    Magic Mirror Entryway Coat Rack with Storage
    16 Posts 5 Posters 6.2k Views 5 Watching
    • SharkbyteS Offline
      Sharkbyte @sdetweil
      @sdetweil Thanks yep always backing up software
      Technically challenged all day everyday.
      So then I just go here Evolution MMA
      Of course though spending time with the son is always the best of the best!
        Mykle1 Project Sponsor Module Developer @Sharkbyte
        @sharkbyte
        Classy bro! Well done. :thumbsup:
          mmoayed
          Hello , I want to implement this Model in my Magicmirror . Where can i find it.
          But I also want to ask if you can help . When am installing any new model and install it in this folder
          /home/pi/MagicMirror/modules
          ![0_1643624184459_a77306d5-0c4c-44ad-be6a-76baf7f83bd4-image.png](Uploading 100%)
          and after each installment, I have all new modules saved in the modules folder
          ![0_1643624295201_1edca06c-1507-4f58-9546-0e8b788a641e-image.png](Uploading 100%)
          The next step I go to the /home/pi/MagicMirror/config and I added the module
          ![0_1643629217765_6ad392c8-fa9a-400e-969a-eb47262b5fd4-image.png](Uploading 100%)
          but it is not working, i think i have missed something, can you help?
            sdetweil @mmoayed
            @mmoayed what does not working mean?
            all your pics did not load
            the pic in forum icon is 3rd from the right
            sun over the mountain with the page corner folded
              mmoayed @sdetweil
              @sdetweil ,
              Well, I don’t know why. I actully liked the model you have used and I want to do the same and in Calander to display 30 days per months .
              I have embeded my google calander, but I do not know how to display as you have did.
              This is the first part of my Question.
              The second part is when I want to add more new modules out of default ones, for example, I follow the steps and installed Calander_montls , and first Install the model to this folder /home/pi/MagicMirror/modules
              and then copy this code to config/config.js files.
              What I noticed If I leave calender_momthly in /home/pi/MagicMirror/modules folder, I got an error when executing, but when I move it to ~/MagicMirror/modules/default it works without error or I have to give the path in the module name, but even if I do like this but there is no output.
              How can you help to make all new modules to show output and how i can i use the same one you did .
              BR,
                sdetweil @mmoayed
                @mmoayed read the links in my signature
                practice a couple times. I didn’t write them but they help
                every module install is the same
                read their instructions for any extra steps
                sometimes they fail into this problem
                  @sdetweil nothing goes into default.
                  those are for the mm supplied modules
                    mmoayed @sdetweil
                    @sdetweil thank you i solved it by installing npm install request that was missed in doco.
                    Well, what is the name of the module you are using to display tasks in this show :
                    Best Regards,
                    Mohammed
                      mmoayed @mmoayed
                      @mmoayed said in Magic Mirror Entryway Coat Rack with Storage:
                      Can I use my google account to display Timetable like this?
                      Best Regards,
                      Mohammed
                        sdetweil @mmoayed
                        @mmoayed I am not doing that at all.
                        calendar_monthly does something like wall calendar.but not mine, don’t use it myself
