    Can't See Calendar, New Feed and To Do List Module ;(
    13 Posts 2 Posters 1.1k Views 2 Watching
    • L Offline
      lina-ja
      I already asked the same question here but
      this is the big problem that I want to solve asap, so I’m asking in this community too.
      I Can’t See Calendar, News Feed and To-Do List Module.
      This is the message from the terminal.
      21.01.2022 14:49.20.550] [WARN] You're using a full whitelist configuration to allow for all IPs [21.01.2022 14:49.20.561] [LOG] Server started ... [21.01.2022 14:49.20.563] [LOG] Connecting socket for: calendar [21.01.2022 14:49.20.565] [LOG] Starting node helper for: calendar [21.01.2022 14:49.20.566] [LOG] Connecting socket for: MMM-FastNotes [21.01.2022 14:49.20.567] [LOG] Starting module helper: MMM-FastNotes [21.01.2022 14:49.20.568] [LOG] Connecting socket for: newsfeed [21.01.2022 14:49.20.569] [LOG] Starting node helper for: newsfeed [21.01.2022 14:49.20.570] [LOG] Connecting socket for: MMM-Remote-Control [21.01.2022 14:49.20.571] [LOG] Starting node helper for: MMM-Remote-Control [21.01.2022 14:49.20.579] [LOG] Connecting socket for: MMM-Todoist [21.01.2022 14:49.20.580] [LOG] Starting node helper for: MMM-Todoist [21.01.2022 14:49.20.581] [LOG] Connecting socket for: MMM-GooglePhotos [21.01.2022 14:49.20.582] [LOG] Connecting socket for: MMM-awesome-alexa [21.01.2022 14:49.20.583] [LOG] Sockets connected & modules started ... [21.01.2022 14:49.20.584] [LOG] Ready to go! Please point your browser to: http://192.168.11.10:8080 [21.01.2022 14:49.43.000] [LOG] Create new calendarfetcher for URL: [HIDE] - Interval: 300000 [21.01.2022 14:49.43.096] [LOG] Create new newsfetcher for url: https://news.yahoo.co.jp/rss/topics/it.xml - Interval: 300000 [21.01.2022 14:49.43.437] [INFO] Newsfeed-Fetcher: Broadcasting 8 items. [21.01.2022 14:49.44.483] [INFO] Calendar-Fetcher: Broadcasting 7 events. [21.01.2022 14:54.43.592] [INFO] Newsfeed-Fetcher: Broadcasting 8 items. [21.01.2022 14:54.45.867] [INFO] Calendar-Fetcher: Broadcasting 7 events. [21.01.2022 14:59.43.727] [INFO] Newsfeed-Fetcher: Broadcasting 8 items. [21.01.2022 14:59.47.143] [INFO] Calendar-Fetcher: Broadcasting 7 events.
      I hide the URL of the calendar but I checked this link is shared successfully.
      These modules were shown before 2 days ago.
      But just changed the place and connected to another Wi-Fi these are disappeared.
      I didn’t change anything.
      But other modules are working as usual!!
      Plz, Help Me and give me any advice…
      I already updated the version of Magic Mirror.
      I have no idea now…
      Thx for your help.
        sdetweil @lina-ja
        @lina-ja can u show all the output of the npm start ?
        if you use pm2, then
        pm2 logs --lines=???
        ??? defaults to 15, u may need 50 or 100
        these all use a server side component to get the content…
        also open the developers window, on the pi do
        ctrl-shift-i
        and select the tab labeled console
        and scroll up to see any errors (usually red text)
        • L Offline
          lina-ja @sdetweil
          Thank you for your reply!
          Here is all output of my terminal when I run the “npm run server”.
