    nest-status access token
    17 Posts 4 Posters 7.3k Views 4 Watching
    • T Offline
      tanvir586
      Hi guys. im stuck on nest status access token. I have done everything but when I go to my windows terminal and try to get access token I get error. I’ll be really happy if someone help me out.terminal 1.jpg terminal.jpg
        djsri
        Hi again,
        Ok, so i’m pretty sure “invalid_grant” means your authorization-code is wrong? Can you try again.
        I started here: https://developers.google.com/nest/device-access/authorize
        Hopefully this helps.
          sdetweil @tanvir586
          @tanvir586 I think it should be curl -sL
          • T Offline
            tanvir586
            I will try it today
            • T Offline
              tanvir586
              Didn’t work. Same issue
                djsri
                Hi
                Have you tried running the command from the magic mirror? I.e ssh session. I was having trouble in windows and this worked for me.
                Providing you completed all the steps to receive the access token it should work. Let me know how you get on
                Cheers
                • T Offline
                  tanvir586 @djsri
                  @djsri Hi mate really thanks for your reply. Ive tried this but it didn’t work aswell. It’s been few days I’m stuck hear. don’t know what to do. my shh is enable aswell.
                  this is my raspberry terminal
                  pi@raspberrypi:~ $ curl -L -X POST ‘https://www.googleapis.com/oauth2/v4/token?client_id=668199754579-ghq6nf2u8lu1lap1gokc2pnfse4up40d.apps.googleusercontent.com&client_secret=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&code=4/0AX4XfWjVY8iQheoIbNCmddQADUHCQyv9-lmh-w-zNPp9XAN64y-P_fcuU6SFNKQWtEpFtA&grant_type=authorization_code&redirect_uri=https://www.google.com’
                  “error”: “invalid_grant”,
                  “error_description”: “Bad Request”
                  pi@raspberrypi:~ $
                    djsri
                    Hi again,
                    • T Offline
                      tanvir586 @djsri
                      @djsri Hi mate . Thank you so much. It’s Worked. Don’t know where I made mistake but it’s working now. Last couple of days I repeat this whole process so many times but it Worked this time. Really appreciate you help.
                      Now I’m facing another problem. I changed the update interval from 2 min to 5 seconds and im receiving this massage ( the device access API rate limit has been exceeded this module will try to load data again in 10 minutes ) Do I have to go back to the 2 minutes or is there anything I can do?
                      xadamxkX 1 Reply Last reply Reply Quote 0
                      • xadamxkX Offline
                        xadamxk @tanvir586
                        @tanvir586 the google api limits how often you can call their api. Every 5 seconds to way too often. I’d say set it anywhere from 3-10 minutes and you should be good.
                        • T Offline
                          tanvir586 @xadamxk
                          @xadamxk Thanks mate. I’m on 2min now and it looks good
                          • T Offline
                            tanvir586
                            Hi guys I’m having a new problem, it freeze after couple of hours. If I restart my magicmirror then it works fine then again after few hours it freeze again. Any solution?
                            • xadamxkX Offline
                              xadamxk @tanvir586
                              @tanvir586 Does your entire mirror freeze or just the module? When you say freeze, does the screen turn black or does every module just stop updating?
                              • T Offline
                                tanvir586 @xadamxk
                                @xadamxk … just my nest module. Everything else working fine.
                                • xadamxkX Offline
                                  xadamxk
                                  @tanvir586 Hard to say what the problem might be without having access to your device. If you read the console output of the magic mirror, or run in server only mode, you might be able to read the logs for any errors associated with the module.
                                  • T Offline
                                    tanvir586 @xadamxk
                                    @xadamxk this is my error log…
                                    [13.03.2022 13:12.50.413] [ERROR] Whoops! There was an uncaught exception…
                                    [13.03.2022 13:12.50.431] [ERROR] TypeError: Cannot read properties of undefined (reading ‘statusCode’)
                                    at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:16:22)
                                    at self.callback (/home/pi/node_modules/request/request.js:185:22)
                                    at Request.emit (node:events:394:28)
                                    at Request.onRequestError (/home/pi/node_modules/request/request.js:877:8)
                                    at ClientRequest.emit (node:events:394:28)
                                    at TLSSocket.socketErrorListener (node:_http_client:447:9)
                                    at TLSSocket.emit (node:events:394:28)
                                    at emitErrorNT (node:internal/streams/destroy:157:8)
                                    at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                                    at processTicksAndRejections (node:internal/process/task_queues:83:21)
                                    [13.03.2022 13:12.50.438] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [13.03.2022 13:12.50.439] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    • xadamxkX Offline
                                      xadamxk @tanvir586
                                      @tanvir586 Apologies for the late reply, I think the notification of your reply was eaten.
                                      https://github.com/michael5r/mmm-nest-status/blob/master/node_helper.js#L18
                                      Looks like the response from the API isn’t returning the expected response. There are several things it could be but it’s hard to know for sure. If you open your configuration file, do you have a custom updateInterval set? If not, add this:
                                      "updateInterval": 240000
                                      This will change the update interval from 2 to 4 minutes, which might help your issue. Give this a try and let me know if it works better for you.
                                      • T Offline
                                        tanvir586 @xadamxk
                                        @xadamxk Hi mate thanks for replying. Im using module refresher now and it refresh my module every few hours. I don’t see any errors after start using it.
