    Weather showing wrong weather for my location
    11 Posts 4 Posters 3.6k Views 4 Watching
      sdetweil @TangoE30
      @TangoE30 the API url changed with the new openweathermap API key (v3)
      mmm-openweathermap uses the 2.5/onecall api
      which may require the v3 API config if the apikey is new.
      I would open the developers window ctrl-shift-i on the keyboard, and select the console tab, and put a unique part of the module name in the filter field
      and see what the error is. I expect 401, access denied
      • T Offline
        TangoE30 @sdetweil
        Thanks for the quick reply! Good information about the API versions and you’re correct that I just signed up (March '23) for a new API.
        Per your suggestions, the following two error codes are displayed as follows:
        1. Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled. loader.js:
        2. 214 Error on loading stylesheet: css/custom.css
        This previously did not show because I followed a command:touch ~/MagicMirror/css/custom.css. Since then, I have deleted the custom.css in my directory as there was no change.
        At the end of the day, if the modules need an updated API version, I may have to stick with the default module or search for another that works with the API version 3.
        Any suggestions on how to fix the current errors or a recommended weather module is appreciated.
          sdetweil @TangoE30
          @TangoE30 put the empty custom.css back
          at least those two errors will go away
          my install script does the touch to create the empty file, 1. to get rid of the useless error messages, 2. many people don’t know how to create the file early in their mm experience
          there should have been other errors tho
          specific to the weathermap module.
          some of the modules support an apiVersion: parameter
          defaults to 2.5 but can be changed to 3.0
          • T Offline
            TangoE30 @sdetweil
            Thanks again Sam! I put the touch ~/MagicMirror/css/custom.css back into the directory and those two errors (Refused to apply style & 214 Error) did go away.
            I tried to install another module MMM-OneCallWeather, with the option to change from 2.5 to 3.0. Upon adding the module and my latitude and longitude and API Key, I’m still receiving an “Loading” message. There are three errors related to icons not showing up.
            For now, I’m going to see how I can modify the default Weather Module or continue to search for another that accepts the 3.0 API key.
              sdetweil @TangoE30
              @TangoE30 the default weather module also provides an apiVersion config option
                sdetweil @TangoE30
                @TangoE30 if u are willing to share your apikey w me. I can look at the problem w whatever module you suggest.
                send in a private chat
                • T Offline
                  TangoE30 @sdetweil
                  Jackpot!!!
                  A quick update and I finally think I figured it out, at least for MMM-OpenWeatherForecast by:
                  • Subscribing to Open Weather’s One Call by Call (https://openweathermap.org/price)
                  • Changing my node_helper.js line 44 from 2.5 to 3.0 :
                  var url = https://api.openweathermap.org/data/3.0/onecall?"
                  Thanks again and I’ll share on the other thread as well. “https://forum.magicmirror.builders/topic/17644/a-working-weather-module”
