    Calendar error ???
    5 Posts 2 Posters 1.2k Views 2 Watching
    • AssassinsA Offline
      Assassins
      Anyone know how to fix this little calendar bug.
      When you set it to a “Full Day Event” it sets the date to “Feb 7.”,
      but if you set it to a “time limit” it sets to “07 / 02/2022”
      I have already put this in config
      dateFormat: ‘DD / MM / YYYY’
      See the picture for more information.
      Regards Assassins
        sdetweil @Assassins
        @assassins there is a full date format too… see the doc
        AssassinsA 1 Reply Last reply Reply Quote 0
          Assassins @sdetweil
          This is my config to it :
          module: ‘calendar’,
          header: “Kalender”,
          position: ‘bottom_left’,
          timeFormat: 24,
          dateFormat: ‘DD/MM/YYYY’,
          colored: true,
          showLocation: true,
          maximumNumberOfDays: 90,
          maximumEntries: 7,
          symbol: ‘calendar’,
          url: ‘http://localhost:8080/modules/calendars/home.ics’,
          color: ‘#5bc0de’
          Have i forget somthing to the format. ???
            sdetweil @Assassins
            @assassins see
            https://docs.magicmirror.builders/modules/calendar.html#configuration-options
              Assassins @sdetweil
              fullDayEventDateFormat:
              work now, thanks
