    Calendar Color
    27 Posts 12 Posters 22.4k Views 13 Watching
    • B
      billp100
      I am trying to add multiple calendars in one module and have them each have a different color, here is what I have so far, the maximumNumberOfDays is working, but the calendar is still showing up in the default color.
      module: 'calendar',
      header: 'family',
      position: 'top_left',
                    colored: true,
                                              symbol: 'male',
                                              url: 'xxxxxxx',
                    color: '#f70000',
                    maximumNumberOfDays: '14',
      strawberry 3.141S 1 Reply Last reply
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @billp100
        @billp100 based on the documentation it should look somehow like this
          module: 'calendar',
          header: 'family',
            colored: true,
                symbol: 'male',
                url: 'xxxxxxx',
                color: '#f70000'
            maximumNumberOfDays: 14
        B 1 Reply Last reply
        • B
          billp100 @strawberry 3.141
          @strawberry-3.141 I’ve tried it that way too with no luck.
          • strawberry 3.141S
            @billp100 are you using the develop branch? this feature is currently not merged in the master branch
            • B
              @strawberry-3.141 That’s it then. I didn’t realize that. Is there away for me to get that feature without having to start over?
              • strawberry 3.141S
                @billp100 to use the develop branch you just have to do the following
                cd ~/MagicMirror
                git fetch
                git checkout develop
                git pull
                npm install
                Reply Quote 1
                • B
                  @strawberry-3.141 I just did those steps and got an npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed message
                  • B
                    billp100
                    Got it! thank you for your help
                    • Mitch1138M
                      Mitch1138
                      Great discussion. I have also added the options to add color the my two calendars, without success. Does anyone know if color is active in the current code? Here is my config setup:
                          module: 'calendar',
                          header: 'My Calendar',
                          	colored:  true,
                      		symbol: 'calendar ',
                      		url: 'https://calendar.google.com/calendar/ical/.../basic.ics',
                      		color: '#f70000'
                      		symbol: 'calendar-o ',
                      		color: '#04f448'
                      Many thanks
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Mitch1138
                        @Mitch1138 its still in the develop branch only
                        R 1 Reply Last reply
                        • Mitch1138M
                          Mitch1138
                          That was fast, thanks very much. How can you tell when it is released?
                          A 1 Reply Last reply
                          • A
                            Aries1984 Module Developer @Mitch1138
                            quick question on this issue…it the function already released? I can’t get it to work :( My config is:
                                        colored: true,
                                        header: "Termine",
                                            displaySymbol: true,
                                            timeFormat: "absolute",
                                            getRelative: "0",
                                            urgency: "0",
                                            dateFormat: "DD.MM HH:mm",
                                            FullDayEventDateFormat: "DD.MM",
                                            fetchInterval: "5000",
                                            fade: false,
                                                    symbol: "mars",
                                                    color: '#f70000',
                                                     url: "https://calendar.google.com/calendar...",
                                                    symbol: "venus",
                                                    color: '#f70000',
                                                    symbol: "clock",
                                                    color: '#f70000',
                                                    symbol: "globe",
                                                    color: '#f70000',
                                                    symbol: "cocktail",
                                                    color: '#f70000',
                            • L
                              LeFreak76
                              Hello Aries,
                              have you found a solution for this problem? I have started my Mirror Build today and achieved a lot of good working things. But the calendars are driving me nuts. First test with MMM-MyCalendar failed because of incorect displayed times (11 or 25 minutes off). Never the less that one had colors. Now i switched back to the “default” calendar, and at least the times are properly shown (despite the fact the the absolute or relative Parameters are doing nothing…). Unfortunately it is not possible to change the colors of the different url’s.
                              So please drop me a line if you found a solution to it. Or if not “Same problem here +1”
                              Thanks a lot
                              LeFreak76 from Hamburg
                              • H
                                hockey2112
                                @LeFreak76 , I found a solution that worked for me: https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar#calendar-configuration
                                Basically, you need to add colored and coloredSymbolOnly settings/values. Then you can add the color setting with the hex code for each calendar.
                                • R
                                  rally @strawberry 3.141
                                  @strawberry-3-141 What does that mean?
                                  It’s not available?
                                  • M
                                    Mrc
                                    Go to folder MagicMirror/modules/default/calendar , edit calendar.js , change values colored and coloredSymbolOnly to “true”
                                      sdetweil @Mrc
                                      @Mrc do NOT edit the module source files to change configuration.
                                      put the settings in the config section for that. module in config.js
                                      module:'calendar',
                                      config:{
                                          colored:true,
                                          coloredSymbolsOnly:true
                                      • R
                                        RJDaPirate
                                        Any one know why all of the calendar entries are being assigned Mom’s color instead of their own?
                                        			header: "Family Schedule",
                                        			position: "top_center",
                                        				colored: true,
                                        						symbol: "calendar-check",
                                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                        						 symbol: "Dad's Calender",
                                        							url: "https://calendar.google.com/calendar/ical/basic.ics",
                                        							color: '#6600CC'
                                        						symbol: "Mom's Calender",
                                        						color: '#ff0000'
                                        						Symbol: "A's Calender",
                                        						color: '#00ff00'
                                        						symbol: "J's Calender",
                                        						color: '#40E0D0'
                                        						symbol: "L's Calender",
                                        							url: "https://calendar.google.com/calendar/basic.ics",
                                        						color: '#ffd700'
                                          sdetweil @RJDaPirate
                                          @RJDaPirate
                                          the code looks up the color using the url as a key…
                                          all of your urls are the same so you will get results based on the url, where the name is stored last. M is higher than any other string, so the url will match that in the hash lookup
                                          • R
                                            RJDaPirate @sdetweil
                                            @sdetweil I deleted the personal settings within the urls. They are all different in the real config.js file.