          I do not think I’m using pm2… (Sorry I’m a beginner ;( )
          pi@raspberrypi:~/MagicMirror $ npm run server
          > magicmirror@2.17.1 server /home/pi/MagicMirror
          > node ./serveronly
          [21.01.2022 22:56.39.130] [LOG]   Starting MagicMirror: v2.17.1
          [21.01.2022 22:56.39.136] [LOG]   Loading config ...
          [21.01.2022 22:56.39.142] [LOG]   Loading module helpers ...
          [21.01.2022 22:56.39.145] [LOG]   No helper found for module: alert.
          [21.01.2022 22:56.39.146] [LOG]   No helper found for module: clock.
          [21.01.2022 22:56.39.329] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.39.330] [LOG]   Module helper loaded: calendar
          [21.01.2022 22:56.39.331] [LOG]   No helper found for module: weather.
          [21.01.2022 22:56.39.610] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.39.611] [LOG]   Module helper loaded: MMM-FastNotes
          [21.01.2022 22:56.39.643] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.39.644] [LOG]   Module helper loaded: newsfeed
          [21.01.2022 22:56.39.870] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.39.871] [LOG]   Module helper loaded: MMM-Remote-Control
          [21.01.2022 22:56.40.199] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.40.201] [LOG]   Module helper loaded: MMM-Todoist
          [21.01.2022 22:56.40.462] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.40.463] [LOG]   Module helper loaded: MMM-GooglePhotos
          [21.01.2022 22:56.40.464] [LOG]   No helper found for module: MMM-MonthCalendar.
          [21.01.2022 22:56.40.465] [LOG]   No helper found for module: MMM-WeeklySchedule.
          [21.01.2022 22:56.41.302] [LOG]   Initializing new module helper ...
          [21.01.2022 22:56.41.303] [LOG]   Module helper loaded: MMM-awesome-alexa
          [21.01.2022 22:56.41.304] [LOG]   All module helpers loaded.
          [21.01.2022 22:56.41.395] [LOG]   Starting server on port 8080 ...
          [21.01.2022 22:56.41.399] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [21.01.2022 22:56.41.409] [LOG]   Server started ...
          [21.01.2022 22:56.41.411] [LOG]   Connecting socket for: calendar
          [21.01.2022 22:56.41.412] [LOG]   Starting node helper for: calendar
          [21.01.2022 22:56.41.413] [LOG]   Connecting socket for: MMM-FastNotes
          [21.01.2022 22:56.41.414] [LOG]   Starting module helper: MMM-FastNotes
          [21.01.2022 22:56.41.415] [LOG]   Connecting socket for: newsfeed
          [21.01.2022 22:56.41.416] [LOG]   Starting node helper for: newsfeed
          [21.01.2022 22:56.41.417] [LOG]   Connecting socket for: MMM-Remote-Control
          [21.01.2022 22:56.41.418] [LOG]   Starting node helper for: MMM-Remote-Control
          [21.01.2022 22:56.41.426] [LOG]   Connecting socket for: MMM-Todoist
          [21.01.2022 22:56.41.427] [LOG]   Starting node helper for: MMM-Todoist
          [21.01.2022 22:56.41.428] [LOG]   Connecting socket for: MMM-GooglePhotos
          [21.01.2022 22:56.41.430] [LOG]   Connecting socket for: MMM-awesome-alexa
          [21.01.2022 22:56.41.431] [LOG]   Sockets connected & modules started ...
          [21.01.2022 22:56.41.432] [LOG]
          [21.01.2022 22:56.46.487] [LOG]   Create new calendarfetcher for URL: [HIDE URL] - Interval: 300000
          [21.01.2022 22:56.46.629] [LOG]   Create new newsfetcher for url: https://news.yahoo.co.jp/rss/topics/it.xml - Interval: 300000
          [21.01.2022 22:56.46.911] [INFO]  Newsfeed-Fetcher: Broadcasting 8 items.
          [21.01.2022 22:56.48.341] [INFO]  Calendar-Fetcher: Broadcasting 7 events.
