the master repo
           fonts/package-lock.json
           package-lock.json
           vendor/package-lock.json
        any *-lock.json files do not need to be saved
        do you want to save these files for later   (Y/n)?y
        updating MagicMirror runtime, please wait
        npm WARN tar TAR_BAD_ARCHIVE: Unrecognized archive format
        npm WARN tarball cached data for qs@https://registry.npmjs.org/qs/-/qs-6.9.6.tgz (sha512-TIRk4aqYLNoJUbd+g2lEdz5kLWIuTMRagAXxl78Q0RiVjAOugHmeKNGdd3cwo/ktpf9aL9epCfFqWDEKysUlLQ==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for ms@https://registry.npmjs.org/ms/-/ms-2.1.3.tgz (sha512-6FlzubTLZG3J2a/NVCAleEhjzq5oxgHyaCU9yYXvcLsvoVaHJq/s5xXI6/XXP6tz7R9xAOtHnSO/tXtF3WRTlA==) seems to be corrupted. Refreshing cache.
        > magicmirror@2.18.0 install
        > echo "Installing vendor files ...
        > " && cd vendor && npm install --loglevel=error
        up to date, audited 10 packages in 7s
        found 0 vulnerabilities
        > magicmirror@2.18.0 postinstall
        > npm run install-fonts && echo "MagicMirror installation finished successfully!
        > magicmirror@2.18.0 install-fonts
        > echo "Installing fonts ...
        > " && cd fonts && npm install --loglevel=error
        up to date, audited 2 packages in 1s
        > magicmirror@2.18.0 prepare
        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
        no husky installed.
        added 3 packages, removed 209 packages, changed 206 packages, and audited 267 packages in 2m
        19 packages are looking for funding
          run `npm fund` for details
        npm notice
        npm notice New minor version of npm available! 8.1.2 -> 8.3.0
        npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.3.0>
        npm notice Run `npm install -g npm@8.3.0` to update!
        npm notice
        Checking for modules with removed libraries
        processing dependency changes for active modules with package.json files
        processing for module MMM-DHT-Sensor please wait
        npm ERR! code EINTEGRITY
        npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/ea/0f/a546dc24ba5ea99e7354a0e3a388be05355ffab78719fa8adfb1bd3127339805bb10a95582e594138f46a9366a29666551053598df5d0c4106dc1f1958de
        npm ERR! errno EINTEGRITY
        npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/jsonfile: Integrity verification failed for sha512-6g+lRtwkul6pnnNUoOOjiL4FNV/6t4cZ+orfsb0xJzOYBbsQqVWC5ZQTj0apNmopZmVRBTWY310MQQbcHxlY3g== (/home/pi/.npm/_cacache/content-v2/sha512/ea/0f/a546dc24ba5ea99e7354a0e3a388be05355ffab78719fa8adfb1bd3127339805bb10a95582e594138f46a9366a29666551053598df5d0c4106dc1f1958de)
        npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_52_46_753Z-debug.log
        processing complete for module MMM-DHT-Sensor
        processing for module MMM-Weather please wait
        > MMM-Weather@1.0.4 preinstall
        > installer/preinstall.sh
        Welcome to MMM-Weather
        Installing all npm libraries...
        added 1 package, and audited 2 packages in 2s
        processing complete for module MMM-Weather
        processing for module MMM-NowPlayingOnSpotify please wait
        npm WARN tarball cached data for aws4@https://registry.npmjs.org/aws4/-/aws4-1.11.0.tgz (sha512-xh1Rl34h6Fi1DC2WWKfxUTVqRsNnr6LsKz2+hfwDxQJWmrx8+c7ylaqBMcHfl1U1r2dsifOvKX3LQuLNZ+XSvA==) seems to be corrupted. Refreshing cache.
