    how to update my MM
    45 Posts 3 Posters 22.2k Views 3 Watching
      RIKKO14
      it does not work …
      pi @ raspberrypi: ~ $ pm2 start
      [PM2] [ERROR] File ecosystem.config.js not found
        sdetweil @RIKKO14
        @rikko14 because of the changed node and npm version… do this
        pm2 update
          RIKKO14
          I do this :
          pi@raspberrypi:~ $ pm2 update
          Be sure to have the latest version by doing `npm install pm2@latest -g` before doing this procedure.
          [PM2] [v] Modules Stopped
          [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
          [PM2] [mm](0) ✓
          [PM2] [v] All Applications Stopped
          [PM2] [v] PM2 Daemon Stopped
          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
          [PM2] Restoring processes located in /home/pi/.pm2/dump.pm2
          [PM2] Process /home/pi/mm.sh restored
          >>>>>>>>>> PM2 updated
          but nothing happens … the MM does not start
          same in the MM folder :
          pi@raspberrypi:~/MagicMirror $ pm2 update
          [PM2] PM2 Successfully daemonized
          [PM2][WARN] No process found
          >>>>>>>>>> PM2 updated
          │ id  │ name  │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0   │ mm    │ default     │ N/A     │ fork    │ N/A      │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
            sdetweil @RIKKO14
            @rikko14 and then pm2 start
            pm2 update fixed the missing file
              RIKKO14
              same error :
              pi@raspberrypi:~/MagicMirror $ pm2 start
              [PM2][ERROR] File ecosystem.config.js not found
              and
              pi@raspberrypi:~ $ pm2 start
                sdetweil @RIKKO14
                @rikko14 ok, (when I said pm2 start, I assumed you would know to add the name or number , pm2 start 0)
                do
                pm2 save
                pm2 start 0
                  RIKKO14
                  it works but I found this Electron problem … with a black screen :
                  see a the top right of my screen
                    sdetweil @RIKKO14
                    @rikko14 black screen… yeh. I added code to fix that but the bad file format problems prevented
                    do
                    pm2 stop all
                    pm2 flush
                    pm2 start 0
                    wait til MM comes up
                    pm2 stop all
                    then do this (1st post is enough)
                    for each module reporting a missing library (there are more than 1 library potentially missing, so I don’t give you the exact command to issue, but teach you how to find the error and fix it from there)
                    then after fixing for all modules with problem,
                    (note you MAY have to repeat this looking thru the log part, I don’t know if they ALL will report, or if it will stop after the 1st error)
                    pm2 start 0
                      RIKKO14
                      I’m not sure I understood and did the right thing …:
                      pi@raspberrypi:~ $ pm2 stop all
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                      [PM2] [mm](0) ✓
                      │ 0   │ mm    │ default     │ N/A     │ fork    │ 0        │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
                      pi@raspberrypi:~ $ pm2 flush
                      [PM2] Flushing /home/pi/.pm2/pm2.log
                      [PM2] Flushing:
                      [PM2] /home/pi/.pm2/logs/mm-out.log
                      [PM2] /home/pi/.pm2/logs/mm-error.log
                      [PM2] Logs flushed
                      pi@raspberrypi:~ $ pm2 start 0
                      [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                      [PM2] [mm](0) ✓
                      [PM2] Process successfully started
                      │ 0   │ mm    │ default     │ N/A     │ fork    │ 29137    │ 0s     │ 0    │ online    │ 0%       │ 2.4mb    │ pi       │ disabled │
                      [PM2] [mm](0) ✓
                      pi@raspberrypi:~ $ npm init -y
                      Wrote to /home/pi/package.json:
                        "name": "pi",
                        "version": "1.0.0",
                        "description": "",
                        "main": "index.js",
                        "scripts": {
                          "test": "echo \"Error: no test specified\" && exit 1"
                        "keywords": [],
                        "author": "",
                        "license": "ISC"
                      pi@raspberrypi:~ $ npm install ???
                      npm ERR! code EINVALIDTAGNAME
                      npm ERR! Invalid tag name "???": Tags may not have any characters that encodeURIComponent encodes.
                      npm ERR!     /home/pi/.npm/_logs/2022-01-13T15_57_40_124Z-debug.log
                      pi@raspberrypi:~ $
                      • mumblebajM
                        @sdetweil Maybe combine the script and check if exist then update, else frsh install? Would that work?