          [21.01.2022 22:58.19.268] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
              at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
              at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:17:12)
              at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:236:11)
              at IncomingMessage.emit (events.js:412:35)
              at endReadableNT (internal/streams/readable.js:1334:12)
              at processTicksAndRejections (internal/process/task_queues.js:82:21)
          (Use `node --trace-warnings ...` to show where the warning was created)
          [21.01.2022 22:58.19.273] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          [21.01.2022 22:58.19.275] [ERROR] (node:2726) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          [21.01.2022 22:58.19.301] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 22:58.19.303] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 4)
          [21.01.2022 22:58.19.677] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 22:58.19.678] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 6)
          [21.01.2022 22:58.19.904] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 22:58.19.905] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
          [21.01.2022 22:58.41.124] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/.google.com/public/basic.ics
          [21.01.2022 22:58.41.125] [INFO]  Calendar-Fetcher: Broadcasting 7 events.
          [21.01.2022 22:58.41.173] [LOG]   Use existing newsfetcher for url: https://news.yahoo.co.jp/rss/topics/it.xml
          [21.01.2022 22:58.41.176] [INFO]  Newsfeed-Fetcher: Broadcasting 8 items.
          [21.01.2022 22:58.41.407] [INFO]  Newsfeed-Fetcher: Broadcasting 8 items.
          [21.01.2022 22:58.41.933] [ERROR] Whoops! There was an uncaught exception...
          [21.01.2022 22:58.41.938] [ERROR] PythonShellError: OSError: [Errno 98] Address already in use
              at PythonShell.parseError (/home/pi/MagicMirror/node_modules/python-shell/index.js:295:21)
              at terminateIfNeeded (/home/pi/MagicMirror/node_modules/python-shell/index.js:190:32)
              at ChildProcess.<anonymous> (/home/pi/MagicMirror/node_modules/python-shell/index.js:182:13)
              at ChildProcess.emit (events.js:400:28)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
              ----- Python Traceback -----
              File "modules/MMM-FastNotes/FastNotes.py", line 25, in <module>
                main()
              File "modules/MMM-FastNotes/FastNotes.py", line 21, in main
                raise e
              File "modules/MMM-FastNotes/FastNotes.py", line 17, in main
                start(host=args.host, port=args.port, debug=args.debug)
              File "/home/pi/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py", line 72, in start
                app.run(host, port, debug)
              File "/usr/local/lib/python3.7/dist-packages/flask/app.py", line 990, in run
                run_simple(host, port, self, **options)
              File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 1052, in run_simple
                inner()
              File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 1005, in inner
                fd=fd,
              File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 848, in make_server
                host, port, app, request_handler, passthrough_errors, ssl_context, fd=fd
              File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 740, in __init__
                HTTPServer.__init__(self, server_address, handler)
              File "/usr/lib/python3.7/socketserver.py", line 452, in __init__
                self.server_bind()
              File "/usr/lib/python3.7/http/server.py", line 137, in server_bind
                socketserver.TCPServer.server_bind(self)
              File "/usr/lib/python3.7/socketserver.py", line 466, in server_bind
                self.socket.bind(self.server_address) {
            traceback: 'Traceback (most recent call last):\n' +
              '  File "modules/MMM-FastNotes/FastNotes.py", line 25, in <module>\n' +
              '    main()\n' +
              '  File "modules/MMM-FastNotes/FastNotes.py", line 21, in main\n' +
              '    raise e\n' +
              '  File "modules/MMM-FastNotes/FastNotes.py", line 17, in main\n' +
              '    start(host=args.host, port=args.port, debug=args.debug)\n' +
              '  File "/home/pi/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py", line 72, in start\n' +
              '    app.run(host, port, debug)\n' +
              '  File "/usr/local/lib/python3.7/dist-packages/flask/app.py", line 990, in run\n' +
              '    run_simple(host, port, self, **options)\n' +
              '  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 1052, in run_simple\n' +
              '    inner()\n' +
              '  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 1005, in inner\n' +
              '    fd=fd,\n' +
              '  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 848, in make_server\n' +
              '    host, port, app, request_handler, passthrough_errors, ssl_context, fd=fd\n' +
