how to update my MM
@sdetweil said in how to update my MM:
what? check if what exist?
What I was referring to is for a single script to run, check if MagicMirror exist, check version and upgrade if not on the latest, if not exist then do a fresh install. This way whoever runs your script does not run the wrong one. Just a suggestion.
@rikko14 look in the pm2 logs output
search for Cannot find module
sorry for the dual use of the word module. NPM calls the library a module and MagicMirror calls its app a module…
after that string, there will be a name in quotes ‘request’ or ‘valid-url’, or maybe something else
on one of the next lines will be a file path
MagicMirror/modules/??? some MagicMirror module name
THAT is the MagicMirror module which is missing the library found in the 'Cannot find module ’ message above
So, navigate to that MagicMirror module folder
cd ~/MagicMirror/modules/modulenameand then look for the package.json file
ls package.jsonif you get ‘No such file or directory’ in response to the ls command, then create the file by doing
npm init -ynext step,
npm install ???
where ??? is the name of the missing library in the message ’ Cannot find module ’done for this library for this MM module
@mumblebaj oh… no… don’t want to get into that
they are two distinct functions… users have to learn sometime
@sdetweil :-) I understand. But it would make your life easier with running the wrong script, messing up their install and you having to go through a 100 different things for them to do to get it fixed… :-)
@mumblebaj they can’t mess up their install …
install aborted as already present
upgrade won’t change anything unless you ask for it.
and it won’t try to upgrade to the same version, unless you report it and I tell you how to get around it.
(I am constantly finding things that users don’t understand, and trying to make life easier as best I can)this particular problem is unrelated to the scripts…
it was caused by a networking problem I can’t fix.
and I don’t know if all this will work . -
I do this for the first modul :
pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-DHT-Sensor pi@raspberrypi:~/MagicMirror/modules/MMM-DHT-Sensor $ ls package.json package.json pi@raspberrypi:~/MagicMirror/modules/MMM-DHT-Sensor $i do this :
npm init -y? -
@rikko14 no. the file exists.
only do npm init -y if the file does NOT exist
@sdetweil as you told me, I do
cd ~/MagicMirror/modules/modulenamefor each module.
I found an error in the last module : MMM-WeatherOrNot, a module that I no longer use so I deleted it with the command :cd ~ / MagicMirrorandrm -rf modules / MMM-WeatherOrNotthen i redid pm2 save and pm2 start 0 and turned the MM off and on again with ~ 1 minute but I still have a black screen and an electron problem.
what to do ?
@rikko14 Can you run the following command and post the output please?
grep -r -E '('request')' ~/MagicMirror/modules/*/*.jsOr post the pm2 logs again? There must be a module that is missing a module as per what Sam advised previously. Let us see if we can find the module that is broken.
pi@raspberrypi:~ $ grep -r -E '('request')' ~/MagicMirror/modules/*/*.js /home/pi/MagicMirror/modules/MMM-Jast/node_helper.js:(()=>{"use strict";var e={944:function(e,t,o){var r=this&&this.__awaiter||function(e,t,o,r){return new(o||(o=Promise))((function(n,i){function s(e){try{c(r.next(e))}catch(e){i(e)}}function a(e){try{c(r.throw(e))}catch(e){i(e)}}function c(e){var t;e.done?n(e.value):(t=e.value,t instanceof o?t:new o((function(e){e(t)}))).then(s,a)}c((r=r.apply(e,t||[])).next())}))};Object.defineProperty(t,"__esModule",{value:!0});const n=o(543),i=o(61);e.exports=n.create({start(){console.log(`${this.name} helper method started...`)},requestStocks(e){return r(this,void 0,void 0,(function*(){let t=[];for(const o of e.stocks)try{const{summaryDetail:e,price:r}=yield i.default.quoteSummary(o.symbol);if(e&&r){const n={symbol:o.symbol,name:o.name,quantity:o.quantity};t.push({summaryDetail:e,price:r,meta:n})}}catch(e){console.error("There was an error requesting the API.",e.message)}return t}))},socketNotificationReceived(e,t){return r(this,void 0,void 0,(function*(){if(e){const e=yield this.requestStocks(t);this.sendSocketNotification("STOCKS_RESULT",e)}else console.warn(`${e} is invalid notification`)}))}})},543:e=>{e.exports=require("node_helper")},61:e=>{e.exports=require("yahoo-finance2")}},t={},o=function o(r){var n=t[r];if(void 0!==n)return n.exports;var i=t[r]={exports:{}};return e[r].call(i.exports,i,i.exports,o),i.exports}(944);module.exports=o})(); /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js:var request = require('request'); /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js: request( /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js: request( /home/pi/MagicMirror/modules/MMM-MovieListings/node_helper.js: request( /home/pi/MagicMirror/modules/MMM-soccer/MMM-soccer.js: * @description Adds nunjuck filters and requests for league data. /home/pi/MagicMirror/modules/MMM-soccer/MMM-soccer.js: * @description Sends request to the node_helper to fetch data for the current selected league. /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @external request /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @see https://www.npmjs.com/package/request /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:const request = require('request'); /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @requires external:request /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: * @param {Object} options - request optionsthe notification. /home/pi/MagicMirror/modules/MMM-soccer/node_helper.js: request(options, (error, response, body) => { /home/pi/MagicMirror/modules/MMM-TomTomTraffic/MMM-TomTomTraffic.js: // Instead, on the first dom request, add a <script> tag and trigger a dom refresh pi@raspberrypi:~ $I do not remember anymore how to post the pm2 logs
@rikko14 So now you now that 2 modules require the module request. Please run the following scripts so we can determine which modules do not have request installed and post the output.