                          sdetweil @RIKKO14
                          @rikko14 npm init -y
                          what is going on…
                          the instructions say
                          cd modulename (where modulename is the module having the error)
                          if the module does NOT provide a file called package.json, then do
                          npm init -y
                          why are you doing this in the users home folder?
                            RIKKO14
                            so i have to do first : cd ~/MagicMirror/ and after npm init -y that’s right ?
                              sdetweil @mumblebaj
                              @mumblebaj said in how to update my MM:
                              what? check if what exist?
                              the problem here is that i looped thru all the installed modules, and found a package.json, which now requires a new
                              npm install
                              in the module folder, BUT, the npm install failed cause of the networking problem
                              one that is finished, I loop thru all the modules and check to see if they use one of the troublesome libraries
                              and do NOT reference it in package.json…
                              and if NO package.json, then I create one, and THEN do the npm install of the library
                              phew, all the same as the instructions i gave in the linked topic.
                              but there might be ANOTHER library too … that I don’t handle…
                                sdetweil @RIKKO14
                                @rikko14 it says
                                to fix this you need to install the library in the module folder
                                cd ~/MagicMirror/modules
                                SO, you have to cd ~/MagicMirror/modules/modulename
                                same as every other time you were told to cd modulename
                                  RIKKO14
                                  I’m lost …
                                  here are all the modules I have installed.
                                  I have to do: cd ~ / MagicMirror / modules / modulename for each module and then npm init -y ?
                                  and post here all the results of npm init -y ?
                                  I have already had this Electron problem several times and I do not remember what I had typed as the command line but it was not that
                                  • mumblebajM
                                    @sdetweil said in how to update my MM:
                                    What I was referring to is for a single script to run, check if MagicMirror exist, check version and upgrade if not on the latest, if not exist then do a fresh install. This way whoever runs your script does not run the wrong one. Just a suggestion.
                                      sdetweil @RIKKO14
                                      @rikko14 look in the pm2 logs output
                                      search for Cannot find module
                                      sorry for the dual use of the word module. NPM calls the library a module and MagicMirror calls its app a module…
                                      after that string, there will be a name in quotes ‘request’ or ‘valid-url’, or maybe something else
                                      on one of the next lines will be a file path
                                      MagicMirror/modules/??? some MagicMirror module name
                                      THAT is the MagicMirror module which is missing the library found in the 'Cannot find module ’ message above
                                      So, navigate to that MagicMirror module folder
                                      and then look for the package.json file
                                      ls package.json
                                      if you get ‘No such file or directory’ in response to the ls command, then create the file by doing
                                      npm init -y
                                      next step,
                                      npm install ???
                                      where ??? is the name of the missing library in the message ’ Cannot find module ’
                                      done for this library for this MM module
                                        sdetweil @mumblebaj
                                        @mumblebaj oh… no… don’t want to get into that
                                        they are two distinct functions… users have to learn sometime
                                        • mumblebajM
                                          @sdetweil :-) I understand. But it would make your life easier with running the wrong script, messing up their install and you having to go through a 100 different things for them to do to get it fixed… :-)
                                            sdetweil @mumblebaj
                                            @mumblebaj they can’t mess up their install …
                                            install aborted as already present
                                            upgrade won’t change anything unless you ask for it.
                                            and it won’t try to upgrade to the same version, unless you report it and I tell you how to get around it.
                                            (I am constantly finding things that users don’t understand, and trying to make life easier as best I can)
                                            this particular problem is unrelated to the scripts…
                                            it was caused by a networking problem I can’t fix.
                                            and I don’t know if all this will work .
                                            • 2 / 3