              '  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 740, in __init__\n' +
              '    HTTPServer.__init__(self, server_address, handler)\n' +
              '  File "/usr/lib/python3.7/socketserver.py", line 452, in __init__\n' +
              '    self.server_bind()\n' +
              '  File "/usr/lib/python3.7/http/server.py", line 137, in server_bind\n' +
              '    socketserver.TCPServer.server_bind(self)\n' +
              '  File "/usr/lib/python3.7/socketserver.py", line 466, in server_bind\n' +
              '    self.socket.bind(self.server_address)\n' +
              'OSError: [Errno 98] Address already in use\n',
            executable: 'python3',
            options: null,
            script: 'modules/MMM-FastNotes/FastNotes.py',
            args: [ '--host', '192.168.11.10', '--port', 5000 ],
            exitCode: 1
          [21.01.2022 22:58.41.945] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [21.01.2022 22:58.41.945] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [21.01.2022 22:58.42.657] [INFO]  Calendar-Fetcher: Broadcasting 7 events.
          [21.01.2022 22:59.55.175] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 22:59.55.176] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 10)
          [21.01.2022 23:00.14.200] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.14.202] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 12)
          [21.01.2022 23:00.14.982] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.14.983] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 14)
          [21.01.2022 23:00.15.173] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.15.176] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 16)
          [21.01.2022 23:00.15.940] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.15.942] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 18)
          [21.01.2022 23:00.44.211] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.44.213] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 20)
          [21.01.2022 23:00.45.231] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.45.233] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 22)
          [21.01.2022 23:00.50.161] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:00.50.163] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 24)
          [21.01.2022 23:01.14.211] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:01.14.213] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 26)
          [21.01.2022 23:01.14.284] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:01.14.285] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 28)
          [21.01.2022 23:01.14.421] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:01.14.423] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 30)
          [21.01.2022 23:01.15.245] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Error: Request failed with status code 400
          [21.01.2022 23:01.15.246] [ERROR] (node:2726) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 32)
          Thank you for reading such a long code!
          AND “ctrl-shift-i
          and select the tab labeled console”
          Is it mean to change the name of the terminal like this??
          Thx.
            sdetweil @lina-ja
            @lina-ja said in
            you have a bunch of errors
            google photos 400
            Can't See Calendar, New Feed and To Do List Module ;(:
            File “/home/pi/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 72, in start
            sounds like on google, your authentication expired and u need to reboot for the second
            on the developers window, you do that on the MagicMirror screen
            • L Offline
              lina-ja @sdetweil
              Thanks to you I could open the developers window!
              As this picture show, there are the same errors appeared again and again.
              (main.js:350)
              I will try to debug of Fast-Note module and Google Photo Module!
              But I still cannot find why the calendar, News Feed and ToDoList module are not working… :disappointed_face:
              Thanks.
              • L Offline
                lina-ja @lina-ja
                Incidentally this is the photo of what happened in my modules.
                When I load the page, “Loading” was just displayed for 1 sec and after that, part of the calendar module will completely disappeared.
                  sdetweil @lina-ja
                  @lina-ja no idea really… but I DO see a missing module output on one of my systems…
                  • L Offline
                    lina-ja @sdetweil
                    @sdetweil Thx for the reply!
                    Where did you find the missing module output?
                    (I already checked my config.js file. )
                      sdetweil @lina-ja
                      @lina-ja on my system , one of my modules in config.js shows and then disappears… left column only
                      • L Offline
                        lina-ja @sdetweil
                        @sdetweil Wow, so we have the same problem, right?
                        Let’s share the solution with each other if we could solve it!
                        I will try to find the solution…