find ~/MagicMirror/modules/* -type d -name request -
pi@raspberrypi:~ $ find ~/MagicMirror/modules/* -type d -name request /home/pi/MagicMirror/modules/MMM-MovieListings/node_modules/request /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/npm/node_modules/request pi@raspberrypi:~ $ -
@rikko14 From this output, their is one module that uses the request module that is not listed. In that module folder you now need to go and install request using the steps that Sam provided you.
@mumblebaj i do this :
pi@raspberrypi:~ $ find ~/MagicMirror/modules/* -type d -name request /home/pi/MagicMirror/modules/MMM-MovieListings/node_modules/request /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/npm/node_modules/request pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-NowPlayingOnSpotify pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ ls package.json package.json pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ npm init -y Wrote to /home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/package.json: { "name": "mmm-nowplayingonspotify", "version": "1.0.0", "description": "A module for MagicMirror 2 displaying the currently playing song on Spotify.", "repository": { "type": "git", "url": "git+https://github.com/raywo/MMM-NowPlayingOnSpotify.git" }, "keywords": [ "magic mirror", "magic mirror 2", "smart mirror", "spotify", "module" ], "author": "raywo <ray@skillbird.de> (https://github.com/raywo)", "contributors": [ "https://github.com/raywo/MMM-NowPlayingOnSpotify/graphs/contributors" ], "license": "MIT", "bugs": { "url": "https://github.com/raywo/MMM-NowPlayingOnSpotify/issues" }, "homepage": "https://github.com/raywo/MMM-NowPlayingOnSpotify", "engines": { "node": ">=7" }, "dependencies": { "cookie-parser": "1.4.3", "express": "~4.16.0", "moment-duration-format": "^2.2.2", "npm": "^5.7.1", "querystring": "~0.2.0", "request": "^2.83.0", "request-promise-native": "^1.0.5", "body-parser": "^1.18.2" }, "main": "MMM-NowPlayingOnSpotify.js", "devDependencies": {}, "scripts": { "test": "echo \"Error: no test specified\" && exit 1" } } pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingOnSpotify $ cd ~/MagicMirror/modules/MMM-MovieListings pi@raspberrypi:~/MagicMirror/modules/MMM-MovieListings $ ls package.json package.json pi@raspberrypi:~/MagicMirror/modules/MMM-MovieListings $ npm init -y Wrote to /home/pi/MagicMirror/modules/MMM-MovieListings/package.json: { "name": "mmm-movielistings", "version": "1.0.0", "description": "MagicMirror module for current movie listing playing in theaters", "main": "MMM-MovieListings.js", "scripts": { "test": "echo \"Error: no test specified\" && exit 1" }, "author": "Christian Jens", "license": "MIT", "dependencies": { "request": "^2.81.0" }, "devDependencies": {}, "repository": { "type": "git", "url": "git+https://github.com/Tueti/MMM-MovieListings.git" }, "keywords": [], "bugs": { "url": "https://github.com/Tueti/MMM-MovieListings/issues" }, "homepage": "https://github.com/Tueti/MMM-MovieListings#readme" } pi@raspberrypi:~/MagicMirror/modules/MMM-MovieListings $but the problem remains the same (black screen et Electron problem)
any solutions ?
@rikko14 You are missing the steps the sdeitwel provided. If the pacskage.json exists then you DO NOT run the
npm init -ycommand. You must only run thenpm install requestcommand. You would or should have noticed that MMM-MovieListings already has request installed. -
@rikko14 Just a final hint. The only module that seems to have a problem is MMM-soccer. You can check that module to see if it has a package.json. If it does then DO NOT run the
npm init -y. However, looking at the MMM-soccer module on Github it has been updated to use node-fetch. You probably need to do agit pull && npm installin the MMM-soccer module folder to get the latest version of the module.Then start the mirror with pm2.
pm2 start mmor however you start it with pm2. thenpm2 stopand thenpm2 log --lines 100and post the log output if you are still experiencing the black screen.
