    nest-status access token
    17 Posts 4 Posters 5.9k Views 4 Watching
    • T Offline
      tanvir586
      Hi guys. im stuck on nest status access token. I have done everything but when I go to my windows terminal and try to get access token I get error. I’ll be really happy if someone help me out.terminal 1.jpg terminal.jpg
        djsri
        Hi again,
        Ok, so i’m pretty sure “invalid_grant” means your authorization-code is wrong? Can you try again.
        I started here: https://developers.google.com/nest/device-access/authorize
        Hopefully this helps.
          sdetweil @tanvir586
          @tanvir586 I think it should be curl -sL
          • T Offline
            tanvir586
            I will try it today
            • T Offline
              tanvir586
              Didn’t work. Same issue
                djsri
                Hi
                Have you tried running the command from the magic mirror? I.e ssh session. I was having trouble in windows and this worked for me.
                Providing you completed all the steps to receive the access token it should work. Let me know how you get on
                Cheers
                • T Offline
                  tanvir586 @djsri
                  @djsri Hi mate really thanks for your reply. Ive tried this but it didn’t work aswell. It’s been few days I’m stuck hear. don’t know what to do. my shh is enable aswell.
                  this is my raspberry terminal
                  pi@raspberrypi:~ $ curl -L -X POST ‘https://www.googleapis.com/oauth2/v4/token?client_id=668199754579-ghq6nf2u8lu1lap1gokc2pnfse4up40d.apps.googleusercontent.com&client_secret=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&code=4/0AX4XfWjVY8iQheoIbNCmddQADUHCQyv9-lmh-w-zNPp9XAN64y-P_fcuU6SFNKQWtEpFtA&grant_type=authorization_code&redirect_uri=https://www.google.com’
                  “error”: “invalid_grant”,
                  “error_description”: “Bad Request”
                  pi@raspberrypi:~ $
                    djsri
                    Hi again,
                    • T Offline
                      tanvir586 @djsri
                      @djsri Hi mate . Thank you so much. It’s Worked. Don’t know where I made mistake but it’s working now. Last couple of days I repeat this whole process so many times but it Worked this time. Really appreciate you help.
                      Now I’m facing another problem. I changed the update interval from 2 min to 5 seconds and im receiving this massage ( the device access API rate limit has been exceeded this module will try to load data again in 10 minutes ) Do I have to go back to the 2 minutes or is there anything I can do?
                      xadamxkX 1 Reply Last reply Reply Quote 0
                      • xadamxkX Offline
                        xadamxk @tanvir586
                        @tanvir586 the google api limits how often you can call their api. Every 5 seconds to way too often. I’d say set it anywhere from 3-10 minutes and you should be good.
                        • T Offline
                          tanvir586 @xadamxk
                          @xadamxk Thanks mate. I’m on 2min now and it looks good
