    mmm-avstock error
    2 Posts 2 Posters 525 Views 2 Watching
    • T Offline
      Thona
      Hi.
      Im totally new to this so bear with me.
      Working on a MagicMirror and tryed to install avstock, but getting errors all the way.
      Any1 see what is wrong here?
      showSourceTitle: true,
      showPublishDate: true,
      broadcastNewsFeeds: true,
      broadcastNewsUpdates: true
      module: “MMM-AVStock”,
      position: “top_bar”, //“bottom_bar” is better for mode:ticker
      apiKey : “xxxxxxxxxxxxxxxx”,
      timeFormat: “DD-MM HH:mm”,
      width: null,
      symbols : [“mpcc”, “GOOGL”, “TSLA”],
      alias: [“MPCC”, “GOOGLE”, “TESLA”],
      locale: config.english,
      tickerDuration: 20,
      chartDays: 90,
      maxTableRows: null,
      mode : “table”, // “table” or “ticker”
      showChart: true,
      pureLine: false,
      chartWidth: null,
      showVolume: true,
      chartInterval: “daily”, // choose from [“intraday”, “daily”, “weekly”, “monthly”]
      movingAverage: {
      type: ‘SMA’,
      periods: [200]
      decimals : 2,
      chartType: ‘candlestick’, // ‘line’, ‘candlestick’, or ‘ohlc’
      chartLineColor: ‘#eee’,
      chartLabelColor: ‘#eee’,
      coloredCandles: true,
      debug: false
      pi@raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.18.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [15.03.2022 19:58.23.429] [LOG] Starting MagicMirror: v2.18.0
      [15.03.2022 19:58.23.439] [LOG] Loading config …
      [15.03.2022 19:58.23.446] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: Cannot access ‘config’ before initialization
      at Object. (/home/pi/MagicMirror/config/config.js:134:17)
      at Module._compile (node:internal/modules/cjs/loader:1116:14)
      at Object.Module._extensions…js (node:internal/modules/cjs/loader:1169:10)
      at Module.load (node:internal/modules/cjs/loader:988:32)
      at Module._load (node:internal/modules/cjs/loader:829:12)
      at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      at Module.require (node:internal/modules/cjs/loader:1012:19)
      at require (node:internal/modules/cjs/helpers:94:18)
      at loadConfig (/home/pi/MagicMirror/js/app.js:69:14)
      at App.start (/home/pi/MagicMirror/js/app.js:212:3)
      [15.03.2022 19:58.23.450] [LOG] Loading module helpers …
      [15.03.2022 19:58.23.473] [LOG] Initializing new module helper …
      [15.03.2022 19:58.23.475] [LOG] Module helper loaded: updatenotification
      [15.03.2022 19:58.23.477] [LOG] No helper found for module: helloworld.
      [15.03.2022 19:58.23.478] [LOG] All module helpers loaded.
      [15.03.2022 19:58.23.591] [LOG] Starting server on port 8080 …
      [15.03.2022 19:58.23.610] [LOG] Server started …
      [15.03.2022 19:58.23.611] [LOG] Connecting socket for: updatenotification
      [15.03.2022 19:58.23.614] [LOG] Starting module helper: updatenotification
      [15.03.2022 19:58.23.614] [LOG] Sockets connected & modules started …
      [15.03.2022 19:58.23.896] [LOG] Launching application.
      [15.03.2022 19:58.32.631] [LOG] Shutting down server…
      [15.03.2022 19:58.32.633] [LOG] Stopping module helper: updatenotification
        sdetweil @Thona
        @thona said in mmm-avstock error:
        syntax error.
        stop magicmirror
        then
        cd ~/MagicMirror
        npm run config:check
