    Google photos error code
    6 Posts 2 Posters 2.2k Views 2 Watching
    • delta 1D
      delta 1
      ![alt text])I’ve been trying to install the google photos module but I keep getting the same in thermal the line that I’m suppose to past my api key is not showing up I keep get module not found
      Module not found
      G photos.js
      /generate_token.js
        sdetweil @delta 1
        @delta-1 sounds like you didn’t do the npm install in the module folder
        delta 1D 1 Reply Last reply
        • delta 1D
          delta 1 @sdetweil
          Yes I did that
            sdetweil @delta 1
            @delta-1 well, I did that install last week twice and only experienced this error when I didn’t run npm install in the module folder
            you also have to be IN the module folder when u run the gen tokens pgm…
            • delta 1D
              delta 1 @sdetweil
              @sdetweil ok i did the install againe i passed that error now when i run (node generate_token.js ) the web page opens up but im getting (Authorization Error
              Error 400: invalid_request
              You can’t sign in to this app because it doesn’t comply with Google’s OAuth 2.0 policy for keeping apps secure.
              You can let the app developer know that this app doesn’t comply with one or more Google validation rules.
              Request Details
              The content in this section has been provided by the app developer. This content has not been reviewed or verified by Google.
              If you’re the app developer, make sure that these request details comply with Google policies.
              redirect_uri: urn:ietf:wg:oauth:2.0:oob )
              • delta 1D
                delta 1 @delta 1
                @delta-1 test
