    how to update my MM
    45 Posts 3 Posters 22.7k Views 3 Watching
      sdetweil @RIKKO14
      @rikko14 npm init -y
      what is going on…
      the instructions say
      cd modulename (where modulename is the module having the error)
      if the module does NOT provide a file called package.json, then do
      npm init -y
      why are you doing this in the users home folder?
        RIKKO14
        so i have to do first : cd ~/MagicMirror/ and after npm init -y that’s right ?
          sdetweil @mumblebaj
          @mumblebaj said in how to update my MM:
          Maybe combine the script and check if exist then update, else frsh install? Would that work?
          what? check if what exist?
          the problem here is that i looped thru all the installed modules, and found a package.json, which now requires a new
          npm install
          in the module folder, BUT, the npm install failed cause of the networking problem
          one that is finished, I loop thru all the modules and check to see if they use one of the troublesome libraries
          and do NOT reference it in package.json…
          and if NO package.json, then I create one, and THEN do the npm install of the library
          phew, all the same as the instructions i gave in the linked topic.
          but there might be ANOTHER library too … that I don’t handle…
          mumblebajM 1 Reply Last reply
            sdetweil @RIKKO14
            @rikko14 it says
            to fix this you need to install the library in the module folder
            cd ~/MagicMirror/modules
            SO, you have to cd ~/MagicMirror/modules/modulename
            same as every other time you were told to cd modulename
              RIKKO14
              I’m lost …
              here are all the modules I have installed.
              I have to do: cd ~ / MagicMirror / modules / modulename for each module and then npm init -y ?
              and post here all the results of npm init -y ?
              I have already had this Electron problem several times and I do not remember what I had typed as the command line but it was not that
              • mumblebajM
                @sdetweil said in how to update my MM:
                What I was referring to is for a single script to run, check if MagicMirror exist, check version and upgrade if not on the latest, if not exist then do a fresh install. This way whoever runs your script does not run the wrong one. Just a suggestion.
                  sdetweil @RIKKO14
                  @rikko14 look in the pm2 logs output
                  search for Cannot find module
                  sorry for the dual use of the word module. NPM calls the library a module and MagicMirror calls its app a module…
                  after that string, there will be a name in quotes ‘request’ or ‘valid-url’, or maybe something else
                  on one of the next lines will be a file path
                  MagicMirror/modules/??? some MagicMirror module name
                  THAT is the MagicMirror module which is missing the library found in the 'Cannot find module ’ message above
                  So, navigate to that MagicMirror module folder
                  and then look for the package.json file
                  ls package.json
                  if you get ‘No such file or directory’ in response to the ls command, then create the file by doing
                  npm init -y
                  next step,
                  npm install ???
                  where ??? is the name of the missing library in the message ’ Cannot find module ’
                  done for this library for this MM module
                    sdetweil @mumblebaj
                    @mumblebaj oh… no… don’t want to get into that
                    they are two distinct functions… users have to learn sometime
                    • mumblebajM
                      @sdetweil :-) I understand. But it would make your life easier with running the wrong script, messing up their install and you having to go through a 100 different things for them to do to get it fixed… :-)
                        sdetweil @mumblebaj
                        @mumblebaj they can’t mess up their install …
                        install aborted as already present
                        upgrade won’t change anything unless you ask for it.
                        and it won’t try to upgrade to the same version, unless you report it and I tell you how to get around it.
                        (I am constantly finding things that users don’t understand, and trying to make life easier as best I can)
                        this particular problem is unrelated to the scripts…
                        it was caused by a networking problem I can’t fix.
                        and I don’t know if all this will work .
                          RIKKO14
                          I do this for the first modul :
                          pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-DHT-Sensor
                          pi@raspberrypi:~/MagicMirror/modules/MMM-DHT-Sensor $ ls package.json
                          package.json
                          i do this : npm init -y ?
                            sdetweil @RIKKO14
                            @rikko14 no. the file exists.
                            only do npm init -y if the file does NOT exist
                              RIKKO14
                              @sdetweil as you told me, I do cd ~/MagicMirror/modules/modulename for each module.
                              I found an error in the last module : MMM-WeatherOrNot, a module that I no longer use so I deleted it with the command : cd ~ / MagicMirror and rm -rf modules / MMM-WeatherOrNot then i redid pm2 save and pm2 start 0 and turned the MM off and on again with ~ 1 minute but I still have a black screen and an electron problem.
                              what to do ?
                              • mumblebajM
                                mumblebaj Module Developer @RIKKO14
                                @rikko14 Can you run the following command and post the output please?
                                grep -r -E '('request')' ~/MagicMirror/modules/*/*.js
                                Or post the pm2 logs again? There must be a module that is missing a module as per what Sam advised previously. Let us see if we can find the module that is broken.