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 111 packages, and audited 674 packages in 1m
        2 packages are looking for funding
        41 vulnerabilities (1 low, 18 moderate, 14 high, 8 critical)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        processing complete for module MMM-NowPlayingOnSpotify
        processing for module MMM-Jast please wait
        added 261 packages, and audited 262 packages in 2m
        31 packages are looking for funding
        processing complete for module MMM-Jast
        processing for module MMM-TomTomTraffic please wait
        npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/14/8e/dcdade657854ccd5d610d29351bd6df101fb52d4d01a837451a7e30bb8d84671c63b2ea77d691763bd70d3f257138ec61bf857c7d487aae8205bca7b4f88
        npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/color-name: Integrity verification failed for sha512-FI7c2t5leFTM1dYQ0pNRvW3xAftS1NAag3RRp+MLuNhGccY7Lqd9aRdjvXDT8lcTjsYb+FfH1Ieq6CBbyntPiA== (/home/pi/.npm/_cacache/content-v2/sha512/14/8e/dcdade657854ccd5d610d29351bd6df101fb52d4d01a837451a7e30bb8d84671c63b2ea77d691763bd70d3f257138ec61bf857c7d487aae8205bca7b4f88)
        npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_56_18_973Z-debug.log
        processing complete for module MMM-TomTomTraffic
        processing for module MMM-MovieListings please wait
        added 47 packages, and audited 48 packages in 4s
        processing complete for module MMM-MovieListings
        processing for module MMM-soccer please wait
        npm ERR! path /home/pi/.npm/_cacache/content-v2/sha512/55/9d/0880334436e4cd6964d4caa6757e94f0fa27e66806cd75eaf698cc10016b007bf4e8ccb075d7dbf981ed0e475d529bea6bc174d3f9270e7f80ea8a5007a4
        npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/call-bind: Integrity verification failed for sha512-VZ0IgDNENuTNaWTUyqZ1fpTw+ifmaAbNder2mMwQAWsAe/TozLB119v5ge0OR11Sm+prwXTT+ScOf4DqilAHpA== (/home/pi/.npm/_cacache/content-v2/sha512/55/9d/0880334436e4cd6964d4caa6757e94f0fa27e66806cd75eaf698cc10016b007bf4e8ccb075d7dbf981ed0e475d529bea6bc174d3f9270e7f80ea8a5007a4)
        npm ERR!     /home/pi/.npm/_logs/2022-01-13T14_57_21_878Z-debug.log
        processing complete for module MMM-soccer
        processing for module MMM-MarineWeather please wait
        added 4 packages, and audited 5 packages in 2s
        processing complete for module MMM-MarineWeather
        processing for module MMM-Shom please wait
        added 2 packages, and audited 3 packages in 3s
        processing complete for module MMM-Shom
        processing for module MMM-Tools please wait
        added 3 packages, and audited 4 packages in 3s
        1 package is looking for funding
        processing complete for module MMM-Tools
        restoring custom.css
        we stashed a set of files that appear changed from the latest repo versions. you should review them
        see installers/stashed_files for the list
        you can use git checkout stash@{0} -- filename to extract one file from the stash
        or git stash pop to restore them all
        WARNING..
        WARNING.. either will overlay the file just installed by the update
        WARNING..
        pi@raspberrypi:~ $
        so everything is OK? Or do you have to do something more?
        I just have to do pm2 start?
          sdetweil @RIKKO14
          @rikko14 yes, just pm2 start… i don’t know what is causing the
          code EINTEGRITY
          errors…
          the more I look at it, the more it sounds like a networking problem
          I checked each reported bad file and I get them clean…
          on this
             package-lock.json
          any *-lock.json files do not need to be saved     <-----------
          do you want to save these files for later   (Y/n)?y  < --------- but you replied yes???
            RIKKO14
            it does not work …
            pi @ raspberrypi: ~ $ pm2 start
            [PM2] [ERROR] File ecosystem.config.js not found
              sdetweil @RIKKO14
              @rikko14 because of the changed node and npm version… do this
              pm2 update
                RIKKO14
                I do this :
                pi@raspberrypi:~ $ pm2 update
                Be sure to have the latest version by doing `npm install pm2@latest -g` before doing this procedure.
                [PM2] [v] Modules Stopped
                [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
                [PM2] [mm](0) ✓
                [PM2] [v] All Applications Stopped
                [PM2] [v] PM2 Daemon Stopped
                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                [PM2] Restoring processes located in /home/pi/.pm2/dump.pm2
                [PM2] Process /home/pi/mm.sh restored
                >>>>>>>>>> PM2 updated
                but nothing happens … the MM does not start
                same in the MM folder :
                pi@raspberrypi:~/MagicMirror $ pm2 update
                [PM2] PM2 Successfully daemonized
                [PM2][WARN] No process found
                >>>>>>>>>> PM2 updated
                │ id  │ name  │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                │ 0   │ mm    │ default     │ N/A     │ fork    │ N/A      │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
                  sdetweil @RIKKO14
                  @rikko14 and then pm2 start
                  pm2 update fixed the missing file
                    RIKKO14
                    same error :
                    pi@raspberrypi:~/MagicMirror $ pm2 start
                    [PM2][ERROR] File ecosystem.config.js not found
                    and
                    pi@raspberrypi:~ $ pm2 start
                      sdetweil @RIKKO14
                      @rikko14 ok, (when I said pm2 start, I assumed you would know to add the name or number , pm2 start 0)
                      do
                      pm2 save
                      pm2 start 0
                        RIKKO14
                        it works but I found this Electron problem … with a black screen :
                        see a the top right of my screen
                        • 2 / 5
