    how to update my MM
    45 Posts 3 Posters 16.7k Views 3 Watching
      sdetweil @RIKKO14
      @rikko14 black screen… yeh. I added code to fix that but the bad file format problems prevented
      do
      pm2 stop all
      pm2 flush
      pm2 start 0
      wait til MM comes up
      pm2 stop all
      then do this (1st post is enough)
      for each module reporting a missing library (there are more than 1 library potentially missing, so I don’t give you the exact command to issue, but teach you how to find the error and fix it from there)
      then after fixing for all modules with problem,
      (note you MAY have to repeat this looking thru the log part, I don’t know if they ALL will report, or if it will stop after the 1st error)
      pm2 start 0
        RIKKO14
        I’m not sure I understood and did the right thing …:
        pi@raspberrypi:~ $ pm2 stop all
        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
        [PM2] [mm](0) ✓
        │ id  │ name  │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 0   │ mm    │ default     │ N/A     │ fork    │ 0        │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
        pi@raspberrypi:~ $ pm2 flush
        [PM2] Flushing /home/pi/.pm2/pm2.log
        [PM2] Flushing:
        [PM2] /home/pi/.pm2/logs/mm-out.log
        [PM2] /home/pi/.pm2/logs/mm-error.log
        [PM2] Logs flushed
        pi@raspberrypi:~ $ pm2 start 0
        [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
        [PM2] [mm](0) ✓
        [PM2] Process successfully started
        │ 0   │ mm    │ default     │ N/A     │ fork    │ 29137    │ 0s     │ 0    │ online    │ 0%       │ 2.4mb    │ pi       │ disabled │
        [PM2] [mm](0) ✓
        pi@raspberrypi:~ $ npm init -y
        Wrote to /home/pi/package.json:
          "name": "pi",
          "version": "1.0.0",
          "description": "",
          "main": "index.js",
          "scripts": {
            "test": "echo \"Error: no test specified\" && exit 1"
          "keywords": [],
          "author": "",
          "license": "ISC"
        pi@raspberrypi:~ $ npm install ???
        npm ERR! code EINVALIDTAGNAME
        npm ERR! Invalid tag name "???": Tags may not have any characters that encodeURIComponent encodes.
        npm ERR!     /home/pi/.npm/_logs/2022-01-13T15_57_40_124Z-debug.log
        pi@raspberrypi:~ $
        • mumblebajM Offline
          mumblebaj Module Developer @sdetweil
          @sdetweil Maybe combine the script and check if exist then update, else frsh install? Would that work?
            sdetweil @RIKKO14
            @rikko14 npm init -y
            what is going on…
            the instructions say
            cd modulename (where modulename is the module having the error)
            if the module does NOT provide a file called package.json, then do
            npm init -y
            why are you doing this in the users home folder?
              RIKKO14
              so i have to do first : cd ~/MagicMirror/ and after npm init -y that’s right ?
                sdetweil @mumblebaj
                @mumblebaj said in how to update my MM:
                what? check if what exist?
                the problem here is that i looped thru all the installed modules, and found a package.json, which now requires a new
                npm install
                in the module folder, BUT, the npm install failed cause of the networking problem
                one that is finished, I loop thru all the modules and check to see if they use one of the troublesome libraries
                and do NOT reference it in package.json…
                and if NO package.json, then I create one, and THEN do the npm install of the library
                phew, all the same as the instructions i gave in the linked topic.
                but there might be ANOTHER library too … that I don’t handle…
                  sdetweil @RIKKO14
                  @rikko14 it says
                  to fix this you need to install the library in the module folder
                  cd ~/MagicMirror/modules
                  SO, you have to cd ~/MagicMirror/modules/modulename
                  same as every other time you were told to cd modulename
                    RIKKO14
                    I’m lost …
                    here are all the modules I have installed.
                    I have to do: cd ~ / MagicMirror / modules / modulename for each module and then npm init -y ?
                    and post here all the results of npm init -y ?
                    I have already had this Electron problem several times and I do not remember what I had typed as the command line but it was not that
                      @sdetweil said in how to update my MM:
                      What I was referring to is for a single script to run, check if MagicMirror exist, check version and upgrade if not on the latest, if not exist then do a fresh install. This way whoever runs your script does not run the wrong one. Just a suggestion.
                        sdetweil @RIKKO14
                        @rikko14 look in the pm2 logs output
                        search for Cannot find module
                        sorry for the dual use of the word module. NPM calls the library a module and MagicMirror calls its app a module…
                        after that string, there will be a name in quotes ‘request’ or ‘valid-url’, or maybe something else
                        on one of the next lines will be a file path
                        MagicMirror/modules/??? some MagicMirror module name
                        THAT is the MagicMirror module which is missing the library found in the 'Cannot find module ’ message above
                        So, navigate to that MagicMirror module folder
                        and then look for the package.json file
                        ls package.json
                        if you get ‘No such file or directory’ in response to the ls command, then create the file by doing
                        npm init -y
                        next step,
                        npm install ???
                        where ??? is the name of the missing library in the message ’ Cannot find module ’
                        done for this library for this MM module
                        • 3 / 5
