    Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service"
    36 Posts 4 Posters 10.3k Views 4 Watching
    • T Offline
      TvE @TvE
      Test with default config looks good 11h without a crash
      [02.03.2022 07:43.20.529] [LOG]   Starting MagicMirror: v2.18.0
      [02.03.2022 18:35.01.238] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
      And still running
      Thus I must deduce that one of the two services I had configured was triggering the problem
      I must enable my two changes individually to identify which is “bad”
        sdetweil @TvE
        @tve weird
        • T Offline
          TvE @sdetweil
          @sdetweil Yep (but I get exposed to that type of behavior daily :-) )
          I have also found the DEBUG setting in the conf file:
          logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"], // Add "DEBUG" for even more logging
          And am tcpdumping the traffic as well
          sudo tcpdump -i wlan0 -w tcpdump-wlan.pcap && sudo tcpdump -i eth0 -w tcpdump-eth.pcap &
          So let’s see what a bisect approach to disabling the “services” leads to
            sdetweil @TvE
            @tve yeh, sorry on debug. lots of calendar stuff
            • T Offline
              TvE @sdetweil
              @sdetweil Don’t worry about “debug” I just had to read the config in stead of skipping over that part
              I have now reverted to my original config and will enable the different service in bisect style.
              TvE test log (on legacy OS)
              Re-configured services resulting in crash:
                1 calendar
                2 openweather_current
                3 openweather_forecast
                4 news
              A: Sample config
                  => 11h and still OK
              B: Enable DEBUG log level
              C: Disable 2+3 (openweather) Enable 1+4
                  => 14 h and still OK
              D: Enable 2+3 (openweather) + disable 1+4 (news & calendar)
                  => ongoing
              So in a few days I should know what’s triggering the issue…
              • T Offline
                TvE @TvE
                Hmm so my latest config ran for more than 2 days.
                I’m now reverting to the initial config (enabling all four config-changes) and then time will tell
                • T Offline
                  TvE @TvE
                  @sdetweil This is really getting intersting - I have now re-enabled all the config changes so I’m back to my initial config and have been running for four days without a problem.
                  I even reproduced the problem on two differerent physical Pi’s (to eliminate HW) before starting to dissect the config…
                  So for now I can only conclude that something external was triggering these crashes!
                  I can now go back to the latest OS and start adding more stuff to my config (and keep my fingers crossed that I no longer encounter what-ever it was…)
                  Thank you for your help!
                    sdetweil @TvE
                    @tve interesting. keep us informed…
                    • thgmirrorT Offline
                      thgmirror
                      @TvE Do you use some wires at the GPIO? For example a PIR-sensor? Than may be interferences causes the issue when an electronic device is around your PI.
                      Or it is the temperature? Check it with
                      vcgencmd measure_temp
                      • T Offline
                        TvE @thgmirror
                        @sdetweil Will do!
                        @thgmirror Nope no PIR sensor (as in “not yet”)
                        My setup is as basic “Hello World!” as it can be (IMHO)
                        (The full config can be seen - as a diff to the sample - earlier in this thread)
                        The pi have been placed horisontally on my desk during all this testing.
                        It is in a cabinet though (the one from the “startet kit”).
                        I have measured the temperature (with my hand) and not been alarmed
                        Now I can validate my assumption based on your tip, thanx!
                        pi@mirror:~ $ vcgencmd measure_temp
                        temp=63.4'C
                        I have read that it’s possible to get add a cooling fin to the CPU, which is something I’ll look in to later (as I am also working on making a replacement for this guy, an image grabber [1].
                        You can no longer purchase it (and I can make more captures pr second on my pi) for 1/2 the price, I only need to add this thingy [2]
                        I have HelloWorld! for this, I “just” need to add
                        • Capture to RAM disk in stead of USB
                        • Auto upload to an ftp share (or maybe change this to scp…)
                        • Maybe get the pi’s to netboot as well (as I need 10+ of the system)
                        But that’s completely irellevant to my MM problem ;-)
                        [1 ]https://www.epiphan.com/wp-content/uploads/2014/07/epiphan-vga2ethernet-brochure.pdf
                        [2] https://www.epiphan.com/products/avio-4k/
                        thgmirrorT 1 Reply Last reply Reply Quote 0
                        • 2 / 4
