    Can't start MagicMirror
    9 Posts 2 Posters 2.0k Views 2 Watching
    • N6NGN
      N6NG
      Can’t start MagicMirror
      I tried to install autostart using PM2 information in the documentation. I was starting MM manually with pm2 start MagicMirror.
      Now I can’t start MagicMirror no matter how I try to do it… I try using my old pm2 start MagicMirror and it doesn’t start then I use the new pm2 start mm.sh and it won’t start. I make sure that I stop all the processes are stopped before I try it but it doesn’t do any good.
      Any suggestions?
      Dennis
        sdetweil @N6NG
        @n6ng use my script, fixuppm2.sh
        do
        pm2 stop all
        pm2 delete 0
        then run my script
        see https://github.com/sdetweil/MagicMirror_scripts
        mm.sh is in the installers folder
        • N6NGN
          N6NG
          followed your instructions but when I get to the fixuppm2.sh it says command not found
          And yes, I used your script to install it to start with.
          Dennis
          S 2 Replies Last reply
            sdetweil @N6NG
            @n6ng u have copy paste the line from the GitHub page
              sdetweil @N6NG
              @n6ng ok, another thing is it’s got an error.
              pm2 stop all
              pm2 logs --lines=50
              cd MagicMirror
              npm start
              see the error
              ctrl-c to exit mm
              • N6NGN
                N6NG
                Ok Sam… thanks
                I resolved the problem by renaming the MagicMirror to oMagicMirror
                I then ran the install script again and moved my modules and config directories over from the oMagicMirror to my new one and its working again… If I run into the problem again, I’ll cp the log information to solve it… Right now it’s running ok again…
                Dennis
                BTW… what does the Reputation -1 listing on my homepage mean… it doesn’t sound good… What caused that and how do I fix it?
                Thanks again…
                Dennis
                  sdetweil @N6NG
                  @n6ng generally neg rep mess someone downvoted your posts. I looked thru them all and don’t see it myself
                  • N6NGN
                    N6NG
                    Ok… thanks a lot… Believe it or not, I’m actually learning a lot by being in this group… Not bad for a 76 year old guy… Wish I had started this when I was 50 instead of 74… I’d be very smart now… Well thanks for everything. I’ll now find out how to mark this solved and put that under my belt…
                    Dennis
                      sdetweil @N6NG
                      @n6ng 70 here.
                      as for closing. you didn’t open as the right type so can’t close it