                                  RIKKO14
                                  pi@raspberrypi:~ $ grep -r -E '('request')' ~/MagicMirror/modules/*/*.js
                                  /home/pi/MagicMirror/modules/MMM-Jast/node_helper.js:(()=>{"use strict";var e={944:function(e,t,o){var r=this&&this.__awaiter||function(e,t,o,r){return new(o||(o=Promise))((function(n,i){function s(e){try{c(r.next(e))}catch(e){i(e)}}function a(e){try{c(r.throw(e))}catch(e){i(e)}}function c(e){var t;e.done?n(e.value):(t=e.value,t instanceof o?t:new o((function(e){e(t)}))).then(s,a)}c((r=r.apply(e,t||[])).next())}))};Object.defineProperty(t,"__esModule",{value:!0});const n=o(543),i=o(61);e.exports=n.create({start(){console.log(`${this.name} helper method started...`)},requestStocks(e){return r(this,void 0,void 0,(function*(){let t=[];for(const o of e.stocks)try{const{summaryDetail:e,price:r}=yield i.default.quoteSummary(o.symbol);if(e&&r){const n={symbol:o.symbol,name:o.name,quantity:o.quantity};t.push({summaryDetail:e,price:r,meta:n})}}catch(e){console.error("There was an error requesting the API.",e.message)}return t}))},socketNotificationReceived(e,t){return r(this,void 0,void 0,(function*(){if(e){const e=yield this.requestStocks(t);this.sendSocketNotification("STOCKS_RESULT",e)}else console.warn(`${e} is invalid notification`)}))}})},543:e=>{e.exports=require("node_helper")},61:e=>{e.exports=require("yahoo-finance2")}},t={},o=function o(r){var n=t[r];if(void 0!==n)return n.exports;var i=t[r]={exports:{}};return e[r].call(i.exports,i,i.exports,o),i.exports}(944);module.exports=o})();
                                  /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js:var request = require('request');
                                  /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js:    request(
                                  /home/pi/MagicMirror/modules/MMM-soccer/MMM-soccer.js:     * @description Adds nunjuck filters and requests for league data.
                                  /home/pi/MagicMirror/modules/MMM-soccer/MMM-soccer.js:     * @description Sends request to the node_helper to fetch data for the current selected league.
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @external request
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @see https://www.npmjs.com/package/request
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:const request = require('request');
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @requires external:request
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:     * @param {Object} options - request optionsthe notification.
                                  /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:        request(options, (error, response, body) => {
                                  /home/pi/MagicMirror/modules/MMM-TomTomTraffic/MMM-TomTomTraffic.js:    // Instead, on the first dom request, add a <script> tag and trigger a dom refresh
                                  pi@raspberrypi:~ $
                                  I do not remember anymore how to post the pm2 logs
                                  • mumblebajM
                                    @rikko14 So now you now that 2 modules require the module request. Please run the following scripts so we can determine which modules do not have request installed and post the output.
                                    find ~/MagicMirror/modules/* -type d -name request
                                      RIKKO14
                                      @mumblebaj
                                      pi@raspberrypi:~ $ find ~/MagicMirror/modules/* -type d -name request
                                      /home/pi/MagicMirror/modules/MMM-MovieListings/node_modules/request
                                      /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request
                                      /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/npm/node_modules/request
                                      pi@raspberrypi:~ $
                                      • mumblebajM
                                        @rikko14 From this output, their is one module that uses the request module that is not listed. In that module folder you now need to go and install request using the steps that Sam provided you.
                                          RIKKO14
                                          @mumblebaj i do this :
                                          pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-NowPlayingOnSpotify
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ ls package.json
                                          package.json
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ npm init -y
                                          Wrote to /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/package.json:
                                            "name": "mmm-nowplayingonspotify",
                                            "version": "1.0.0",
                                            "description": "A module for MagicMirror 2 displaying the currently playing song on Spotify.",
                                            "repository": {
                                              "type": "git",
                                              "url": "git+https://github.com/raywo/MMM-NowPlayingOnSpotify.git"
                                            "keywords": [
                                              "magic mirror",
                                              "magic mirror 2",
                                              "smart mirror",
                                              "spotify",
                                              "module"
                                            "author": "raywo <ray@skillbird.de> (https://github.com/raywo)",
                                            "contributors": [
                                              "https://github.com/raywo/MMM-NowPlayingOnSpotify/graphs/contributors"
                                            "license": "MIT",
                                            "bugs": {
                                              "url": "https://github.com/raywo/MMM-NowPlayingOnSpotify/issues"
                                            "homepage": "https://github.com/raywo/MMM-NowPlayingOnSpotify",
                                            "engines": {
                                              "node": ">=7"
                                            "dependencies": {
                                              "cookie-parser": "1.4.3",
                                              "express": "~4.16.0",
                                              "moment-duration-format": "^2.2.2",
                                              "npm": "^5.7.1",
                                              "querystring": "~0.2.0",
                                              "request": "^2.83.0",
                                              "request-promise-native": "^1.0.5",
                                              "body-parser": "^1.18.2"
                                            "main": "MMM-NowPlayingOnSpotify.js",
                                            "devDependencies": {},
                                            "scripts": {
                                              "test": "echo \"Error: no test specified\" && exit 1"
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ cd ~/MagicMirror/modules/MMM-MovieListings
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-MovieListings $ ls package.json
                                          package.json
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-MovieListings $ npm init -y
                                          Wrote to /home/pi/MagicMirror/modules/MMM-MovieListings/package.json:
                                            "name": "mmm-movielistings",
                                            "version": "1.0.0",
                                            "description": "MagicMirror module for current movie listing playing in theaters",
                                            "main": "MMM-MovieListings.js",
                                            "scripts": {
                                            "author": "Christian Jens",
                                            "license": "MIT",
                                            "dependencies": {
                                              "request": "^2.81.0"
                                            "repository": {
                                              "type": "git",
                                              "url": "git+https://github.com/Tueti/MMM-MovieListings.git"
                                            "keywords": [],
                                            "bugs": {
                                              "url": "https://github.com/Tueti/MMM-MovieListings/issues"
                                            "homepage": "https://github.com/Tueti/MMM-MovieListings#readme"
                                          but the problem remains the same (black screen et Electron problem)
                                            RIKKO14
                                            any solutions ?
                                            • 2 / 3
